Part numbers
Here's my list of part numbers that I collected over the years.
Thought I share it with everyone.
If you find incorrect parts, please feel free to let me know.
Datsun 521
Ignition
DATSUN 520 620
NS013842
P/NO.
25150-B5000
25150-B9800
Tension Rod Bushing
56112-W5000
Poly Urethane
9-8105 and 9-8106
Energy Suspension
2.2107g
Rear Leaf Spring
Bilstein Shocks
Front B46-1780-H0
Rear 606493
Patrol Parts
http://www.nissanparts.cc
air cleaner to carb insulator 16523-59600 $4.24
axle bearing 40210-85000 $38.15
axle lock nut - LH 43084-46500 $15.08 ('67 and later only)
axle lock washer 43069-44000 $4.26
axle seal 40227-32201 $5.46
brake hose - front 46201-C0102 $15.04
brake master cylinder 46010-44001 $112.64
brake return spring - frt cyl side 41022-30100 $1.87
brake return spring - rear lower 44071-30100 $3.14
brake return spring - frt adj side 41021-30100 $2.39
clutch disc 30100-90708 $75.23
clutch master cyl 30610-46500 $110.85
clutch pressure plate 30210-44003 $154.86
clutch release bearing 30502-55100 $24.89
clutch release brg retainer 30501-85060 $1.52
clutch release brg sleeve 30501-44000 $11.07
clutch slave cylinder 30620-08000 $39.76
clutch slave rebuild kit 30620-08027 $4.03
diff cover gskt 40515-44000 $1.31
fuel filter - '69 16400-F2601 $5.44
fuel filter - for glass bowl 16404-68225 $4.04
gas tank sending unit 17291-44002 $45.48
oil pressure sending unit 25027-58000 $48.68
output shaft seal 38189-44000 $10.81
plug wires 22450-80029 $43.00
rad hose - lower 21503-65200 $30.00
shift boot - inner 32853-43800 $8.19
shocks 56210-C4225 $58.22
steering damper 48611-46500 $106.92
sway bar bushings 56112-09400 $2.27
thermostat 170 21200-F3190 $8.85
thermostat by-pass hose 21069-58000 $3.84
temp sending unit 25080-62200 or 25080-89900 $21.97
valve cover gskt 13270-58000 $15.04
washer tank w/pump 27470-89901 $90.42
wheel cylinder cups - rear 44112-E5010 $2.53
wheel cylinder - LF 41113-35003 $41.83
wheel cylinder - RF 41111-35003 $39.05
wiper blades - up to '66 26362-44000 $10.35
F Brake Cylinders
41111-35003
41113-35003
Starter Solenoid
23343-43301
Points
22145-58000
Datsun Patrol Fram Oil Filter
PH2850
22157-46502 Dist rotor
16404-68225 Fuel Filter
Datsun 510
License Lamp
26510-21000
1968-Oil Cap
15255-B3430
SRP311 Clutch
Disk: 30100-W3490
Pressure Plate:30210-20111
Shift boot
74963-E6000
SSS Distributor
D4A5-10 6602
22100-N7400
Heater Hoses
B7020-A0800
B7021-A0800
Spring insulator
710 Offset Insulator
PN# 54320-U7000
SSS side Mirror
96301-N0400
96032-N0400
Water Bypass Hose (Intake manifold)
14080-A8602
510 Map Light
Light-25730-A4600
Switch-25733-A4600
Door hinge
NAPA # 675-5157
Nissan # H0400-73002
Datsun Badge
Bluebird
63806-N1600
Datsun1600
63806-23700
Quater Window Latch
76860-A1400
Fuel Filler Tube
17220-A5501
Washer Tank
27470-89901
Fuse Box Cover
25411-N0915
