pl521sss Posted April 24, 2008 Report Share Posted April 24, 2008 Here's my list of part numbers that I collected over the years. Thought I share it with everyone. If you find incorrect parts, please feel free to let me know. Datsun 521 Ignition DATSUN 520 620 NS013842 P/NO. 25150-B5000 25150-B9800 Tension Rod Bushing 56112-W5000 Poly Urethane 9-8105 and 9-8106 Energy Suspension 2.2107g Rear Leaf Spring Bilstein Shocks Front B46-1780-H0 Rear 606493 ########################################### Patrol Parts http://www.nissanparts.cc air cleaner to carb insulator 16523-59600 $4.24 axle bearing 40210-85000 $38.15 axle lock nut - LH 43084-46500 $15.08 ('67 and later only) axle lock washer 43069-44000 $4.26 axle seal 40227-32201 $5.46 brake hose - front 46201-C0102 $15.04 brake master cylinder 46010-44001 $112.64 brake return spring - frt cyl side 41022-30100 $1.87 brake return spring - rear lower 44071-30100 $3.14 brake return spring - frt adj side 41021-30100 $2.39 clutch disc 30100-90708 $75.23 clutch master cyl 30610-46500 $110.85 clutch pressure plate 30210-44003 $154.86 clutch release bearing 30502-55100 $24.89 clutch release brg retainer 30501-85060 $1.52 clutch release brg sleeve 30501-44000 $11.07 clutch slave cylinder 30620-08000 $39.76 clutch slave rebuild kit 30620-08027 $4.03 diff cover gskt 40515-44000 $1.31 fuel filter - '69 16400-F2601 $5.44 fuel filter - for glass bowl 16404-68225 $4.04 gas tank sending unit 17291-44002 $45.48 oil pressure sending unit 25027-58000 $48.68 output shaft seal 38189-44000 $10.81 plug wires 22450-80029 $43.00 rad hose - lower 21503-65200 $30.00 shift boot - inner 32853-43800 $8.19 shocks 56210-C4225 $58.22 steering damper 48611-46500 $106.92 sway bar bushings 56112-09400 $2.27 thermostat 170 21200-F3190 $8.85 thermostat by-pass hose 21069-58000 $3.84 temp sending unit 25080-62200 or 25080-89900 $21.97 valve cover gskt 13270-58000 $15.04 washer tank w/pump 27470-89901 $90.42 wheel cylinder cups - rear 44112-E5010 $2.53 wheel cylinder - LF 41113-35003 $41.83 wheel cylinder - RF 41111-35003 $39.05 wiper blades - up to '66 26362-44000 $10.35 F Brake Cylinders 41111-35003 41113-35003 Starter Solenoid 23343-43301 Points 22145-58000 Datsun Patrol Fram Oil Filter PH2850 22157-46502 Dist rotor 16404-68225 Fuel Filter ################################################# Datsun 510 License Lamp 26510-21000 1968-Oil Cap 15255-B3430 SRP311 Clutch Disk: 30100-W3490 Pressure Plate:30210-20111 Shift boot 74963-E6000 SSS Distributor D4A5-10 6602 22100-N7400 Heater Hoses B7020-A0800 B7021-A0800 Spring insulator 710 Offset Insulator PN# 54320-U7000 SSS side Mirror 96301-N0400 96032-N0400 Water Bypass Hose (Intake manifold) 14080-A8602 510 Map Light Light-25730-A4600 Switch-25733-A4600 Door hinge NAPA # 675-5157 Nissan # H0400-73002 Datsun Badge Bluebird 63806-N1600 Datsun1600 63806-23700 Quater Window Latch 76860-A1400 Fuel Filler Tube 17220-A5501 Washer Tank 27470-89901 Fuse Box Cover 25411-N0915 25410-21000 (68'-69') PCV hose 11828-23002 PCV Valve 11810-A3501 Wagon Filler tube 17217-A5301 Fuse Box Clip 90467-08119 (Toyota part replacement) Front Wheel Bearing Seal Beck Arnley 052-1484 Brakes pads Beck Arnley 082-0118 Brembo Rear Drums # 14.3302.10 Nissan 240z drums # 43206-E4100 Window Channel Felt H0335-89931 Roadster Pressure Plate 30210-20111 SU Dual Fuel line 17520-15760 Clutch Kit L16L18 Exedy I2030-120245 Throw out bearing L16L18 Koyo I2020-101371 ################################################# Koni Shocks Front 86-2224 86 1612 (10.5 inch) 86 1849 (10.5-11) 86 1715 (11.5) Rear 80-2299 Wagon Rear Koni Shock 80 2008HD 80 1891 Datsun 521 80-1311 Rear Koni Red 520, 521, 620, 720 Pickup (2wd) 80-2102 Front Koni Red 520, 521, 620, 720 Pickup (2wd) ################################################## NGK Spark plug-B6ES Stock # 7432 Platinum-B6EVX Wire Set Part # NE64 Stock # 9828 ################################################## Pertronix part # 1741 ################################################# Tokico shocks 1968-69 HZ3002 Front 10.5'' HZ3003 Front 11'' HE2572 Rear Wagon HE 2550 ################################################# Subaru LSD 1985-1986 (production up to 3/86) XT 4WD (Subaru part # 7220 11000). 