Laecaon Posted August 28, 2012 Report Share Posted August 28, 2012 There is a oil plug... for a hole that runs front to back in the block... but its driver side. Quote Link to comment
metalmonkey47 Posted August 28, 2012 Report Share Posted August 28, 2012 That blue looks fantastic! Quote Link to comment
ptown green Posted August 28, 2012 Author Report Share Posted August 28, 2012 There is a oil plug... for a hole that runs front to back in the block... but its driver side. That might be it then. I dont really remember the oil plug. I had a fel pro gasket and seal kit that I used so if it wasnt in there I may have missed it. The oil pressure may have just pushed it out on the passenger side if thare was a little openeing. I guess Im pulling the tranny and clutch out tomorrow! Quote Link to comment
ptown green Posted August 28, 2012 Author Report Share Posted August 28, 2012 That blue looks fantastic! Thanks man! obviously not high quality pictures. They're will be better ones whenever I get this thing driving haha Quote Link to comment
ptown green Posted August 28, 2012 Author Report Share Posted August 28, 2012 Check out What I did to my dash pad! Wood grain! I also have a wood Z steering wheel I'l be using instead of the one in these pics Some new gauges down in the left too Quote Link to comment
78kingcab Posted August 29, 2012 Report Share Posted August 29, 2012 wow its really come far...looks great man....dash is one of a kind awsome.....cant wait for this one to be done.... Quote Link to comment
ptown green Posted August 29, 2012 Author Report Share Posted August 29, 2012 So it looks like I found where the oil is coming from. I didn't plug that hole in the pic on the right. So this whole goes all the way through huh? That means I probably didnt pug the other side either! What size plugs are those? Are they like the freeze plugs or are they solid? If I dont plug the front one will my oil pressure not be right? Quote Link to comment
ptown green Posted August 29, 2012 Author Report Share Posted August 29, 2012 Thank you man! It won't be too long Quote Link to comment
Laecaon Posted August 29, 2012 Report Share Posted August 29, 2012 How to build your datsun engine book said to just tap and use a threaded plug. You dont need to remove those plugs, like ever, but it does help when the block gets hot tanked. There is a front one under the timing cover. I do believe it goes all the way through. I would plug it, as that is how it left the factory. Quote Link to comment
Spoona_Jay21 Posted August 29, 2012 Report Share Posted August 29, 2012 dude, looks good! can't wait too see it done. Quote Link to comment
ptown green Posted September 9, 2012 Author Report Share Posted September 9, 2012 well shit. I forgot about the one little bolt behind the oil pump and was just wiggling it off and it fuckin cracked. So I need a timing cover. Anyone have one? Preferably one that belongs on an l18? I have someone else I can get one from but I cant talk to him until at least tuesday. The sooner the better. Quote Link to comment
ptown green Posted September 17, 2012 Author Report Share Posted September 17, 2012 K well I got a timing cover. Got both oil holes plugged and was making 60 psi for oil pressure. I was breaking in the engine and noticeing the exhaust was a little more smokey then I'm used to but I was just letting it burn off. Then I notice the rpms falling and the enging bogging down so I shut it off. Then it wouldn't fucking turn over! I couldn't do it manually by the crank bolt either. It was seized up!!! So today I tore it all apart and The thrust bearing was turned. Looked like it wasn't getting any oil. All black under it with chunks of bearing material baked to the crank. There was also way too much oil in the cylenders. Too much for even breaking in the rings. So Im pretty sure I know what happened. I don't think the pilot bushing is far enough in which is pushing the crank forward in the block and seizing up against the thrust bearing, turning it, blocking the oiler hole and also keeping the riings from seating due to the crank not being able to float at all. So once again with this cursed car, FMMFL. Anyway, when you install your pilot bushing do you knock it in all the way in or leave it flush? Quote Link to comment
ptown green Posted September 17, 2012 Author Report Share Posted September 17, 2012 pilot bushing. all the way in the crank, or flush with front of crank? Quote Link to comment
darrel Posted December 13, 2012 Report Share Posted December 13, 2012 When you plugged the two holes in the block, how long were the plugs? Quote Link to comment
banzai510(hainz) Posted December 13, 2012 Report Share Posted December 13, 2012 Looked like it wasn't getting any oil.?????????? you prime the oil pump???????????????before start up Quote Link to comment
ptown green Posted December 13, 2012 Author Report Share Posted December 13, 2012 Darrel- the plugs that go in the front and rear of the block looked like freeze plugs. So not very long. They just hammered in. Hainz- yeah it definitely looked that way. The oil pump was primed. Almost looked like the bearing was upside down. Really beats me. I still haven't figured out what caused it. Quote Link to comment
ptown green Posted December 13, 2012 Author Report Share Posted December 13, 2012 This thing is due for an update! So the crank got redone and the block was ranked again and all checked out. The engine is now assembled and in the car and runs awesome! No problems yet. I'll get some pics of all of the stuff I've been doing pretty soon. Quote Link to comment
BlkSSnCPT Posted December 13, 2012 Report Share Posted December 13, 2012 Got my LED dash lights! Should be pretty cool and some LEDs for the brake lights/turn signals ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- i haven't popped open my gauges to check but are the lights just the kind to pop off and replaceable with the LED's??? -Rob Quote Link to comment
ptown green Posted December 13, 2012 Author Report Share Posted December 13, 2012 Yep the black piece that they plug into unscrews from the back of what you see in the pic and you just put them in Quote Link to comment
BlkSSnCPT Posted December 13, 2012 Report Share Posted December 13, 2012 Yep the black piece that they plug into unscrews from the back of what you see in the pic and you just put them in nice, what size/number LED's are they??? for the gauges... -Rob Quote Link to comment
Project Bandwagon Posted December 13, 2012 Report Share Posted December 13, 2012 all that and no assembled pics!??!?!? :D let's see this thing man! Quote Link to comment
ptown green Posted December 13, 2012 Author Report Share Posted December 13, 2012 nice, what size/number LED's are they??? for the gauges... -Rob I don't remember but I found it somewhere on ratsun Quote Link to comment
ptown green Posted December 14, 2012 Author Report Share Posted December 14, 2012 So I got my grill and trim pieces I had powder coated and headlights all put on Powder coated tail light trim Black pillar vents VDO tach in dash Passenger seat in and testing out the center console. Still more to cut off to get it to fit right Engine bay pic. Working on the wiring. It'll all get cleaned up Quote Link to comment
screamer510 Posted December 14, 2012 Report Share Posted December 14, 2012 Just read the whole thread. Nice work and good job sticking with it. Sucks about the engine Quote Link to comment
ptown green Posted February 5, 2013 Author Report Share Posted February 5, 2013 Its getting close to being finished. I took it for its first drive last weekend which was really super exciting for me. Just gotta get the rest of the wiring done and dial in the timing and carb and whatever comes up in order to make it reliable. My distributor vacuum advance on my L18 is bad and its not available. Anyone have one for me or know where I can get one? 1 Quote Link to comment
