Let's see some machine work
I had to recently setup a machine that was not setup from origin point, but ran a 4th axis, multiple offset setup. In this setup there is an offset for each angle and plane which is machined on.
There were 6 offsets for op1 and 2.
Six......., versus having them all done with 1 that the positions NEVER change, and can be used on every part programmed this way in this machine.
  • Replies 947
I have dealt with those type of programmers before.
Manufacturing has no need for them. Worked with a lathe programmer once that thought it was cool to put an offset on every surface turned.
I have heard of that too, Thats an awesome way to destroy a lathe.
we always use the exact same point for programming in the lathe.
I've got the second "s" in "kiss" down pat!!!  :)
Very interesting information guys! Thanks!!!  It may be some time before I even pull out my 4th axis, but I'm still trying to learn what I can for when the time comes.
I've been working on my new mill a little each day....it's down to some tweaking now. :)
On our Horizontals we program to corner of part/stock and have MasterCam output G10 lines to shift the origin. I hate centerline on HMC's....
On VMC's with rotaries (which I haven't done in a few years) I do the same. I like having my z values relative to the part and not centerline. Sometimes I program from center of rotary. It really depends on the part. If it's a 4 sided fixture/tombstone I'll program from faces. If it's a single part I'll go centerline.
Multiaxis lathes its always G54 for main, G55 for sub. Centerline of course.
5axis Mills it's always center of rotaries.
We use G10 lines to write most all of our work offsets using subplates and charts to tell you the exact location. Takes 30sec to load your work offset. No edge finders... HMC's its just load gcode and hit cycle start.
If your doing high precision work you need lots of offsets. I have a family of parts running on a HMC and the parts have as much as 12 offsets each. Each rotation has to be adjusted independently.
You guys are talking about two different methods.
Center of rotary.
Shifted work offset.
I use both where applicable. Some guys are either one or the other. Old school (centerline) or new school (shifted).
Josh-
Here's a typical HMC code output:
O0123(14-0779)
(POST REV 2.0)
(NH4000DCG - HMC)
(MCX FILE   - 421Z6301-4062--B-CELL.MCX-8)
(DATE       - APR-29-2014)
(TIME       - 5:09 PM)
(USER ID    - ***)
(OPERATIONS - 50/60/70)
#510=21(OPTIONAL N SEQ START)
IF[#510EQ1]GOTO3000
M0
(USING OPTIONAL N SEQ START)
M0
(YOU ARE STARTING PART WAY THROUGH)
N3000
(***  TOOL LIST  ***)
(T1   - I321 -3" FACE MILL   - D3.0000 - R0.0313)
(T6   - B682 - 0.250" END MILL - 0.01" RAD - D0.2500 - R0.0100)
(T12  - O600 - 1/4"-90 SPOT DRILL - D0.2500)
(T31  - D1236 - #16 DRILL    - D0.1770)
(T15  - F1829 - 0.1985" REAMER - D0.1985)
(T8   - B3470 - 1/2" END MILL - 0.094" RAD - D0.5000 - R0.0940)
(T4   - B3533 - 3/4" ENDMILL  - D0.7500 - R0.0300)
(T27  - D2354 - 5/8" DRILL   - D0.6250)
(T28  - B3460 - 1/2" END MILL - D0.5000 - R0.0200)
(T5   - B3461 - 1/2" ENDMILL  - D0.5000 - R0.0300)
(T13  - D1727 - 0.386" DRILL - D0.3860)
