07FlyingWagon Posted November 10, 2013 Report Share Posted November 10, 2013 Lol I hear ya! I got mine off the stands and idled around the block and let it settle into the new tires - it sits super low in the back, tucking with a bit of negative camber lol but has quite a bit of gap up front - Hrmmm ;) I need to get some new pics up so you can see what I mean :) Quote Link to comment
Busta Nut Posted November 10, 2013 Author Report Share Posted November 10, 2013 Got a few things done yesterday morning..... -Lubed door locks with graphite powder -Readjusted my slave cylinder.....I must have the wrong sleeve in the tranny....I need a shorter one. -Installed steering spacers -Tuned carbs New Problems....... -Water Pump gasket is now leaking -Slave cylinder is leaking into the boot -Oil leak between engine and trans getting worse (rear main, oil pan, or that damn last bearing cap with those stupid seals in it??) Tuning the carbs made a huge difference in how it runs....I should've done it sooner.... ........no more hesitation between circuits and not nearly as much intake backfiring under very light throttle It was running waaaay rich....4.2%CO......no pics....camera battery was charging.. Now HC<300ppm, CO is @ 2.47%, & CO2 @ 13.2% It could probably use a bit more fine tuning but I'm happy for now. Quote Link to comment
Busta Nut Posted November 10, 2013 Author Report Share Posted November 10, 2013 Lol I hear ya! I got mine off the stands and idled around the block and let it settle into the new tires - it sits super low in the back, tucking with a bit of negative camber lol but has quite a bit of gap up front - Hrmmm ;) I need to get some new pics up so you can see what I mean :) I got an idea....What did you do to lower the rear?? Quote Link to comment
Busta Nut Posted November 10, 2013 Author Report Share Posted November 10, 2013 Oics from the spacer install..... 1 Quote Link to comment
Busta Nut Posted November 10, 2013 Author Report Share Posted November 10, 2013 Water pump gasket leak...... Quote Link to comment
Busta Nut Posted November 10, 2013 Author Report Share Posted November 10, 2013 Random engine bay shots from this morning........ Quote Link to comment
skyblue Posted November 11, 2013 Report Share Posted November 11, 2013 Oh man new problems. Ugh. Sucks. Bug at keast they're easy fixes, except gif the oil leak from the back of motor. Quote Link to comment
Ranman72 Posted November 11, 2013 Report Share Posted November 11, 2013 Thanks Marty........It's not terrible.... .....I just like being as low as practical :fu: :fu: :fu: ...... :D fixed I like it too but 1/2 lower in the front would look good Quote Link to comment
07FlyingWagon Posted November 11, 2013 Report Share Posted November 11, 2013 I got an idea....What did you do to lower the rear??I got it this way ;) according to the PO, it has Eibachs all the way around - front feels plenty stiff, but the back is soggy. I'm going to pull he out of the garage and take some decent pics later today instead of using my iPhone - ill pm you when I get them up in my build thread ;) What struts are you running now? *edited for "reading too many build threads and not recalling exact details before asking question" syndrome lol Quote Link to comment
Busta Nut Posted November 11, 2013 Author Report Share Posted November 11, 2013 Up front it's a Tokico Blue insert......the oldschool ones you can't get anymore.... ......ground-control coil over and eibach spring obviously..... I haven't changed the rear suspension....this is the way I bought it.....spring is cut with an air shock installed......they work for now.... .....it's nice being able to raise and lower the car in the rear also..... ......I want rear coilovers though ......all in due time. Quote Link to comment
terolla Posted November 11, 2013 Report Share Posted November 11, 2013 didn't see if you mentioned it, but what brand of filter screens are you using on the carbs? Quote Link to comment
Busta Nut Posted November 11, 2013 Author Report Share Posted November 11, 2013 didn't see if you mentioned it, but what brand of filter screens are you using on the carbs? I gottem at Pierce Manifolds in Gilroy,CA http://www.piercemanifolds.com/product_p/99217.225.htm Seems the price has gone up since I bought mine.....I don't think I paid $50/pair.....I wanna say it was more like $35-$40.... Quote Link to comment
