Josh K. Posted August 4, 2016 Author Report Share Posted August 4, 2016 Bye bye 720. She was rusted and falling apart. Head gasket blowing was the final straw. Ready to move. I filled that uhaul with my shop stuff.. New home. 6 Quote Link to comment
q-tip Posted August 4, 2016 Report Share Posted August 4, 2016 Not a bad sized garage, about the same size as mine. 2 Quote Link to comment
Josh K. Posted August 6, 2016 Author Report Share Posted August 6, 2016 Got a welding cart for free! My old one was a POS. Got the seat mounts tacked in place and ready to weld. Driver side atleast.. 3 Quote Link to comment
Josh K. Posted August 7, 2016 Author Report Share Posted August 7, 2016 ECU and CanAm box wouldn't fit under the seat like I planned. Oh well. I didn't want wires running along the floor anyways. I made a mount plate and mounted both CanAm boxes in the glove box. One is for ECU/Fuel Pump. The other is for Headlights/Cooling Fan. Tomorrow I'm gonna start the dreaded process of putting all this together.. I put the ECU on the kick panel. Here's what a $200 bottle of trimix looks like... 3 Quote Link to comment
q-tip Posted August 7, 2016 Report Share Posted August 7, 2016 That's a cute little bottle....better make it last, that stuff ain't cheap! As for the relays and such why not mount them under the glove box and build a cover plate so you can keep some glove box space. 1 Quote Link to comment
mklotz70 Posted August 7, 2016 Report Share Posted August 7, 2016 Is that for the bottle and gas, or just the gas? 1 Quote Link to comment
Josh K. Posted August 7, 2016 Author Report Share Posted August 7, 2016 That's a cute little bottle....better make it last, that stuff ain't cheap! As for the relays and such why not mount them under the glove box and build a cover plate so you can keep some glove box space. Because I don't need a glove box and this way I can access them easily. 3 Quote Link to comment
Josh K. Posted August 7, 2016 Author Report Share Posted August 7, 2016 Is that for the bottle and gas, or just the gas? Bottle and gas. 3 Quote Link to comment
q-tip Posted August 7, 2016 Report Share Posted August 7, 2016 Because I don't need a glove box and this way I can access them easily. Good, I have an aluminum panel hiding my mess of wiring is the reason I mentioned a cover. 1 Quote Link to comment
Josh K. Posted August 8, 2016 Author Report Share Posted August 8, 2016 Yeah I was lucky to be able to wire the ECU on my bench. Worked out well. Ok. My back has had enough. Tapping out for the night. ECU is wired to the Motor now. Lots to do still. 3 Quote Link to comment
q-tip Posted August 8, 2016 Report Share Posted August 8, 2016 That is clean man, mine is the exact opposite, thus the shiny aluminum cover. :Lol: Quote Link to comment
Josh K. Posted August 8, 2016 Author Report Share Posted August 8, 2016 Probably like how mine was wired when I bought it.. that reminds me.. I believe the wiring is what started this journey.. Quote Link to comment
Josh K. Posted August 13, 2016 Author Report Share Posted August 13, 2016 First crank (since complete rewire). I was feeling a little unsure. I must've done something right. This is a "no throttle" first try. My car has zero idle controls but the throttle plate. Now to finish welding the exhaust in the am. Too hot tonight. Yes!!! 8 Quote Link to comment
tr8er Posted August 13, 2016 Report Share Posted August 13, 2016 Fuck yeah!!!!! I'd love to feel that right now. 1 Quote Link to comment
Z23T Posted August 13, 2016 Report Share Posted August 13, 2016 Nice, I remember when I first got my car running after it had been apart for a dozen years. It felt so fucking good! 1 Quote Link to comment
Draker Posted August 13, 2016 Report Share Posted August 13, 2016 <Fist pump gif> 2 Quote Link to comment
Josh K. Posted August 14, 2016 Author Report Share Posted August 14, 2016 Thanks Guys! I trimmed a ton of fuel out and the motor smoothed out. Something was still off though. I found the MAP Sensor had 12v instead of 5v.... Seems i tapped the wrong power source. Killed the MAP Sensor. I ordered a replacement.. I also finished the exhaust back to the shifter. Wideband is also setup and working. The factory tach even works! Lot's of little things to do. Atleast I know the motor is healthy. 2 Quote Link to comment
Icehouse Posted August 14, 2016 Report Share Posted August 14, 2016 Huh I didn't even know MAP sensors took 5v. Learn something everyday. 1 Quote Link to comment
Josh K. Posted August 14, 2016 Author Report Share Posted August 14, 2016 Yeah it's best to tap the 5v source from the TPS. Quote Link to comment
Niz16 Posted August 14, 2016 Report Share Posted August 14, 2016 congrats mate!!! must be a big relief to hear her fire up!!!!! 1 Quote Link to comment
moath Posted August 15, 2016 Report Share Posted August 15, 2016 Awesome progress! Are you planning on running a heater core? 1 Quote Link to comment
Josh K. Posted August 15, 2016 Author Report Share Posted August 15, 2016 Yes. Once all systems are tested I'll put in the core. :) 1 Quote Link to comment
jeph Posted August 15, 2016 Report Share Posted August 15, 2016 Awesome progress! Are you planning on running a heater core? Yes. Once all systems are tested I'll put in the core. :) i was gunna say i hope hes putting a heater core in, cant own any car in washington without heat lol, especially when we get rain and snow storms in the summer and shit lol 2 Quote Link to comment
Josh K. Posted August 16, 2016 Author Report Share Posted August 16, 2016 Yummy :) Flat faced H1/H4's... 2 Quote Link to comment