25410-21000 (68'-69')
PCV hose
11828-23002
PCV Valve
11810-A3501
Wagon Filler tube
17217-A5301
Fuse Box Clip
90467-08119 (Toyota part replacement)
Front Wheel Bearing Seal
Beck Arnley 052-1484
Brakes pads
Beck Arnley 082-0118
Brembo Rear Drums # 14.3302.10
Nissan 240z drums # 43206-E4100
Window Channel Felt
H0335-89931
Roadster Pressure Plate
30210-20111
SU Dual Fuel line
17520-15760
Clutch Kit L16L18
Exedy I2030-120245
Throw out bearing L16L18
Koyo I2020-101371
Koni Shocks
Front 86-2224
86 1612 (10.5 inch)
86 1849 (10.5-11)
86 1715 (11.5)
Rear 80-2299
Wagon
Rear Koni Shock
80 2008HD
80 1891
Datsun 521
80-1311 Rear Koni Red
520, 521, 620, 720 Pickup (2wd)
80-2102 Front Koni Red
NGK
Spark plug-B6ES
Stock # 7432
Platinum-B6EVX
Wire Set
Part # NE64
Stock # 9828
Pertronix
part # 1741
Tokico shocks
1968-69
HZ3002 Front 10.5''
HZ3003 Front 11''
HE2572 Rear
Wagon HE 2550
Subaru LSD
1985-1986 (production up to 3/86) XT 4WD (Subaru part # 7220 11000).
1986-1987 (production from 4/86-10/86) GL 4WD (Subaru part # 7220 11001).
1986-1991+ (production from 11/86) Loyale/GL 4WD (Subaru part # 7220 11002).
1988-1991 GL and XT-6 4WD (Subaru part # 22011 GA022).
Thorley headers
Nickel Chrome Finish
(part number THY-403)
Metallic/ceramic coating
(part number THY-403-C)
Belltech
3'' Block w/ 2 degree
part # 6202
1'' Block w/ 2 degree
part # 6002
Bluestreak
JH59X---Blue distro cap wbrass contacts
  • Replies 59
here are a few I have
fuse block for 510 (three wire) 25410-N0915
510 wagon left tail light 26556-A5900
510 wagon leaf spring bushings:
upper & lower shackle: 55046-U8600 & 55047-22900
frame mount: 55045-G2500
fly wheel bolts 12315-42L11
38mm SU linkage kit: 99996-D1110
Plastic floats for the 38mm SUs: 16061-K1407
Carb to mainfold insulators (Bakelite): 16174-15801
These are current, as I have bought them in the past year.
-Zerow- __________________
image.php?u=790&type=sigpic&dateline=1206776199Drive a DATSUN, Then Decide.:cool:
for those who don't have comp catalogs:
L-series
valve springs 99996-M1046
Valve spring retainers:
Aluminum: for lash pads between
.150 and .180 99996-M1152
.190-.240 99996-M1151
.250-.340 99996-M1150
Steel:
.150-.180 99996-M1050
.190-.240 99996-M1052
.250-.340 99996-M1051
Lash pads
99996-M1155 .150
99996-M1160 .160
99996-M1170 .170
99996-M1180 .180
99996-M1190 .190
99996-M1200 .200
99996-M1210 .210
99996-M1220 .220
99996-M1230 .230
99996-M1240 .240
99996-M1250 .250
99996-M1260 .260
99996-M1270 .270
99996-M1280 .280
99996-M1290 .290
99996-M1300 .300
99996-M1310 .310
99996-M1320 .320
99996-M1330 .330
99996-M1340 .340
spray bar 9996-D1087
Turbo head bolts short 11056-P7600, long 11059-P7600, washers 11058-21001
high pressure oil pump 15010-A1115
high volume oil pump 15010-S8000
gear reduction starter 23300-N5903R
  • 1 month later...
  • 3 months later...
