Pacific coast Datsun Posted April 22, 2008 Report Share Posted April 22, 2008 I have an issue on my 72 wagon. Its a 3 speed auto on the floor, i have to start it buy turning the key to the "start" position then using a screwdriver "jump" the two terminals on the starter. Works every time but i also notice a rattling noise coming from the starter. Sounds like something is hitting the flywheel. It does goes away after it warms up. I remember Mklotz mentioning a part on the trans. that may cause an issue like this but cant rememebr that part name. A new starter is only $35 but i need to know if i need to replace anything else while im under the car. Thanks in advance...:cool: Quote Link to comment
Duke Posted April 22, 2008 Report Share Posted April 22, 2008 Sounds like a wiring issue. I would check that before you check anything. If the starter is not turning over when you turn the key to start, but it will when you jump it with a screwdriver, I would vote for a wiring issue. In regards to the rattling issue, I don't really know. I would say get the wiring good then see if you need a new starter. Quote Link to comment
ggzilla Posted April 22, 2008 Report Share Posted April 22, 2008 It is not supposed to start unless the shifter is in P or N. If you turn the key to Start, and wiggle the shifter, even move it from P to D and back, does it engage the starter at any point? If so, the problem is in the shifter-switch mechanism. Quote Link to comment
Pacific coast Datsun Posted April 22, 2008 Author Report Share Posted April 22, 2008 Ill try that tomorrow. The wiring on the car looks to be untouched/stock. Where is the shifter switch located? Quote Link to comment
hang_510 Posted April 22, 2008 Report Share Posted April 22, 2008 ^switch is on the tranny, possibly the forward of the 2 (3?) try to start it in N and then that would be the switch. like ggzilla described. untouched wiring could mean corrosion too, clean em up anyways :D solid grounds are important! Quote Link to comment
bonvo Posted April 22, 2008 Report Share Posted April 22, 2008 i had a similar issue it turned out to be the starter it would just click when i turned to start but u would bump it with the screw driver and it worked the silanoid in the starter was bad Quote Link to comment
banzai510(hainz) Posted April 22, 2008 Report Share Posted April 22, 2008 Well I would put it in Park and Neutral and pull the wire off and see if 12volts on start. what are the chances that 2 postiones of a switch are bad at the same time. well anyway Pac Coast a true L motor guy would have a spare starter for troubel shooting. Most likely its the selinoid on the starter. But I forgot about the automatics and yes it could be the switch. (Could always jump the wire to bypass the switch) if you know the color codes. Quote Link to comment
Pacific coast Datsun Posted April 22, 2008 Author Report Share Posted April 22, 2008 I will bust out the test light today & see whats up. TY Hainz...i tried to put a spare on but the solenoid was on the wrong side [hit the block & bolt holes were off] Every time i start it people think im stealing it :rolleyes: Quote Link to comment
banzai510(hainz) Posted April 22, 2008 Report Share Posted April 22, 2008 new starter is only $35 ???????? I think youll be doing that 35$starter soon enough. yeah see if 12volt at starter wire when in PARK and Neutral. I have heard of those offset L motor starters but never actually seen one. When I was 1st into 510s when I got out of the Airforce I would get the Schucks Lifetime warrentee STARTERS. MPA brand rebuilt in Maylasia. I changed 2 in 3 years and I was done with them. I guess it just depends on who has the contract to rebuild them. I know the Autolite rebuilds from Schucks are abit better at least for the alternators. beck Arnely or Nissan is the way to go if getting off the shelf stock parts(Not including the GM saturn units) I was reading on the jeep Cherokees that most of the NO START on them are just dirty contacks on the automatics Quote Link to comment
