Cmac Posted February 8, 2014 Author Report Share Posted February 8, 2014 Mazda MX6 fuel filler mod photos. Not sure if I had posted this on this build thread and was asked on another. Flaw - breather tube should not be bent down not allowing fumes to escape. 1/4 inch rubber gasket to seal body to pipe. Rubber connector / transition in also from MX6 and fits stock tank. 1 Quote Link to comment
Cmac Posted February 8, 2014 Author Report Share Posted February 8, 2014 LSD Update S14 stub axles C clip notch is to be installed on the Stub axle TSR 930 stub Axles not C lip notch is for clip to be installed in the Differential Differential rebuilt by http://www.differentials.com/ Os giken super lock Bolts required to install ring gear 12mm bolts OS giken uses a 13mm hole note shoulder. 1 Quote Link to comment
Cmac Posted February 8, 2014 Author Report Share Posted February 8, 2014 Damage caused by rocker arm keeper sticking to rod bolt and hitting the bottom of cylinder. Busted the bottom of # 4 piston. Block has been maganafluxed checks out and is currently at the machine shop waiting its turn in line. Quote Link to comment
Cmac Posted February 8, 2014 Author Report Share Posted February 8, 2014 Oil breather on the 510 is plastic not so good for a turbo application. Right is one taken from a later model Nissan steering box - no longer available from the dealer or at least was not when I checked 6 months ago. 1 Quote Link to comment
SR20DETdatsun510 Posted May 24, 2018 Report Share Posted May 24, 2018 Mr. C-Mac! Maybe these forums can be useful again? I can see all of your pics again. :thumbup: Giggity Oh, and I can use "Giggity" again. Hahaha 1 Quote Link to comment
Cmac Posted September 5, 2020 Author Report Share Posted September 5, 2020 (edited) 17 year old son wanting to know if I wash it can I drive it. Edited June 6, 2022 by Cmac Quote Link to comment
Cmac Posted September 5, 2020 Author Report Share Posted September 5, 2020 Well one good thing about covid is all family activities stopped allowing me to mess with the car on and off for a couple months. Quote Link to comment
Cmac Posted September 11, 2020 Author Report Share Posted September 11, 2020 James Boswell version 3 rack. Standard 2.9 ratio custom arms to tuck 17”x 7.5 rims. 2 Quote Link to comment
Draker Posted September 11, 2020 Report Share Posted September 11, 2020 So clean! Nice work on this build! Quote Link to comment
