I scored a 510 wagon !!!
  • Replies 503
  • 1 month later...
Update time. Replaced the PS outer wheel bearing recently & replaced the fuel pump gasket + cleaned up the oil that leaked all over the block & firewall...:mad: Then made a quicky center console. The top will be hinged & I'll carpet it next week...& oh yeah now my coffee wont tip over :D
Ok getting ready to slap on a different set of rims this week [ 5 sets to choose from:D]. Gonna run the fake centerlines [13 x 5] i got from Mario [71 dimer]. Did a really quick wet sand job so they dont look too dingy...P1010001.jpg
also did a quicky clean up & paint job on the caps... before...
sanded...
& painted...
how they look. I know a bit different but its better than rust...
Hoping i can use the same lugs that are on the Libres...;)
TY guys. It rides much better & no more Mr T effect as i drive [weaving on the freeway & excessive steering wheel movement :lol:] Been pricing new tires & my next set will prob. be some 185-60-14's for my Z 6 spokes. I can get all 4 NEW mounted & balanced for $160 :D
Ok Mr t effect is deff. gona & TY mario for the catch phrase :D Picked up a Grant wheel from Robert [dat521kid] & put it on after cleaning it up...
before..
& after. I took a small sanding disc on my drill & made a series of swirls then cleared it. The allens are green, of course ;).
TY Robert, it cleaned up nice. & I test fit 1 of the ZX 6 spokes the other day...cant wait to get tires for them...
Ok decided to go with a used set of 185-60-14's on the ZX rims. Tread is ok & should last awhile....
no rubbing issues...
This is the lugs i used w/ a washer ... Thread is 12 x 1.25......
this is the lugs i use on the Libres & solid rims...
& this is the factory alloy lugs i wanted to use. Strangely enough only a few fit down into the ZX rim lug pockets :unsure:
Will test drive it later to make sure i get no wheel wobble.
Thanks guys. Drove it around a bit w/ no wobbles or shakes. In a few days ill re-tighten the lugs if needed.
Benzo- id hold on to your ZX's..with a bit of wet sanding & polishing anything is possible.
Motivated- yeah the cup holder rocks & is very low tech..holds my coffee perfect :cool:
