Josh K. Posted December 29, 2012 Author Report Share Posted December 29, 2012 Decided to start on the coil-over adapters. I'm just roughing them out for now until I get the coil-overs. I'll core out the center to lighten before welding. Quote Link to comment
darc510 Posted December 29, 2012 Report Share Posted December 29, 2012 ToDo'sModify and mount Brake Master Cylinder Sun, Dec 30 Finish running brake lines Sun, Dec 30 Make Bump Steer Spacers Sun, Jan 6, 2013 Install CV's Sun, Jan 6, 2013 Final Weld out of rear suspension Sun, Jan 6, 2013 Make Front Coilover adapters Sun, Jan 13, 2013 Fit Coil-Overs Sun, Jan 13, 2013 Clearance body for rear subframe Sun, Jan 20, 2013 Finish passenger axle tub Sun, Jan 20, 2013 Finish trunk pan and braces Sun, Jan 20, 2013 Finish and weld driver quarter panel Sun, Jan 27, 2013 Redo passenger rear rocker Sun, Jan 27, 2013 Finish and weld on passenger quarter and trunk pan Sun, Jan 27, 2013 Finish weld out of rear panels Sun, Jan 27, 2013 Flip car around Sun, Feb 3, 2013 Mockup all engine bay components. Oil Lines Sun, Feb 3, 2013 Mockup engine harness Sun, Feb 3, 2013 Pull motor and replace rear main seal Sun, Feb 10, 2013 Degrease motor Sun, Feb 10, 2013 Install motor Sun, Feb 10, 2013 Mount all accesories Sun, Feb 17, 2013 Run engine harness Sun, Feb 17, 2013 Wire up all lights and accessories Sun, Feb 24, 2013 Mount Exhaust Sun, Mar 3, 2013 TEST DRIVE........ Pretty optimistic but I gotta set some goals... I applaud your optimism :) I bet if i set a schedule like this i might actually pull everything together on my datto. Quote Link to comment
Josh K. Posted December 30, 2012 Author Report Share Posted December 30, 2012 You gotta start somewhere. As you can tell I get sidetracked real easy....... Looks like finishing the brake line from the front to back will have to wait till I pull the motor. No room... I traded 510 OC a set of CV adapters for his JDM tail light garnish.. No idea what tail lights I'll run. Would like a set of JDM lights with the chrome bars running horizontal but don't wanna pay $500-$600 for a NOS set! 1 Quote Link to comment
hobbes_the_cat Posted December 30, 2012 Report Share Posted December 30, 2012 Love the tail garnish. :wub: I think some Mexican tail lights would go well with it. Crazy to see how much this car has changed. 1 Quote Link to comment
510 OC Posted December 30, 2012 Report Share Posted December 30, 2012 You gotta start somewhere. As you can tell I get sidetracked real easy....... Looks like finishing the brake line from the front to back will have to wait till I pull the motor. No room... I traded 510 OC a set of CV adapters for his JDM tail light garnish.. No idea what tail lights I'll run. Would like a set of JDM lights with the chrome bars running horizontal but don't wanna pay $500-$600 for a NOS set! Looks badass my friend. :thumbup: I was going to try to find a set of NOS Euro tail lights. They're in your price range too. Quote Link to comment
Josh K. Posted December 30, 2012 Author Report Share Posted December 30, 2012 Thanks Jordan. I've got my eye on a set of Euro lights, we'll see..... Finished roughing out the other Coil Over Adapter. Moved onto the Master Cylinder. The 82-83 has a horizontal bolt pattern. I decided to modify the plate to accommodate the pattern. I'll bolt through the firewall and into the pedal assembly. I welded up all the other holes. Just gotta go home and mount it up! I plan to tear it apart and rebuild it if needed. Quote Link to comment
Tristin Posted December 30, 2012 Report Share Posted December 30, 2012 I might have a set of GLs for sale if youre interested Josh. As always, I love your updates. You usually provide good content for the posts. Quote Link to comment
Josh K. Posted December 30, 2012 Author Report Share Posted December 30, 2012 Thanks Tristin. My heart is set on euros..... Gonna make a brace later that bolts to the face of the master and then forward to the strut tower.... 1 Quote Link to comment
Tristin Posted December 30, 2012 Report Share Posted December 30, 2012 Euros are what you're after, I know someone local possibly looking to sell theirs. Not NOS, but with NOS frames I believe. Quote Link to comment
Josh K. Posted December 30, 2012 Author Report Share Posted December 30, 2012 Would have to be trade for cnc'd parts.... ;) 1 Quote Link to comment
Tristin Posted December 30, 2012 Report Share Posted December 30, 2012 Always worth a shot. I'll have him pm you. Quote Link to comment
Josh K. Posted January 3, 2013 Author Report Share Posted January 3, 2013 Got my axles back from Dutchman today. I stayed late tonight and put them together. I'll test fit them this weekend. I measured six times so hopefully they fit..... 1 Quote Link to comment
510 OC Posted January 3, 2013 Report Share Posted January 3, 2013 Wow, those look great Josh!! :hyper: Can't wait to see them installed!!! Quote Link to comment
Josh K. Posted January 5, 2013 Author Report Share Posted January 5, 2013 Should be test fit tonight.... Made the Bump Steer Spacers. 1.25" Tall. I reamed the bolt holes 0.002" over the bolt shoulder Diameter and will make a 0.013" sleeve for where the bolts go through the steering arm. This way it will have no slop and locate the same when I take it apart next time without requiring the toe be reset. I've seen how Techno Toy accomplished this but didn't like the solution they came up with. This is more robust. Quote Link to comment
Josh K. Posted January 6, 2013 Author Report Share Posted January 6, 2013 I made an extra set if someone is interested..... Quote Link to comment
Will Posted January 6, 2013 Report Share Posted January 6, 2013 I made an extra set if someone is interested..... I'm interested!! Nice work! Quote Link to comment
Josh K. Posted January 6, 2013 Author Report Share Posted January 6, 2013 Will, I'll send you a pm soon. Fit the cv's. With the axles horizontal they can compress another 3/4". Looks like I measured correct.... Here's a flood of pics.... Moar lower! Good thing I tunneled the body! 2 Quote Link to comment
DISLEXICDIME Posted January 6, 2013 Report Share Posted January 6, 2013 awww man looking good Quote Link to comment
Josh K. Posted January 6, 2013 Author Report Share Posted January 6, 2013 I can make more bump steer spacers if people want them. I figured the market was already flooded..... Quote Link to comment
Josh K. Posted January 6, 2013 Author Report Share Posted January 6, 2013 awww man looking good Thanks, its starting to come together! Quote Link to comment
that one guy Posted January 6, 2013 Report Share Posted January 6, 2013 You. Quit cheating and making everything look so fancy and damn easy!!!! Quote Link to comment
Josh K. Posted January 6, 2013 Author Report Share Posted January 6, 2013 It's easy if you have a plan, skills necessary and the equipment to do it ;) Or just make up for all of that with sheer determination! Quote Link to comment
Josh K. Posted January 6, 2013 Author Report Share Posted January 6, 2013 Nothing but win in this picture.... 1 Quote Link to comment
Josh K. Posted January 7, 2013 Author Report Share Posted January 7, 2013 Finished the rear suspension!!! Quote Link to comment
Josh K. Posted January 8, 2013 Author Report Share Posted January 8, 2013 Just talked to Troy and my coil overs are shipping this week!!! Quote Link to comment
