Topher88 Posted July 31, 2012 Author Report Share Posted July 31, 2012 little update Got the 240sx rear brakes on 9now i need to make some custom lines) welded up the strut towers front and back pretty sure this is where the adjustable proportioning valve is going to go back seat is gone Most of the holes are shaved and bay is stitch welded and primer should be going on tomorrow then paint shortly after Quote Link to comment
INDY510 Posted July 31, 2012 Report Share Posted July 31, 2012 . SO epic!!! .... :cool: 1 Quote Link to comment
Josh K. Posted July 31, 2012 Report Share Posted July 31, 2012 It's coming along I see your going Z32 Blow through MAF. I ran the same setup on my SR successfully. Only downside is after a few months she's starts running rich and you need to clean the MAF wire due to oil from the turbo. Kind of a PITA but worth it to not have a Recirculating BOV and also the air is much smoother. The Z32 MAF is one finicky bitch!! Another issue is the hoses blowing off due to the slickness of the plastic. I scored mine in a criss cross pattern with a razor knife. I think I also used hair spray. I was running 18psi daily. Just a heads up. -Josh 1 Quote Link to comment
Topher88 Posted July 31, 2012 Author Report Share Posted July 31, 2012 I see your going Z32 Blow through MAF. I ran the same setup on my SR successfully. Only downside is after a few months she's starts running rich and you need to clean the MAF wire due to oil from the turbo. Kind of a PITA but worth it to not have a Recirculating BOV and also the air is much smoother. The Z32 MAF is one finicky bitch!! Another issue is the hoses blowing off due to the slickness of the plastic. I scored mine in a criss cross pattern with a razor knife. I think I also used hair spray. I was running 18psi daily. Just a heads up. -Josh good to know man. thanks for the heads up. a few of my buddys are running the same set up. id like to in the future run a stand alone so i dont need the maf Quote Link to comment
Topher88 Posted August 4, 2012 Author Report Share Posted August 4, 2012 Got my wheels back :) Quote Link to comment
SSS510 Posted August 4, 2012 Report Share Posted August 4, 2012 Got my wheels back :) They Look SICK! Quote Link to comment
Topher88 Posted August 4, 2012 Author Report Share Posted August 4, 2012 Welded in some spacers for the rad so it will be nice and stout when installed and makes life easy Quote Link to comment
Topher88 Posted August 6, 2012 Author Report Share Posted August 6, 2012 how did you SR guys run your catch cans? Quote Link to comment
Topher88 Posted August 10, 2012 Author Report Share Posted August 10, 2012 It's getting there! 1 Quote Link to comment
Jester Posted August 10, 2012 Report Share Posted August 10, 2012 This car is looking really good. Keep it up man! Quote Link to comment
dennis Posted August 10, 2012 Report Share Posted August 10, 2012 how did you SR guys run your catch cans? I am running mine on the tray above the BMC. Make sure you go with a vented can or modify a Geddy type can to vent with a npt motorcycle breather. I would show you mine but it is on my bench with a tap into into it. http://www.ebay.com/itm/Oil-Catch-Can-Honda-Nissan-Mitsubishi-Toyota-Subaru-Chevy-Ford-Chrysler-BMW-VW-/400314481927?pt=Motors_Car_Truck_Parts_Accessories&hash=item5d349a3d07&vxp=mtr I have a couple of those cans. I am going to lay it flat, then swap the visual tube with the lower barb so it can give you an accurate reading if it is laying on its side. Then with the top fitting I will tap it for a 1/4" npt and run a motorcycle breather in it. it will be similar to Kevins 510 Quote Link to comment
sedition88 Posted August 10, 2012 Report Share Posted August 10, 2012 This is going to be badass. Lots of good work so far. Motivation to get going on my dime Quote Link to comment
Topher88 Posted August 10, 2012 Author Report Share Posted August 10, 2012 Thanks fit the information Dennis. I have a greddy catch can with a small filter coming off it but the previous owner said it would spit oil out. It's set up just like the one above so I think I'm going to run it that same way but put a larger filter on it. And I don't have time to search right now but what's a motorcycle breather do? Quote Link to comment
dennis Posted August 10, 2012 Report Share Posted August 10, 2012 Thanks fit the information Dennis. I have a greddy catch can with a small filter coming off it but the previous owner said it would spit oil out. It's set up just like the one above so I think I'm going to run it that same way but put a larger filter on it. And I don't have time to search right now but what's a motorcycle breather do? The SR oil catch system was designed to breath, reducing pressure in the valve cover. The catch can will fill up with oil but you have to drain it when it fills up, this is why you can see a sight tube to monitor the levels. The S13 is notorious for dumping a lot of oil into catch cans, this is due to a poorly designed valve cover baffle. This problem was corrected with the S14/15 with improved baffling. You can also buy modified S13/14 Hybrid valve covers from Togue Factory. Quote Link to comment
Topher88 Posted August 11, 2012 Author Report Share Posted August 11, 2012 Good to know thank you sir. I'll probably just modifi my current greddy catch can and put one of those breathers. Ps my white I chose Quote Link to comment
Topher88 Posted August 14, 2012 Author Report Share Posted August 14, 2012 i like this pic and my other baby Quote Link to comment
DAT510 Posted August 14, 2012 Report Share Posted August 14, 2012 i like this pic and my other baby I hate you I hate you I hate you I hate you I hate you I hate you I hate you I hate you I hate you I hate you I hate you I hate you I hate you 2 Quote Link to comment
dennis Posted August 14, 2012 Report Share Posted August 14, 2012 i like this pic and my other baby I had a real 70 454SS, I sold it in 2000 for 6,000 because I was moving. One of the biggest mistakes of my life, it was in good shape and I probably could have sold it now for 20k. Quote Link to comment
sedition88 Posted August 15, 2012 Report Share Posted August 15, 2012 Nice! Keep it up JCCS is drawing near :thumbup: Quote Link to comment
ATP Posted August 15, 2012 Report Share Posted August 15, 2012 i like this pic and my other baby Thats a clean looking 72 chevelle! what are you running for power? I've have a 64 project I've been keeping around for years that I WILL build, just always gets put on the back burner. :blush: Andrew Quote Link to comment
Topher88 Posted August 15, 2012 Author Report Share Posted August 15, 2012 Nice! Keep it up JCCS is drawing near :thumbup: It won't be running by then but since I already registered I'll be towing it like a boss 1 Quote Link to comment
jrock4224 Posted August 16, 2012 Report Share Posted August 16, 2012 nice 72..... Quote Link to comment
Topher88 Posted August 20, 2012 Author Report Share Posted August 20, 2012 I wanted to brake up the white a little and try and blend the crossmember and other black goodies on the bottom of the car. Quote Link to comment
Topher88 Posted August 23, 2012 Author Report Share Posted August 23, 2012 SHHITTTYYY day... Not only will my car Not be running for JCCS BUT! I have to work up north on that weekend. The one damn weekend I have to work is that weekend.... FML Quote Link to comment
