Skib Posted May 25, 2011 Author Report Share Posted May 25, 2011 then i need one of them to lol. its at a nice height for me now since I have 240Z seats in my truck and they sit a bit lower Link to comment
Javin Posted May 26, 2011 Report Share Posted May 26, 2011 I want one too! What z do I need to get one out of skib? Link to comment
Skib Posted May 26, 2011 Author Report Share Posted May 26, 2011 I want one too! What z do I need to get one out of skib? any L series Z will do (70-83) just as long as its not an 82-83 turbo cuz those came with T-5 trannys. Link to comment
Jester Posted May 26, 2011 Report Share Posted May 26, 2011 JUST KEEP IT!!!!! It looks toooooo good. Link to comment
Skib Posted May 26, 2011 Author Report Share Posted May 26, 2011 got another super nice 240z seat for the pass side :cool: also replaced the throttle cable today, noticed it was starting to fray Link to comment
hellamikey Posted May 26, 2011 Report Share Posted May 26, 2011 got another super nice 240z seat for the pass side :cool: What did you have to do to put the Z seats in? new seat rails, or do they line up? I'll be putting mine in soon, but I haven't mocked 'em up yet. Link to comment
Skib Posted May 26, 2011 Author Report Share Posted May 26, 2011 What did you have to do to put the Z seats in? new seat rails, or do they line up? I'll be putting mine in soon, but I haven't mocked 'em up yet. what year Z are they from? Link to comment
datsunaholic Posted May 26, 2011 Report Share Posted May 26, 2011 Fray? That throttle cable looks torched. They do that when the engine block ground isn't hooked up, or when the block ground is hooked up but the body ground isn't. Link to comment
Skib Posted May 26, 2011 Author Report Share Posted May 26, 2011 Fray? That throttle cable looks torched. They do that when the engine block ground isn't hooked up, or when the block ground is hooked up but the body ground isn't. I assumed the discoloration was from the heat of it rubbing. the hole where it comes threw the firewall (its a lokar so its got the threaded fitting it runs threw) and the hole it goes into on the pedal are just a bit off, the pedal sits like 1/4in higher so the cable rubs on the top of the threaded sleeve it runs threw Link to comment
datsunaholic Posted May 26, 2011 Report Share Posted May 26, 2011 I can't see how a throttle cable would move fast enough to heat up enough to get blue discoloration. That's gotta be from it shorting to the firewall. The new cable will do the same thing- I think hooking up extra grounds would be a wise investment at this point. Might even make your dash lights brighter... Link to comment
Skib Posted May 26, 2011 Author Report Share Posted May 26, 2011 where would you suggest putting them? I have a battery>block ground and a block>body ground already Link to comment
Skib Posted May 26, 2011 Author Report Share Posted May 26, 2011 it runs threw an aluminum sleeve and wore a notch into the top of the old one where it rubbed Link to comment
HRH Posted May 26, 2011 Report Share Posted May 26, 2011 Where is the block to body ground run? I ran mine from the bolt hole on the cylinder head, over to the bolt that used to house the voltage regulator. That's the stock ground point for all the headlights and alternator too. Link to comment
Skib Posted May 26, 2011 Author Report Share Posted May 26, 2011 Where is the block to body ground run? I ran mine from the bolt hole on the cylinder head, over to the bolt that used to house the voltage regulator. That's the stock ground point for all the headlights and alternator too. it runs from the very back exhaust stud to the firewall there might be a second one, I need to go look Link to comment
HRH Posted May 26, 2011 Report Share Posted May 26, 2011 Doesn't show the ground strap currently there, but that's where it goes to on the 510. Link to comment
hellamikey Posted May 27, 2011 Report Share Posted May 27, 2011 what year Z are they from? An early 74 (late 73 build date). I cant remember when they changed the seat mounts from studs to tabs. Anyway, any mods required? What years are your seats? Link to comment
Skib Posted May 27, 2011 Author Report Share Posted May 27, 2011 An early 74 (late 73 build date). I cant remember when they changed the seat mounts from studs to tabs. Anyway, any mods required? What years are your seats? as long as they have the flat/stud 240z type rails its fine. I drilled new holes for it in the front seat mount and then just drilled 2 holes for the rear in the floor. mine are both from a 73 Link to comment
hellamikey Posted May 27, 2011 Report Share Posted May 27, 2011 as long as they have the flat/stud 240z type rails its fine. I drilled new holes for it in the front seat mount and then just drilled 2 holes for the rear in the floor. mine are both from a 73 sweet. easy as. Link to comment
Skib Posted May 28, 2011 Author Report Share Posted May 28, 2011 lost my phone so I cant get pics but I have a geound cable going from the batt to the head, from the batt to the engine bay right next to it and a cable going from the rear most exhaust stud to the firewall Link to comment
Skib Posted May 31, 2011 Author Report Share Posted May 31, 2011 got both the 240z seats in :cool: Link to comment
Skib Posted May 31, 2011 Author Report Share Posted May 31, 2011 Nice skib! Now what? paint, hood wrap, carpet, bed liner, sound deadner, lol the list is still plenty long :lol: Link to comment
]2eDeYe Posted May 31, 2011 Report Share Posted May 31, 2011 Did you send that memory stick yet? Link to comment
AtomChurch Posted June 1, 2011 Report Share Posted June 1, 2011 got both the 240z seats in :cool: Yay! for the other seat! Link to comment
Skib Posted June 1, 2011 Author Report Share Posted June 1, 2011 2eDeYe' date='31 May 2011 - 02:42 PM' timestamp='1306878137' post='485775']Did you send that memory stick yet? on my list for tomorrow Link to comment
