blueridgespeed Posted January 28, 2011 Report Share Posted January 28, 2011 mmmm, yummy. Who makes the Brembo kit? (is it a 510 application?) Quote Link to comment
Cmac Posted January 29, 2011 Author Report Share Posted January 29, 2011 Mario Lozano TSR - Toespeed racing 310-323-6553 work number The Brembo brake kit is for a 510 most of the guys running them are using 280zx struts one is using 510 struts. You can either get 16 inch rim kit or a 17 inch kit. the option on the rear as I stated above can have a willwood parking brake or a brembo unit. You can also see his parts on facebook at Datsunboys socal Quote Link to comment
Cmac Posted May 20, 2011 Author Report Share Posted May 20, 2011 A couple of new bits showed up in the mail the other day. JRZ - RS rear coil overs Hyperco rear coils and TSR top pillow ball mounts to eliminate the possibility of the shaft from bending under load. Mario has been working with JRZ USA now for just shy of a year to design an set of shocks for the 510. He also has a front set that will be released shortly. I have now tried out the Carrera and the Troy Ermish rear coil overs on this car and both have handled well and road nice. I am looking forward to seeing the difference as soon as the new axels show up for the 930cv conversion show up. Quote Link to comment
WAGON JON Posted May 20, 2011 Report Share Posted May 20, 2011 Looks great! I want some. Quote Link to comment
the510keeper Posted May 20, 2011 Report Share Posted May 20, 2011 Someone needs to blow Corey, cause his car is sweet Quote Link to comment
SR20DETdatsun510 Posted June 6, 2011 Report Share Posted June 6, 2011 Hey, how do you like the rear coils? I am in the market for them. How much they set you back? You got Marios number? I need several things from him...... PM me if you need to...... Quote Link to comment
SR20DETdatsun510 Posted June 11, 2011 Report Share Posted June 11, 2011 Intercooler piping What kind of Clamps are those? Diameter? What prep to the piping do you have to do to use those? Quote Link to comment
Dirttrack510 Posted June 11, 2011 Report Share Posted June 11, 2011 No offense everyone, but this is the prettiest 510 I think I've ever seen. :wub: I LOVE IT!!! Another addition to my screen saver. Quote Link to comment
Cmac Posted June 11, 2011 Author Report Share Posted June 11, 2011 Thanks ! The clamps are wiggins clamps there is also another company called pro-flo. For install you have to weld a oring flange to the piping. In this case the flange is 3 inch and the flange is welded to the throttle body and the intercooler piping. The wiggins clamp uses a clam shell cover over a brass ring sealing against o rings. There are some on ebay right now that have the flanges that slip over the 3 inch pipe which makes for a cleaner application. Quote Link to comment
SSS510 Posted June 12, 2011 Report Share Posted June 12, 2011 Someone needs to blow Corey, cause his car is sweet You can doit James!! :rofl: :lol: Quote Link to comment
jefe de jefes Posted June 12, 2011 Report Share Posted June 12, 2011 Fap? Nice car! Quote Link to comment
nckzck Posted July 5, 2011 Report Share Posted July 5, 2011 Is the engine crossmember and the tranny mount TSR pieces also? Man.....that is a beautiful car! Quote Link to comment
Cmac Posted July 6, 2011 Author Report Share Posted July 6, 2011 Is the engine crossmember and the tranny mount TSR pieces also? Man.....that is a beautiful car! Yes the engine crossmember is a 1968 that has been flipped and plated for reinforcement by TSR. The transmission crossmember is for a 6 speed and rear differential is for the R200 both made by TSR as well. All items bolted right in without issue. Quote Link to comment
banzai510(hainz) Posted July 6, 2011 Report Share Posted July 6, 2011 this car is too HOT for Ratsun. Badass!!!!!!!!!! Quote Link to comment
Wisk Posted April 4, 2012 Report Share Posted April 4, 2012 A couple of new bits showed up in the mail the other day. JRZ - RS rear coil overs Hyperco rear coils and TSR top pillow ball mounts to eliminate the possibility of the shaft from bending under load. Mario has been working with JRZ USA now for just shy of a year to design an set of shocks for the 510. He also has a front set that will be released shortly. I have now tried out the Carrera and the Troy Ermish rear coil overs on this car and both have handled well and road nice. I am looking forward to seeing the difference as soon as the new axels show up for the 930cv conversion show up. Did you get the fronts also from JRZ? Quote Link to comment
Wisk Posted April 4, 2012 Report Share Posted April 4, 2012 I ask because I ordered a set. Quote Link to comment
Wisk Posted April 4, 2012 Report Share Posted April 4, 2012 Absolulty beautiful!!!!! I love this car. Quote Link to comment
Wisk Posted April 4, 2012 Report Share Posted April 4, 2012 Your front coilovers JRZ? Quote Link to comment
Cmac Posted July 6, 2012 Author Report Share Posted July 6, 2012 Full Race Twin Scroll does in fact fit but it is tight. Gtx3071, Titanium hi heat coating on the housing and manifold is supposed to be good to 2000deg. 60 deg down pipe off turbo. 45 deg 4 inch intake pipe with flange made to work with Apexi filter. Quote Link to comment
Z chopper Posted July 6, 2012 Report Share Posted July 6, 2012 friggin sweet build Quote Link to comment
charlie mac Posted August 12, 2012 Report Share Posted August 12, 2012 dude amzing build ........... :thumbup: Quote Link to comment
Cmac Posted August 12, 2012 Author Report Share Posted August 12, 2012 This showed up in the mail on friday - TSR wire retainer 930 CV sway away axels finally installed Finished the turbo upgrade except one 4an line I have to wait to get on monday. 1 Quote Link to comment
Rawlo Posted August 13, 2012 Report Share Posted August 13, 2012 i love this i will most def give this mario a call for some parts for my dime sr Quote Link to comment
