skunk Posted May 18, 2011 Author Report Share Posted May 18, 2011 worked on the car a bit today, hoping to get it all done tomorrow. Quote Link to comment
skunk Posted May 18, 2011 Author Report Share Posted May 18, 2011 pulled the timing cover off today, got it and the water pump all clean. Started getting the timing all set in. Have to finish that up tomorrow morning. Have all new gaskets for timing cover/water pump, intake/exhaust, head gasket and a bunch of other stuff. Changing the oil. the timing chain looks new. and it has the gold links :D. No more RTV!!!! Quote Link to comment
skunk Posted May 25, 2011 Author Report Share Posted May 25, 2011 at this point the engine has all new gaskets. just not the oil pan. exhaust is on, carbs are on. car even starts. but my thermostat housing is fucked, found two extras. both had bolts broke in them. fucked up both of them trying to get them to work. on the hunt for a thermostat housing. Quote Link to comment
Guest kamakazi620 Posted May 25, 2011 Report Share Posted May 25, 2011 I gots the bolt drilled out we need a tap to rethread it Quote Link to comment
yello620 Posted May 25, 2011 Report Share Posted May 25, 2011 i have a housing if you end up needing it. Quote Link to comment
skunk Posted May 25, 2011 Author Report Share Posted May 25, 2011 that might be easier, seeing i dont have the tool to tap the fucked up one. Quote Link to comment
yello620 Posted May 25, 2011 Report Share Posted May 25, 2011 I have the tap too. Quote Link to comment
philcas1987 Posted May 25, 2011 Report Share Posted May 25, 2011 Thought it was running? Quote Link to comment
philcas1987 Posted May 25, 2011 Report Share Posted May 25, 2011 Haha . I see what you did there Quote Link to comment
Rustina 510 Posted May 26, 2011 Report Share Posted May 26, 2011 I thought your su bulbs where black skunk? Looking good dude Quote Link to comment
skunk Posted May 26, 2011 Author Report Share Posted May 26, 2011 my bulbs are black. NOT!!!! Quote Link to comment
skunk Posted May 26, 2011 Author Report Share Posted May 26, 2011 the old intakes filter things i had on the 510 were black. and yes it is running, its just not holding water. Quote Link to comment
izzo Posted May 26, 2011 Report Share Posted May 26, 2011 Looks good so far dood. You going to find some small air horns for the su's? or run the K&N? (or just leave it wide open!) whats not holding water? Quote Link to comment
Skib Posted May 26, 2011 Report Share Posted May 26, 2011 one of the bolts for the thermostat housing top is stripped out so it needs a new one Quote Link to comment
skunk Posted June 1, 2011 Author Report Share Posted June 1, 2011 ok, well. she runs. she dont leak any more watter. she does have a exhaust leak where the new down pipe was welded on. i may have to swap over the Throttle Cable. Quote Link to comment
izzo Posted June 1, 2011 Report Share Posted June 1, 2011 Sweet man, almost there! Get er done!!! Bringing it to canby? I wanna see this thing Quote Link to comment
skunk Posted June 1, 2011 Author Report Share Posted June 1, 2011 well tomorrow is my only day of work before canby. so its still a big "maybe". Im going to try and get a ride out to work on the car tomorrow and see if i cant get the timing set and work on tuning the SUs. might save the Throttle Cable swap till im at canby, lol. Quote Link to comment