MikeRL411 Posted April 22, 2008 Report Share Posted April 22, 2008 The BW transmission interlock switch is on the [American] driver's side and can be touchy. It can also break the cable if the engine mounts are worn and let the engine vibrate too much. It is usually covered with road gunk and hard to see let alone adjust. The adjustment is to rotate wih a continuity meter and set half way. I use the proceedure in the Chilton's "Datsun 1961 to 1972" manual, ISBN0-8019-5790-7 if you want to try to order it from a book store. It's the best manual I have found as far a authentic repair proceedures and excellent wiring schematics. You also may have a bum starter relay. Quote Link to comment
datsunaholic Posted April 22, 2008 Report Share Posted April 22, 2008 The "offset" starters are usually NAPS-Z starters. I have a bunch of 'em. Quote Link to comment
ggzilla Posted April 23, 2008 Report Share Posted April 23, 2008 Bosch starters are good quality. Better than old Hitachis (2 brush). The Mitsubishes (4 brush) are also good. Quote Link to comment
JMVegas Posted April 24, 2008 Report Share Posted April 24, 2008 I vote keep the screw driver method. Quote Link to comment
MikeRL411 Posted April 26, 2008 Report Share Posted April 26, 2008 Sounds like a wiring issue. I would check that before you check anything. If the starter is not turning over when you turn the key to start, but it will when you jump it with a screwdriver, I would vote for a wiring issue. In regards to the rattling issue, I don't really know. I would say get the wiring good then see if you need a new starter. Sounds [no pun intended] like you have sheared off one of the legs on the shift fork that shoves the starter gear into contact with the flywheel teeth. The rattling sound is what's left of the broken fork being turned into chips. Quote Link to comment
datzenmike Posted April 26, 2008 Report Share Posted April 26, 2008 I vote keep the screw driver method. Always think of the worst case scenario. It's dark and you stall in the middle of an intersection or RR tracks. Ill try that tomorrow. The wiring on the car looks to be untouched/stock. Where is the shifter switch located? The inhibit switch is on the drivers side just back from the bell housing on the top end of the shifter lever where the shift rod joins it. It is a small harness with four wires two for reverse lights and two for the inhibit. The two Black/Yellow wires have to be connected by the switch in P or N. If either wire is off or broken it wont turn over. (the Red/Black wires are for the reverse lamps) Quote Link to comment
Pacific coast Datsun Posted April 26, 2008 Author Report Share Posted April 26, 2008 Thanks Mike. Ill get up under the car next week & find that switch now that i know where to look. Quote Link to comment
Pacific coast Datsun Posted May 27, 2008 Author Report Share Posted May 27, 2008 Ok found the switch & the wires going to it. I was told by a very reliable source that i can bypass the switch by removing one of the wires & connecting it to the "start" terminal on the back of the ignition switch. Question is..what wire [of the 2 blk & yellow wires] do i run up to the ig. switch ? Quote Link to comment
datzenmike Posted May 27, 2008 Report Share Posted May 27, 2008 Join the two Black/Yellow wires and it will start with the key IN ANY GEAR POSITION !!! This is the reason for the interlock to prevent starting in gear by accident. Please be careful. Quote Link to comment
Pacific coast Datsun Posted May 27, 2008 Author Report Share Posted May 27, 2008 TY Mike, i always make sure it's in park anyways + safety is very important to me ;) Quote Link to comment
datzenmike Posted May 27, 2008 Report Share Posted May 27, 2008 I know.:D I used to have an old early '60s Valliant and I disconnected the interlock. Kind of interesting to have it in drive and hit the starter and as soon as it fires up it's movin'. It had a push button automatic. On the left side of the dash were a row of vertical buttons like an old car radio, weird. Quote Link to comment
racerx Posted May 27, 2008 Report Share Posted May 27, 2008 Not sure if anyone said this but you can take the starter to auozone or Kragens and they can check... how old is that starter anyway? RacerX Quote Link to comment
Pacific coast Datsun Posted May 27, 2008 Author Report Share Posted May 27, 2008 Not sure how old the starter is but it works ok when i bridge the terminals. 1st ill bypass the N switch & see how it works. Quote Link to comment
