Supercharged VG30 ,stretched 720 Pickup
  • Replies 584
Update
Still alive , got a new toy !!!! 2005 350Z 35th anniversary 6 spd.
it's super sweet !!!!!
It has helped me get motivated to work on the truck.
Good news I have to finish Blue Thunder before I can play with the Zed
So I have been back on the 720 .....
Machining the hubs so the new Z32 discs line up in the middle of the Calipers
New studs
Had to make the centers of the discs bigger & drill holes so the hub could go on the outside and the disc gets bolted on from behind
Next is making custom outer tie rods to compensate for the bump steer
And again thanks for the nice comments , really going to push to get this done ASAP !!!!!
  • Like 4
Update
New studs
Gee.....where have I seen that kind of work before? lol :)   Did you redrill the rotors to fit the hub?
Update
Well I was going to make an Aluminum tank and run it between the frame rails at the back etc , but its just going to far with this build.
Just need to button it up and get it done. So managed to get a fuel tank in , it's out of a regular cab short box 93 D21 I had hanging around . it has a pump in it so that will help ( I will refurbish it of course )
But the goal was to get it in there.
Here it is next to the stock one I took out , quite a bit smaller.
Making the front mount
In order to get it away from the rear suspension and new frame I had to notch the back of the cab.
this will work out great the tank will be flush with the bottom of the frame rail, tucked up there nicely .
Now I will box that back in , the tank will get a thick rubber pad to isolate it from the brackets.
  • Like 4
Update
Worked on my space saver spare system today , what can I say it's too cool !!!!!
Had to make the bottom piece fit the hole
The center shaft the old T-Bar goes in , machined it to fit a socket that fit the PW motor drive
  • Like 3
Update
Spare tire system , just have to fab up the cradle parts to guide and hold it in place , works really well !!!!!
Trimmed the cross braces to get it tucked up in there out of the way , probably will never use it but I intend to do some long road trips , and don't want to be without a spare.
  • Like 4
Update
Worked on the Spare again today , I hurt my back a Xmass time and it's not cooperating , so everything is crawling along , including me .....
Here is a little trick I do quite often , I tack weld two or three plates together if I am making two or three copies , this saves a lot of time , you only do the layout once , drill all the holes at the same time , trimming or grinding the pieces , they all turn out the same .
Bending the parts to fit the tire , this will help hold it in place
I bent a piece of tube to go in the front to help guide it into place on the way up.
I will finish welding these out when the box comes off.
  • Like 5
  • 4 weeks later...
Hi
back working on Blue Thunder , had to do something fun to get me motivated , something not under the truck for a change .....my back is still not 100 % .
So I decided to prep the summer hood , I made a special pair of plyers for this job.
Was trying to get an edge on the cut out that would help stiffen it up.
Measure twice
Plyers in action
Still some dolly work to do and a skiff of filler
  • Like 13