Left Front door seal 76801-24000 also fits 520 and 521 PU
Left rear door seal 76803-2400
Right side seals were out of stock even 10 years back when I got the above seals]
Pre muffler [resonator] 20301-16500
Muffler 20101-16500
Tube [tail pipe end section with hanger] 20401-10400
Hubcap [portholes] 40315-10400 also fits 1500 Fair Lady Roadster
  • 8 months later...
  • 4 months later...
very helpful info. thank you
sorry to jack this thread but for those looking for fuse box covers. I do sell jdm ones. I do have it on my classified ad. only thing they are in japanese writing but they are all brand new units.
Edited by benzo
  • 8 months later...
Additional part numbers:
411 fuse block assembly 25410-1840 comes with cover. Will probably fit 410 and could be wired for 510 in a pinch, you would need to work out the unswitched versus switched 12 volt power.
Instrument panel voltage regulator, 2 part numbers. 25020-25900 and 25020-13200. One is for the 410 / 411 and the other is for the first generation 510. The difference is in the mounting / grounding tab. One is straight, the other has a 90 degree bend. If you luck out, just plug in and fasten the bolt. If not, a pair of pliers fixes everything. I have used these interchangably for 42 years so they do work!
  • 11 months later...
All these parts are still available as of 7/1/2011
Hood Bumpers 65157-A0600
Hood Bumpers 65158-A0600
Stub Axle Nuts 43262-21000
Heater Hose B7020-A0800
Heater Hose B7021-A0800
Available as of 9/2010:
1/4 Window Latches 76860-A1400
  • 4 weeks later...
This seems like the best place to ask. I have some parts/ part numbers and I am unsure what they are for. Is there anyone that can help? If there is someone that can help I will pm the part numbers. Please and thank you
These were available as of 8/1/2011
Rear Control Arm Bushings - 55045-21000
25mm Floor plugs - 06212-2500P
Intake Manifold Thick Washers - 14037-N3600
Fuel Door Bumpers - 77760-R8000
Door and Trunk Drain Covers - 80840-21001
2 Door Inner Door Window Squeegee RH - 80835-26501
2 Door Inner Door Window Squeegee LH - 80836-26501
"Datsun" Emblem Trunk/Fender - 63806-21300
More items still available as of 8/9/2011
Differential Breather - 38352-78600
4 Door rear door rubber bumpers - 82865-21010
Spare tire well plug (late 80's Stanza) that fit my 510 - 06212-5500P
Tool Bag - 99504-50Y004
Heater Hose Firewall Grommets - 27035-21000 - EDIT-These work but may not be the correct part.
  • 3 months later...
ran into this one recently, figured it would make a good first post... on a 720 its for the heater on the fusebox and for the ignition/main relay by the battery
through lots of hours of cross referencing I found all its nissan/datsun uses though :)
RELAY - MULTIPURPOSE 4-PIN
OEM#’S 2523089972, 2523089975, 2523089977
Beck Arnley# 203-0004, 203-0089
Four Seasons# 35984
standard#RY39
Other# 19936, RY5010, R800, R4228, R201, 1R1315
SPEC’s:
a/c, auto speed, heater, ignition, pump, choke, fan, starter, emission (various application depending on vehicle)
for the following nissan datsuns:
200SX 77 - 97
ALTIMA 93 - 97
210 79 - 82
AXXESS 90 - 95
240SX 89 - 97
B210 75 - 78
260Z 75
D21 86 - 93
280Z 75 - 78
F10 76 - 78
280ZX 79 - 83
MAXIMA 82 - 97
300ZX 84 - 96
MICRA 84 - 91
310 79 - 82
MULTI 86 - 88
510 78 - 81
NX 91 - 93
610 75 - 76
620 72 - 79
PICKUP 95 - 97
710 75 - 77
PULSAR 83 - 90
720 80 - 86
QUEST 93 - 97
810 77 - 81
QUEST 93 - 97
VAN 87 - 88
SENTRA 82 - 95
STANZA 82 - 92
PATHFINDER 87 - 97
  • 6 months later...