(T9   - B3473 - 3/4" ENDMILL - 0.094" RAD - D0.7500 - R0.0940)
(T16  - B572 - 1/2" END MILL - 0.008"RAD - D0.5000 - R0.0080)
(T29  - B1357 - 1/2" END MILL - 0.0625"RAD - D0.5000 - R0.0625)
(T25  - B2956 - 3/8"BALLNOSE - D0.3750 - R0.1875)
(T30  - B1367 -3/16" BALLNOSE - D0.1875 - R0.0938)
(T26  - L352 - 0.250"X45 CHAMFER MILL - D0.2500)
(T18  - TD3475 - ROMICRON BORING HEAD - D1.0003)
(T19  - TD3095 - ROMICRON BORING HEAD - D0.7500)
(T20  - J2537 - 0.500"X45/-45 BACK CHAMFER - D0.5000)
(T22  - A2432 - 0.1875" END MILL - D0.1875)
(T23  - F3476 - 0.2545" REAMER - D0.2545)
(T24  - F567 - 0.3135" REAMER - D0.3135)
(***  USER DEFINED WORK COORDINATES START  ***)
(TOOL PLANE -  OP60 - B0 - P1)
G90G10L20P1X0.Y6.9061Z10.2425B0.(ACTUAL -  B0. FACE)
G91G10L20P1X0.Y0.Z0.(INCREMENTAL WORK SHIFT)
(TOOL PLANE -  OP60 - B270 - P2)
G90G10L20P2X10.2425Y6.9061Z0.B0.(ACTUAL -  B270. FACE)
G91G10L20P2X0.Y0.Z0.(INCREMENTAL WORK SHIFT)
(TOOL PLANE -  OP60 - B90 - P3)
G90G10L20P3X-10.2425Y6.9061Z0.B0.(ACTUAL -  B90. FACE)
G91G10L20P3X0.Y0.Z0.(INCREMENTAL WORK SHIFT)
(TOOL PLANE -  OP60 - B0 - P4 - SLOT FINISH)
G90G10L20P4X0.Y6.9061Z10.2425B0.(ACTUAL -  B0. FACE)
G91G10L20P4X.002Y0.Z0.(INCREMENTAL WORK SHIFT)
(TOOL PLANE -  OP60 - B0 - P5 CENTER FEATURES)
G90G10L20P5X.0012Y6.9061Z10.2425B0.(ACTUAL -  B0. FACE)
G91G10L20P5X.001Y0.Z0.(INCREMENTAL WORK SHIFT)
(TOOL PLANE -  OP70 - B0 - P25)
G90G10L20P25X-1.9647Y13.438Z7.4385B0.(ACTUAL -  B0. FACE)
G91G10L20P25X0.Y0.Z-.0006(INCREMENTAL WORK SHIFT)
(TOOL PLANE -  OP70 - B355 - P26)
G90G10L20P26X-1.3089Y13.438Z7.582B0.(ACTUAL -  B355. FACE)
G91G10L20P26X0.Y0.Z0.(INCREMENTAL WORK SHIFT)
(TOOL PLANE -  OP70-B221.795-P27)
G90G10L20P27X-3.4958Y12.7695Z6.8468B0.(ACTUAL -  B41.79 FACE)
G91G10L20P27X0.Y0.Z0.(INCREMENTAL WORK SHIFT)
(***  WORK COORDINATES END  ***)
GOTO#510(JUMP TO SEQ)
M01
N1(Sequence #1.)
(TOOL# 1 - I321 -3" FACE MILL -  DIA. - 3.)
(OP  22 )
(MAX - Z.02)
( PALLET CHECK - PALLET2 )
M500C2
G00G17G40G80G90G53Z0.
T1M6
M11(UNLOCK)
G00G17G90G54.1P25B0.
M10(LOCK)
X-2.3186Y2.5659S6000M03
G43H1Z2.M8T6
G332R1.
G5P10000
Z.25
G94G01Z.14F100.
P1-24 are assigned to Pallet 1, 25-50 are assigned to Pallet 2. The post outputs the correct pallet change number per work offset. ( PALLET CHECK - PALLET2 )
M500C2
In this case it's pallet 2.
You'll also notice the following: (MAX - Z.02)
Since the work offset is set to "Top of finished part", this will tell you exactly how deep that tool will go. In this case it will Leave 0.020" on the part face. Very handy for validation at the control.
-Josh
If & GoTo loops. Used those a ton on the Okuma Pallet change horizontal.
Each face of the tomb stones had its own quardinate call out, and P-#
Loved how I could set the tools from the tool setter and park them in the belt. A probe would verify rough stock and finish part dimension as well.
Lights out.
Probes are great. As long as their not old Renishaw continuity probes....
The sequence start (#510, coincidence?) is setup so if you need to start part way through you are A) Informed/warned that is what you're doing. B.) So the work offsets are written and updated incase you made a change since last time they were written.
  • 4 weeks later...
  • 1 month later...