1986-1987 (production from 4/86-10/86) GL 4WD (Subaru part # 7220 11001). 1986-1991+ (production from 11/86) Loyale/GL 4WD (Subaru part # 7220 11002). 1988-1991 GL and XT-6 4WD (Subaru part # 22011 GA022). ################################################# Thorley headers Nickel Chrome Finish (part number THY-403) Metallic/ceramic coating (part number THY-403-C) ################################################# Belltech 3'' Block w/ 2 degree part # 6202 1'' Block w/ 2 degree part # 6002 ################################################# Bluestreak JH59X---Blue distro cap wbrass contacts ################################################# 1 Quote Link to comment
Pacific coast Datsun Posted April 24, 2008 Report Share Posted April 24, 2008 Good info. Can this go into the FAQ thread? Quote Link to comment
fryanbacon Posted April 24, 2008 Report Share Posted April 24, 2008 Fuse Box Cover 25411-N0915 25410-21000 (68'-69') where can you find these? I've looked and nobody has them anymore Quote Link to comment
]2eDeYe Posted April 24, 2008 Report Share Posted April 24, 2008 Good info. Can this go into the FAQ thread? Done :D Quote Link to comment
hang_510 Posted April 24, 2008 Report Share Posted April 24, 2008 :cool: there is a good 510 part number sticky on the510realm.com Quote Link to comment
pl521sss Posted April 24, 2008 Author Report Share Posted April 24, 2008 It's good idea to have it here also. Good info. Can this go into the FAQ thread? :cool: there is a good 510 part number sticky on the510realm.com Quote Link to comment
ssfwgn Posted April 25, 2008 Report Share Posted April 25, 2008 here are a few I have fuse block for 510 (three wire) 25410-N0915 510 wagon left tail light 26556-A5900 510 wagon leaf spring bushings: upper & lower shackle: 55046-U8600 & 55047-22900 frame mount: 55045-G2500 fly wheel bolts 12315-42L11 Quote Link to comment
pl521sss Posted April 25, 2008 Author Report Share Posted April 25, 2008 38mm SU linkage kit: 99996-D1110 Plastic floats for the 38mm SUs: 16061-K1407 Carb to mainfold insulators (Bakelite): 16174-15801 These are current, as I have bought them in the past year. -Zerow- __________________ Drive a DATSUN, Then Decide.:cool: Quote Link to comment
fiveNdime Posted April 25, 2008 Report Share Posted April 25, 2008 The fuse block cover is killing me.:lol: I wish I had new ones on all my dattos! Quote Link to comment
ssfwgn Posted May 4, 2008 Report Share Posted May 4, 2008 for those who don't have comp catalogs: L-series valve springs 99996-M1046 Valve spring retainers: Aluminum: for lash pads between .150 and .180 99996-M1152 .190-.240 99996-M1151 .250-.340 99996-M1150 Steel: .150-.180 99996-M1050 .190-.240 99996-M1052 .250-.340 99996-M1051 Lash pads 99996-M1155 .150 99996-M1160 .160 99996-M1170 .170 99996-M1180 .180 99996-M1190 .190 99996-M1200 .200 99996-M1210 .210 99996-M1220 .220 99996-M1230 .230 99996-M1240 .240 99996-M1250 .250 99996-M1260 .260 99996-M1270 .270 99996-M1280 .280 99996-M1290 .290 99996-M1300 .300 99996-M1310 .310 99996-M1320 .320 99996-M1330 .330 99996-M1340 .340 spray bar 9996-D1087 Turbo head bolts short 11056-P7600, long 11059-P7600, washers 11058-21001 high pressure oil pump 15010-A1115 high volume oil pump 15010-S8000 gear reduction starter 23300-N5903R Quote Link to comment
pl521sss Posted June 17, 2008 Author Report Share Posted June 17, 2008 Datsun 410 411 46201-69010 Hose-brake 1.3L (drum) 46201-27410 Hose-brake 1.6L (disc) Quote Link to comment
pl521sss Posted September 22, 2008 Author Report Share Posted September 22, 2008 Fel-Pro OS20042C Oil Pan Gasket FEL-PRO Part # MS226931 Intake & Exhaust Manifold Gasket Set; Rectangular exh. ports Quote Link to comment
MikeRL411 Posted September 22, 2008 Report Share Posted September 22, 2008 Left Front door seal 76801-24000 also fits 520 and 521 PU Left rear door seal 76803-2400 Right side seals were out of stock even 10 years back when I got the above seals] Pre muffler [resonator] 20301-16500 Muffler 20101-16500 Tube [tail pipe end section with hanger] 20401-10400 Hubcap [portholes] 40315-10400 also fits 1500 Fair Lady Roadster Quote Link to comment
