Bat Fastard Posted September 14, 2009 Report Share Posted September 14, 2009 Hello, I have been checking out this forum for a while, looking for a new place to continue my build thread. (if theres any interest) I started one at 510 Realm and have spent quite some time there looking at other peoples cars for ideas. Then the search engine at the realm broke and the picture uploading stopped working as well. So I'm gonna post up a few pics of my car and see if theres any interest for me to continue the build thread here. My old thread on the Realm is titled "Cuban Missle Crisis". Read the begining of the thread and you will understand the title. BF Quote Link to comment
DISLEXICDIME Posted September 14, 2009 Report Share Posted September 14, 2009 we like pics :D Quote Link to comment
Bat Fastard Posted September 14, 2009 Author Report Share Posted September 14, 2009 O.K., as soon as I can figure it out...... Quote Link to comment
datrod Posted September 14, 2009 Report Share Posted September 14, 2009 We like pic's so post up so we can start to bash you right away. Quote Link to comment
Bat Fastard Posted September 14, 2009 Author Report Share Posted September 14, 2009 Under the posting rules is says "You may not post attachments". WHy is this? Quote Link to comment
datsunfreak Posted September 15, 2009 Report Share Posted September 15, 2009 Do you not have the photos hosted somewhere? Like maybe photobucket? Quote Link to comment
Skib Posted September 15, 2009 Report Share Posted September 15, 2009 How to post pictures (and keep online photo albums) ;) Quote Link to comment
Bat Fastard Posted September 15, 2009 Author Report Share Posted September 15, 2009 Here we go... Quote Link to comment
Bat Fastard Posted September 15, 2009 Author Report Share Posted September 15, 2009 a few of the power steering rack from a celica.. Quote Link to comment
Bat Fastard Posted September 15, 2009 Author Report Share Posted September 15, 2009 R200 with 280zx turbo cv's and maxima companion flanges as well as Byron 510's camber plates. They worked out great! Quote Link to comment
Bat Fastard Posted September 15, 2009 Author Report Share Posted September 15, 2009 Thanks Skib for the how to. Quote Link to comment
bonvo Posted September 15, 2009 Report Share Posted September 15, 2009 the back brakes look like an ermish kit are they? Quote Link to comment
Bat Fastard Posted September 15, 2009 Author Report Share Posted September 15, 2009 Nope, they are from Airzona Z cars. Quote Link to comment
Bat Fastard Posted September 15, 2009 Author Report Share Posted September 15, 2009 We like pic's so post up so we can start to bash you right away. Go Ahead.... Quote Link to comment
lynchfourtwenty Posted September 15, 2009 Report Share Posted September 15, 2009 that ish is SICK! Quote Link to comment
izzo Posted September 15, 2009 Report Share Posted September 15, 2009 Go Ahead.... i like it :D Quote Link to comment
datto510 Posted September 15, 2009 Report Share Posted September 15, 2009 That is a clean dime! Especially for the east coast. Quote Link to comment
Duke Posted September 15, 2009 Report Share Posted September 15, 2009 Any more info on the rack? Looks to be the perfect width for a 510. Did you shorten it? Car looks great, I'm lookin forward to seeing the progress. Quote Link to comment
DISLEXICDIME Posted September 15, 2009 Report Share Posted September 15, 2009 nice job it looks real clean Quote Link to comment
Byron510 Posted September 15, 2009 Report Share Posted September 15, 2009 Thanks Skib for the how to. The same process works on the Realm as well. But now I Quote Link to comment
fisch Posted September 15, 2009 Report Share Posted September 15, 2009 Rad build man!! Welcome indeed! Quote Link to comment
Icehouse Posted September 15, 2009 Report Share Posted September 15, 2009 WOW!!!!! AWESOME!!!! What CV axles did you use? They must be really short to fit the R200. Quote Link to comment
Bat Fastard Posted September 16, 2009 Author Report Share Posted September 16, 2009 The rack is from a 92 celica (not sure of the year but it was that bodystyle). The rack did need some mods: It is not shortened but we did have to "clock" the piece where the PS lines go into.. see pics where we welded another set of tabs to rotate the head so that the lines would clear the engine block. Custom mounts were also fabbed to mount it to the crossmember. The tie rods are stock Celica parts (inner and outer) just shortened to fit. It is a very tight setup that is approx. 2.6 turns lock to lock. Quote Link to comment
Bat Fastard Posted September 16, 2009 Author Report Share Posted September 16, 2009 On with the progress, I started out working on the fuel tank this morning and got the tank mounted, all lines connected and tightened, made a mount for the fuel pump and filter, then mounted that on some rubber isolators right in front of the tank. With the fuel system finished up to the firewall, it was time to work on the brakes. I ran new hard lines for the right and left sides in the engine bay. The pedal assembly, which is a cut up modded Wilwood reverse pedal mount, was then mounted and I ran new lines from it to the bulkhead fittings for the front lines. A new clutch line was ran as well. Then on to mounting the resivoirs, that turned out a little more time consuming than I thought. As soon as I get some parts from summit (park lock) I'll be able to finish up the brake system. Tomorrow maybe I'll mount the gas pedal assy from a 240sx.... Quote Link to comment
Byron510 Posted September 16, 2009 Report Share Posted September 16, 2009 The rack is from a 92 celica (not sure of the year but it was that bodystyle). The rack did need some mods: It is not shortened but we did have to "clock" the piece where the PS lines go into.. see pics where we welded another set of tabs to rotate the head so that the lines would clear the engine block. Custom mounts were also fabbed to mount it to the crossmember. The tie rods are stock Celica parts (inner and outer) just shortened to fit. It is a very tight setup that is approx. 2.6 turns lock to lock. Thanks for the info on the rack, but what is the distance between the inner tie rod ends?. I'm hoping it's around 19". Byron Quote Link to comment
