SRSANDS Posted August 22, 2010 Report Share Posted August 22, 2010 Hey guys, I am soon to be a owner of a 521. My plans for this project have many suprises down the road but for now I want to get it into a good daily driver so I dont have to drive my 510 to work. I was researching how to reindex torsion bars and I guess since I havent had a chance to actually lay under the truck and take a hands on approach it seem kinda un clear to me. Can anyone point me in the right direction by giving my a write up or steps on how to crank this thing to the ground. 1 Quote Link to comment
datzenmike Posted August 22, 2010 Report Share Posted August 22, 2010 Look in the pinned FAQ in the General Discussion http://www.bleachgar...20tech_spn.html 1 Quote Link to comment
datzenmike Posted August 22, 2010 Report Share Posted August 22, 2010 Look in the pinned FAQ in the General Discussion : http://community.ratsun.net/topic/2105-datsun-faq-frequently-asked-questions-look-here-first/ also here: http://www.bleachgarage.com/620tech_spn.html 1 Quote Link to comment
I'm BLUE Posted August 22, 2010 Report Share Posted August 22, 2010 double post fail ^^^ :lol: 1 Quote Link to comment
datzenmike Posted August 22, 2010 Report Share Posted August 22, 2010 double post fail ^^^ :lol: :lol: Damn I added another link and dropped the ball. Already had to fix someone's triple post to-day. 2 Quote Link to comment
banzai510(hainz) Posted August 22, 2010 Report Share Posted August 22, 2010 Jeff and I reindexed his 521 from the from A arm. Loosen nut where it almost comes off then wack it with a hammer/mallet You need to jack the wheel hub up.to hold it. we didnt take the torsion bolt or c clip out in the back. This is more on 620s 2 Quote Link to comment
]2eDeYe Posted August 22, 2010 Report Share Posted August 22, 2010 Take some pics so we can add the to the FAQ :D 1 Quote Link to comment
Pacific coast Datsun Posted August 23, 2010 Report Share Posted August 23, 2010 Jeff and I reindexed his 521 from the from A arm. Loosen nut where it almost comes off then wack it with a hammer/mallet You need to jack the wheel hub up.to hold it. we didnt take the torsion bolt or c clip out in the back. This is more on 620s I did my 521 the same way...very easy & effective. 2 Quote Link to comment
SRSANDS Posted August 26, 2010 Author Report Share Posted August 26, 2010 Ya Im in a tough boat on this one.....not familiar to the entire setup of torsion bars and the bars came with the truck but Im thinking there are a few pieces not with them. Datdoug is a cool dude and he said hes got the bolts but I know there is more....clips ect I dunno, I have a manal but the images are poor and limited so.....I guess I have to be patient and wait for a 51 in the junk yard.....Are the 620s te same or close as far as parts and mounting ect.....I dunno.....Right now I see splined holes in the front and a plate with a hole in under the bed where they go but Im scratchin my nuts with the torsion bars in my hand (bars only wit that lever with the hole and dimple in it..only) Mini trucks are a whole different animal :( Anyone have detailed pics or a truck guy close to Puyalup that can show me whats up and what I need I would appreciate it! 1 Quote Link to comment
Pacific coast Datsun Posted August 26, 2010 Report Share Posted August 26, 2010 Heres the only 2 pix i took from when i did the bars on my 521. This is AFTER removing the long nut & bolt..you can see how the bracket has dropped down bout 1/4 inch....... & i used a sharpie to mark the position of the bar in the STOCK position. Theres a bolt on the frontside of the bar [lower arm] that you remove then tap the bar out towards the BACK of the truck...... once the bar is removed simply jack up the lower arm until you get the desired wheel to fender gap. Reinstall the front bolt then the long bolt & nut. You "may" have to trim & or remove the bump stops depending how low you go. 1 Quote Link to comment
Lobo Posted February 21, 2014 Report Share Posted February 21, 2014 i know this is a older post but what is the point of marking it if it is not going into the same spot anyway 1 Quote Link to comment
Hooligan Posted February 21, 2014 Report Share Posted February 21, 2014 So you can count how many teeth you move each bar to make sure they match from side to side 1 Quote Link to comment
mrbigtanker Posted February 21, 2014 Report Share Posted February 21, 2014 If I am not mistaken you will get about 4" respectfully,if you crank the torsion bar nuts down and you will get 3" tested and proven. 2 Quote Link to comment
Ed-datsun521 Posted February 21, 2014 Report Share Posted February 21, 2014 if i re index them one tooth is that gonna drop about and inch? or more 2 Quote Link to comment
mrbigtanker Posted February 21, 2014 Report Share Posted February 21, 2014 if i re index them one tooth is that gonna drop about and inch? or more Just 1 tooth is about 3-4".Driver side goes counter clock wise and passenger side goes clock wise. 2 Quote Link to comment
Ed-datsun521 Posted February 25, 2014 Report Share Posted February 25, 2014 4 inch drop! Wow just did it I think I will go back an inch with the torsion bolts 2 Quote Link to comment
zatdane Posted September 18, 2015 Report Share Posted September 18, 2015 anyone getting ready to do this and willing to shoot a video of it? 1 Quote Link to comment
datson4life Posted September 18, 2015 Report Share Posted September 18, 2015 anyone getting ready to do this and willing to shoot a video of it? http://community.ratsun.net/topic/63543-video-how-to-reindex/?do=findComment&comment=1297129 That link took me 45 minutes to find 1 Quote Link to comment