Busta Nut Posted November 11, 2013 Author Report Share Posted November 11, 2013 Since putting on the spacers.......I now have a heavy rotational knocking sound during hard right turns..... .....TBA..... Quote Link to comment
Eagle_Adam Posted November 11, 2013 Report Share Posted November 11, 2013 lookn good man!!!! Quote Link to comment
r0p0doe Posted November 11, 2013 Report Share Posted November 11, 2013 Got a few things done yesterday morning..... -Lubed door locks with graphite powder -Readjusted my slave cylinder.....I must have the wrong sleeve in the tranny....I need a shorter one. -Installed steering spacers -Tuned carbs New Problems....... -Water Pump gasket is now leaking -Slave cylinder is leaking into the boot -Oil leak between engine and trans getting worse (rear main, oil pan, or that damn last bearing cap with those stupid seals in it??) Tuning the carbs made a huge difference in how it runs....I should've done it sooner.... ........no more hesitation between circuits and not nearly as much intake backfiring under very light throttle It was running waaaay rich....4.2%CO......no pics....camera battery was charging.. Now HC<300ppm, CO is @ 2.47%, & CO2 @ 13.2% It could probably use a bit more fine tuning but I'm happy for now. Ouch whats the story behind that fender dent? I dont remember it being there.... Quote Link to comment
Busta Nut Posted November 11, 2013 Author Report Share Posted November 11, 2013 Ouch whats the story behind that fender dent? I dont remember it being there.... It's always been there....I usually take the shots to hide it.....or take'em from the other side.....I have the brow that matches..Haha... All the dents, holes, blemishes, rust were there when I bought it..... Quote Link to comment
510T Posted November 11, 2013 Report Share Posted November 11, 2013 Since putting on the spacers.......I now have a heavy rotational knocking sound during hard right turns..... .....TBA..... Tie rod to wheel weight interference? I had a problem once like that, only at full lock. Was on my S12 struts with my 8" +15 wheel setup and 1.25" spacers. Quote Link to comment
Busta Nut Posted November 11, 2013 Author Report Share Posted November 11, 2013 Ya......it sounds like that.... Quote Link to comment
Busta Nut Posted November 12, 2013 Author Report Share Posted November 12, 2013 Moh paaat to feex caa..... Quote Link to comment
Busta Nut Posted November 12, 2013 Author Report Share Posted November 12, 2013 Bababooey was correct.... .....low pro weight installed. Quote Link to comment
Busta Nut Posted November 12, 2013 Author Report Share Posted November 12, 2013 More pics of problems making a mess of my cleanliness...... Quote Link to comment
Busta Nut Posted November 13, 2013 Author Report Share Posted November 13, 2013 One other thing that needs attention........idler arm bushings They're pretty wasted......just ordered the EE poly replacements...... .......almost 2 weeks to deliver.....dayam.........oh well ......one more thing.... Yesterday morning it drizzled a little and reminded me I need to install wipers and the motor...... ...I remember them moving very slow back in the day...... Is there anything I can do to the motor to rejuvenate it :confused: Haven't dug it out yet, but I was planning on taking it apart and cleaning it out hoping that would do something..... Quote Link to comment
the510keeper Posted November 13, 2013 Report Share Posted November 13, 2013 replace that old wiper motor with a mazda 626 wiper motor, ez mod and speeds things up 1 Quote Link to comment
Busta Nut Posted November 14, 2013 Author Report Share Posted November 14, 2013 replace that old wiper motor with a mazda 626 wiper motor, ez mod and speeds things up what year?? Quote Link to comment
tr8er Posted November 14, 2013 Report Share Posted November 14, 2013 http://community.ratsun.net/topic/16102-mazda-wiper-motor-upgrade-on-510/ you are welcome get an 84-88 if you are too lazy to read it. This is not personally verified. Quote Link to comment
