Busta Nut Posted August 9, 2013 Author Report Share Posted August 9, 2013 Been keeping an eye on this..... awfully close.....it shaved a bit of the clamp away.... figured out why my belt came loose also......alt. bracket is cracked/broken....oics to come. Quote Link to comment
Busta Nut Posted August 11, 2013 Author Report Share Posted August 11, 2013 So..... On the way home from San Leandro yesterday my clutch started slipping..... I thought it was strange that it engaged almost all the way at the top....I thought I had the correct sleeve for the trans in there but now I'm having doubts... Parts: -Stage 2 Centerforce clutch - 78-81 z trans? I think -sleeve for said trans -Stock flywheel -Stock slave & clutch master ...any thoughts?? Quote Link to comment
Busta Nut Posted August 11, 2013 Author Report Share Posted August 11, 2013 Pic of my broken alt. bracket...... ....wonder how long it's gonna last like that :unsure: Quote Link to comment
LenRobertson Posted August 11, 2013 Report Share Posted August 11, 2013 So..... On the way home from San Leandro yesterday my clutch started slipping..... I thought it was strange that it engaged almost all the way at the top....I thought I had the correct sleeve for the trans in there but now I'm having doubts... Parts: -Stage 2 Centerforce clutch - 78-81 z trans? I think -sleeve for said trans -Stock flywheel -Stock slave & clutch master ...any thoughts?? The TO sleeve must match the clutch pressure plate, not the tranny. I'm not absolutely sure, but I suppose when you get a Centerforce clutch, the PP height is the same as the stock clutch you are replacing. So unless you got really lucky and the Z tranny sleeve is the same length as the one for your stock clutch, then you probably have the wrong length sleeve. If you need it, I have a link to a chart of PP heights and sleeve lengths. But I'm guessing you need the sleeve from your stock 4-speed. Maybe someone who knows about Centerforce clutches will post better information. Len Quote Link to comment
rusty12ver Posted August 12, 2013 Report Share Posted August 12, 2013 What pp, did you order from Centerforce? 200sx? (l20b?) If the trans has the zx tbc, I think it's too long. I think the fork also has to match. My set up was 200 sx clutch set, 510 fork, with tbc that measured in the "middle" meaning not the 510 collar or the long zx collar, I think I ordered the collar for a 610 from the dealer. I think on eBay there is a luc clutch for a 200sx, with matching tbc. That one is a good clutch and can hold the torque of a decent built l20b. Here ya go :ebay Item #: 221094270164 Quote Link to comment
Busta Nut Posted August 12, 2013 Author Report Share Posted August 12, 2013 Thanks guys....I may have the wrong sleeve..... If you need it, I have a link to a chart of PP heights and sleeve lengths. But I'm guessing you need the sleeve from your stock 4-speed.Len That link would be great!! I ordered a clutch for an L16.... I had a floor shift auto in it before...... Quote Link to comment
LenRobertson Posted August 12, 2013 Report Share Posted August 12, 2013 Here are the links for TO bearing sleeve and PP heights: http://datsun510.com/photopost/showphoto.php?photo=6979&title=datsun-pressure-plate-comparison&cat=3129 http://datsun510.com/photopost/showphoto.php?photo=6981&title=200mm-clutch-t-2fo-bearing-sleeve-specs&cat=3129 http://datsun510.com/photopost/showphoto.php?photo=6980&title=225mm-and-240mm-clutch-t-2fo-bearing-sleeve-specs&cat=3129 I imagine you can study these pages and figure out if you need a different TO sleeve. I believe someone posted that they were able to get a new sleeve from Nissan, so if you need a different one, that may be quicker than trying to find a used one. Len Quote Link to comment
Busta Nut Posted August 12, 2013 Author Report Share Posted August 12, 2013 ^Thx! Quote Link to comment
Eagle_Adam Posted August 12, 2013 Report Share Posted August 12, 2013 you need an alt bracket? Quote Link to comment
Busta Nut Posted August 12, 2013 Author Report Share Posted August 12, 2013 you need an alt bracket? Don't think so... I have the one from the Z.....and Skyblue has a spare he said he'd give me... .....might even attempt to see what my welding skillz are like... :lol: I appreciate the offer though.. Quote Link to comment
Busta Nut Posted August 13, 2013 Author Report Share Posted August 13, 2013 Update on a couple issues.... Gas cap wasn't tight enough I guess.....I tighten the shit out of it now and no spillage. :) Adjusted clutch again and it seems to be a little better.....it just doesn't feel right to me though... ......that'll have to wait till I pull the trans.....good enough for now. Oics of 5Teezy at the Car Show in San Leandro........lucked out on the prime spot! 1 Quote Link to comment
the510keeper Posted August 14, 2013 Report Share Posted August 14, 2013 Damn missed that show Quote Link to comment
Busta Nut Posted August 23, 2013 Author Report Share Posted August 23, 2013 Small update.... Gas door kept flying open on hard left turns.... Every once in a while I'd get out and find it open......pretty annoying....and a little ghetto... ....found a small magnet.... ..........problem averted till further date.... I'll be gearing up for the Fairfax Car show coming soon...... .....stay tuned.... Quote Link to comment
Busta Nut Posted August 23, 2013 Author Report Share Posted August 23, 2013 Got my reg card the other day... Quote Link to comment
Busta Nut Posted September 3, 2013 Author Report Share Posted September 3, 2013 So Skyblue hooked me up with the vents he didn't want to put on Doty because a little fabrication was gonna be necessary.... .....me.....I don't give a :poop: ......my car is far from stock or O.G. ...on with the oics.... Quote Link to comment
Busta Nut Posted September 3, 2013 Author Report Share Posted September 3, 2013 One is missing the edge.... Quote Link to comment
Busta Nut Posted September 3, 2013 Author Report Share Posted September 3, 2013 Quick clean up in the solvent tank.... Quote Link to comment
Busta Nut Posted September 3, 2013 Author Report Share Posted September 3, 2013 Dug up the bottom trim pieces.... One is near flawless.....the other has a few tweeks but nothing serious..... Still gots all da clips also.. :thumbup: Quote Link to comment
Eagle_Adam Posted September 3, 2013 Report Share Posted September 3, 2013 mmmmmmmm, trim!!!! Quote Link to comment
Busta Nut Posted September 4, 2013 Author Report Share Posted September 4, 2013 ^^Yes...lots of it!! Got one last shot before my memory card filled up with a video of Doty.... Quote Link to comment
Busta Nut Posted September 6, 2013 Author Report Share Posted September 6, 2013 Almost ready for install.... Quote Link to comment
Busta Nut Posted September 6, 2013 Author Report Share Posted September 6, 2013 Marked up where the holes need to be.... One out of three line up.... Quote Link to comment
Busta Nut Posted September 6, 2013 Author Report Share Posted September 6, 2013 Holes drilled and filed..... Quote Link to comment
Busta Nut Posted September 6, 2013 Author Report Share Posted September 6, 2013 So much better than mint...... B) Just a test fit too.... I wanna repaint the blck & hit'em up with some polish tonight or tomorrow for the show..... Thx Skyblue!! Quote Link to comment
Busta Nut Posted September 6, 2013 Author Report Share Posted September 6, 2013 Hoping this gets done before Sunday also...but I'm not holding my breath... Looks like a shop day Saturday w/the childrens... Remove all the paint from the door trim..... Got almost halfway through one side before I had to start work this morning..... Hopefully the rest of the day mellows out.... Quote Link to comment