pl521sss Posted June 3, 2009 Author Report Share Posted June 3, 2009 waterCoolant bypass hose on L series motors A4056-23001 Quote Link to comment
datsun4dsc Posted October 9, 2009 Report Share Posted October 9, 2009 521520 Front suspension Bushing 54519-08700 Quote Link to comment
benzo Posted October 9, 2009 Report Share Posted October 9, 2009 (edited) very helpful info. thank you sorry to jack this thread but for those looking for fuse box covers. I do sell jdm ones. I do have it on my classified ad. only thing they are in japanese writing but they are all brand new units. Edited October 9, 2009 by benzo Quote Link to comment
MikeRL411 Posted July 5, 2010 Report Share Posted July 5, 2010 Additional part numbers: 411 fuse block assembly 25410-1840 comes with cover. Will probably fit 410 and could be wired for 510 in a pinch, you would need to work out the unswitched versus switched 12 volt power. Instrument panel voltage regulator, 2 part numbers. 25020-25900 and 25020-13200. One is for the 410 / 411 and the other is for the first generation 510. The difference is in the mounting / grounding tab. One is straight, the other has a 90 degree bend. If you luck out, just plug in and fasten the bolt. If not, a pair of pliers fixes everything. I have used these interchangably for 42 years so they do work! Quote Link to comment
kemmer Posted June 30, 2011 Report Share Posted June 30, 2011 Wiper Blade Inserts napa 60-1614 Quote Link to comment
D52E Posted July 8, 2011 Report Share Posted July 8, 2011 All these parts are still available as of 7/1/2011 Hood Bumpers 65157-A0600 Hood Bumpers 65158-A0600 Stub Axle Nuts 43262-21000 Heater Hose B7020-A0800 Heater Hose B7021-A0800 Available as of 9/2010: 1/4 Window Latches 76860-A1400 Quote Link to comment
chester Posted August 1, 2011 Report Share Posted August 1, 2011 This seems like the best place to ask. I have some parts/ part numbers and I am unsure what they are for. Is there anyone that can help? If there is someone that can help I will pm the part numbers. Please and thank you Quote Link to comment
datzenmike Posted August 1, 2011 Report Share Posted August 1, 2011 Go ahead..... Quote Link to comment
D52E Posted August 5, 2011 Report Share Posted August 5, 2011 These were available as of 8/1/2011 Rear Control Arm Bushings - 55045-21000 25mm Floor plugs - 06212-2500P Intake Manifold Thick Washers - 14037-N3600 Fuel Door Bumpers - 77760-R8000 Door and Trunk Drain Covers - 80840-21001 2 Door Inner Door Window Squeegee RH - 80835-26501 2 Door Inner Door Window Squeegee LH - 80836-26501 "Datsun" Emblem Trunk/Fender - 63806-21300 Quote Link to comment
D52E Posted August 11, 2011 Report Share Posted August 11, 2011 More items still available as of 8/9/2011 Differential Breather - 38352-78600 4 Door rear door rubber bumpers - 82865-21010 Spare tire well plug (late 80's Stanza) that fit my 510 - 06212-5500P Tool Bag - 99504-50Y004 Heater Hose Firewall Grommets - 27035-21000 - EDIT-These work but may not be the correct part. Quote Link to comment
dreadsiren Posted December 8, 2011 Report Share Posted December 8, 2011 ran into this one recently, figured it would make a good first post... on a 720 its for the heater on the fusebox and for the ignition/main relay by the battery through lots of hours of cross referencing I found all its nissan/datsun uses though :) RELAY - MULTIPURPOSE 4-PIN OEM#’S 2523089972, 2523089975, 2523089977 Beck Arnley# 203-0004, 203-0089 Four Seasons# 35984 standard#RY39 Other# 19936, RY5010, R800, R4228, R201, 1R1315 SPEC’s: a/c, auto speed, heater, ignition, pump, choke, fan, starter, emission (various application depending on vehicle) for the following nissan datsuns: 200SX 77 - 97 ALTIMA 93 - 97 210 79 - 82 AXXESS 90 - 95 240SX 89 - 97 B210 75 - 78 260Z 75 D21 86 - 93 280Z 75 - 78 F10 76 - 78 280ZX 79 - 83 MAXIMA 82 - 97 300ZX 84 - 96 MICRA 84 - 91 310 79 - 82 MULTI 86 - 88 510 78 - 81 NX 91 - 93 610 75 - 76 620 72 - 79 PICKUP 95 - 97 710 75 - 77 PULSAR 83 - 90 720 80 - 86 QUEST 93 - 97 810 77 - 81 QUEST 93 - 97 VAN 87 - 88 SENTRA 82 - 95 STANZA 82 - 92 PATHFINDER 87 - 97 Quote Link to comment
D52E Posted June 14, 2012 Report Share Posted June 14, 2012 Door trim panel clips... Quote Link to comment
