ptown green Posted September 17, 2011 Author Report Share Posted September 17, 2011 Did you flip the K member? Also did you get the taowers line bored?< this is a biggy after a total dismantle the what? I didnt actually take the transmission apart I just bought in a working order Quote Link to comment
Guest 510kamikazifreak Posted September 17, 2011 Report Share Posted September 17, 2011 the what? I didnt actually take the transmission apart I just bought in a working order cross member(K member) :lol: Quote Link to comment
ptown green Posted September 17, 2011 Author Report Share Posted September 17, 2011 cross member(K member) :lol: haha no Im reffering to this -> "Also did you get the taowers line bored?< this is a biggy after a total dismantle" Quote Link to comment
Guest 510kamikazifreak Posted September 17, 2011 Report Share Posted September 17, 2011 haha no Im reffering to this -> "Also did you get the taowers line bored?< this is a biggy after a total dismantle" ollz.. :lol: the Cam towers were they line bored before you reassembled it? They have to be line bored if towers taken off. kills bearings if not :blink: Quote Link to comment
ptown green Posted September 17, 2011 Author Report Share Posted September 17, 2011 But yeah I tried it with the cross member both ways and the bolts are off. If I put a spacer in there to level out the driveline will the bolts line up? Idk how much of a spacer to use though Quote Link to comment
ptown green Posted September 17, 2011 Author Report Share Posted September 17, 2011 ollz.. :lol: the Cam towers were they line bored before you reassembled it? They have to be line bored if towers taken off. kills bearings if not :blink: OH, that wasnt related to the tanny! no but I had them checked because I was gonna just have them honed but they turned out fine Quote Link to comment
Guest 510kamikazifreak Posted September 17, 2011 Report Share Posted September 17, 2011 OH, that wasnt related to the tanny! no but I had them checked because I was gonna just have them honed but they turned out fine :lol: how did they turn out fine :unsure: Quote Link to comment
ptown green Posted September 17, 2011 Author Report Share Posted September 17, 2011 :lol: how did they turn out fine :unsure: The cam towers are fine Quote Link to comment
Guest 510kamikazifreak Posted September 17, 2011 Report Share Posted September 17, 2011 The cam towers are fine :cool: now back to that "tranny" did you flip the K member? Quote Link to comment
ptown green Posted September 17, 2011 Author Report Share Posted September 17, 2011 :cool: now back to that "tranny" did you flip the K member? Yeah I tried to flip it and the bolt holes were still off. Maybe it just needs to be flipped and spaced down a little? Quote Link to comment
Guest 510kamikazifreak Posted September 17, 2011 Report Share Posted September 17, 2011 Yeah I tried to flip it and the bolt holes were still off. Maybe it just needs to be flipped and spaced down a little? What K member you have? Havent read from the start on this. Quote Link to comment
Laecaon Posted September 17, 2011 Report Share Posted September 17, 2011 Yes, the dogleg mounts an inch or 2 lower than stock. So get creative. Its the only part that isnt "simple". Wanna see my ghetto mount? Quote Link to comment
ptown green Posted September 17, 2011 Author Report Share Posted September 17, 2011 What K member you have? Havent read from the start on this. Here it is before I droppeed it in. The 5 speed didnt have a crossmember when I bought it so It has the one that was on the 4 speed that was already in the car. I just measured from the front of the bellhousing to where the mount bolts up and its about an inch or 2 different it looks like. Which would make sence Quote Link to comment
ptown green Posted September 17, 2011 Author Report Share Posted September 17, 2011 Yes, the dogleg mounts an inch or 2 lower than stock. So get creative. Its the only part that isnt "simple". Wanna see my ghetto mount? yeah lets see it! did you have to drill and use different bolts? or did the holes line up when you spaced it? Quote Link to comment
Guest 510kamikazifreak Posted September 17, 2011 Report Share Posted September 17, 2011 Do you have the availability of a Auto(column) K member, its a bolt in item(as best as it gets other than a Specialty or Carter B modded) :cool: 1 Quote Link to comment
Laecaon Posted September 17, 2011 Report Share Posted September 17, 2011 yeah lets see it! did you have to drill and use different bolts? or did the holes line up when you spaced it? Ok so this is the proper way to do it: Here is how I did it...: Yes those are nuts as spacers... This is not permanent, nor is it safe looking. Quote Link to comment
Laecaon Posted September 17, 2011 Report Share Posted September 17, 2011 Do you have the availability of a Auto(column) K member, its a bolt in item(as best as it gets other than a Specialty or Carter B modded) :cool: not true, My picture is the auto tranny K member. Only thing is I think, is that it has more of a bow to it, so when you flip it, it sits under the tranny better. Also note, the dogleg uses T head bolts and then you thread nuts on from below. I lost one of them, so I just put a nut on top, and ran a bolt from the bottom. Quote Link to comment
Guest 510kamikazifreak Posted September 17, 2011 Report Share Posted September 17, 2011 http://www.ebay.ca/itm/Bolt-In-5-Speed-Transmission-Crossmember-Datsun-510-/170697653278?pt=Vintage_Car_Truck_Parts_Accessories&hash=item27be5f7c1e much better Idea.. It works same as the specialty one(from up here) tested and proven for years... :D Quote Link to comment
ptown green Posted September 17, 2011 Author Report Share Posted September 17, 2011 Ok so this is the proper way to do it: Here is how I did it...: Yes those are nuts as spacers... This is not permanent, nor is it safe looking. haha whoa scary. So you drilled different holes in the crossmember so the bolt would go through. Im probably going to find another way to space it hahaha Quote Link to comment
Guest 510kamikazifreak Posted September 17, 2011 Report Share Posted September 17, 2011 not true, My picture is the auto tranny K member. Only thing is I think, is that it has more of a bow to it, so when you flip it, it sits under the tranny better. Also note, the dogleg uses T head bolts and then you thread nuts on from below. I lost one of them, so I just put a nut on top, and ran a bolt from the bottom. Did you flip the K member? From an auto in the tree? Quote Link to comment
Laecaon Posted September 17, 2011 Report Share Posted September 17, 2011 haha whoa scary. So you drilled different holes in the crossmember so the bolt would go through. Im probably going to find another way to space it hahaha As you should. I did say it was ghetto. I would like to get some 1" square tube to use as a spacer, Have it bolt to the car, and the crossmember bolt to the spacer. Quote Link to comment
ptown green Posted September 17, 2011 Author Report Share Posted September 17, 2011 http://www.ebay.ca/i...=item27be5f7c1e much better Idea.. It works same as the specialty one(from up here) tested and proven for years... :D oh nice! that's the way to go there. I gotta think about this. Ill probably give it a try with my existing crossmember asn save the mony but Id rather have that. Quote Link to comment
ptown green Posted September 17, 2011 Author Report Share Posted September 17, 2011 As you should. I did say it was ghetto. I would like to get some 1" square tube to use as a spacer, Have it bolt to the car, and the crossmember bolt to the spacer. okay so 1 inch?! haha finally! :P Quote Link to comment
Laecaon Posted September 17, 2011 Report Share Posted September 17, 2011 Maybe a bit more. I figured the width of 3 7/8ths nuts was good. No odd sounds, so that is good. Quote Link to comment
ptown green Posted September 17, 2011 Author Report Share Posted September 17, 2011 well I guess ill get an inch of square tubing and either drill holes that line up with the mount and put bolts down through there with a nut and washer on the bottom or modify the mount so I can use the original bolt holes. Shit and I thought I was just bolting it in. Quote Link to comment
