robrizzo Posted April 18, 2023 Report Share Posted April 18, 2023 15x8 with 3.5” back spacing wheels Will these fit a 1971 521 ? I wish there was a list of what fits and what does not. Or what other cars or truck wheels fit. Can someone answer this question? Quote Link to comment
d.p Posted April 18, 2023 Report Share Posted April 18, 2023 What is the bolt pattern? 6 x 139.7 is what it is on 521s...and 15 x 8 -10 or so is the sweet spot IMHO. No idea how backspacing plays into all that. Quote Link to comment
robrizzo Posted April 18, 2023 Author Report Share Posted April 18, 2023 Yes 6 lug. The back space is the concern I am asking about Quote Link to comment
thisismatt Posted April 18, 2023 Report Share Posted April 18, 2023 If anything I'd think they'll poke. 8" wide with 3.5" backspacing would be a -25 offset I believe. That's if you take backspacing off the lip and the lips account for about 1" more than the specified wheel width as typical. An 8" rim being 9" lip to lip with a 3.5" backspace is 1" negative off center, or -25 offset. Quote Link to comment
datzenmike Posted April 18, 2023 Report Share Posted April 18, 2023 Always better to find out what will fit first than to fall in love and you have to make all the changes. Always make the rims and tires fit the vehicle, not the other way around. Quote Link to comment
robrizzo Posted April 18, 2023 Author Report Share Posted April 18, 2023 does anyone know if the rim will work? Quote Link to comment
thisismatt Posted April 18, 2023 Report Share Posted April 18, 2023 18 minutes ago, robrizzo said: does anyone know if the rim will work? Sorry we don't have every offset, width, and diameter combination that works scoured to memory to serve you, sir. Get out there with a straight edge, tape measure, and combo square to figure it out for yourself ffs 1 1 Quote Link to comment
mainer311 Posted April 18, 2023 Report Share Posted April 18, 2023 (edited) 8" rim with 3.5" backspace is -25 offset. They'll stick out of the fenders. Will they "work"? Yeah. If your truck is lowered, the tires will smash the fenders. Fuckin christ. Do some math or something. Edited April 18, 2023 by mainer311 1 2 Quote Link to comment
datzenmike Posted April 18, 2023 Report Share Posted April 18, 2023 I got these rims and tires off a 280z so I could drive to the body shop. Yours may end up worse than this. Even with this much height clearance they hit the wheel arch on a bump. Get the correct offset. Takes a little thought but you can do it. 1 Quote Link to comment
wayno Posted April 18, 2023 Report Share Posted April 18, 2023 I have found that most domestic 6 lug rims stick out too far on a Datsun unless aftermarket made for a Datsun, but I have seen Datsuns where the owner went for that look. Are not all 6 lug patterns the same except for on dually applications? Quote Link to comment
thisismatt Posted April 18, 2023 Report Share Posted April 18, 2023 8 minutes ago, wayno said: I have found that most domestic 6 lug rims stick out too far on a Datsun unless aftermarket made for a Datsun, but I have seen Datsuns where the owner went for that look. Are not all 6 lug patterns the same except for on dually applications? No, there are 6x135mm, 6x4.5" (114.3mm), and 6x5.5 (139.7mm) 1 Quote Link to comment
mainer311 Posted April 19, 2023 Report Share Posted April 19, 2023 Nissan started using 6x114.3 on SUV’s and midsize trucks starting in 2005. Dodge Dakotas also use it. 1 Quote Link to comment
robrizzo Posted April 19, 2023 Author Report Share Posted April 19, 2023 Good Morning, I am sorry I asked. I did put all the info I have on the wheels. I was wondering if anyone knew so I could figure to buy wheels or not. 8" rim with 3.5" backspace 15 inch with 6 lug. Honestly if I had the wheel I would not be asking. If I had my truck with me I would not be asking. Sad thing I thought we were all here for the LOVE OF CARS. to help one another. I see some reactions to comments Laughing and off putting comments. Some are respectful and helpful Bur remember you were not born being knowledgeable to everything God Bless 1 Quote Link to comment
KELMO Posted April 19, 2023 Report Share Posted April 19, 2023 We should have a disclaimer on here. This is a forum for a bunch of assholes that just happen to own Datsuns. 1 Quote Link to comment
robrizzo Posted April 19, 2023 Author Report Share Posted April 19, 2023 All good I just know what to expect here Quote Link to comment
robrizzo Posted April 19, 2023 Author Report Share Posted April 19, 2023 11 hours ago, mainer311 said: Nissan started using 6x114.3 on SUV’s and midsize trucks starting in 2005. Dodge Dakotas also use it. so these fit 1971 521? Quote Link to comment
datzenmike Posted April 19, 2023 Report Share Posted April 19, 2023 The 521/620 720 and D21 Hardbody WD21 Pathfinder and probably Xterra all use the same 6 lug pattern. Toyota/Mazda/Isuzu 6 lug also fit as does GM and Ford. I sent you a private message with a calculator tool for comparing what you have now with what might work. There is no easy answer for this, you have to make some measurements and plug the numbers in. Generally stock rims are probably zero offset but this can be confirmed with a tape measure. 2 Quote Link to comment
robrizzo Posted April 19, 2023 Author Report Share Posted April 19, 2023 6 minutes ago, datzenmike said: The 521/620 720 and D21 Hardbody WD21 Pathfinder and probably Xterra all use the same 6 lug pattern. Toyota/Mazda/Isuzu 6 lug also fit as does GM and Ford. I sent you a private message with a calculator tool for comparing what you have now with what might work. There is no easy answer for this, you have to make some measurements and plug the numbers in. Generally stock rims are probably zero offset but this can be confirmed with a tape measure. Thank You exactly what I was hoping for thank You so much Quote Link to comment
mainer311 Posted April 19, 2023 Report Share Posted April 19, 2023 (edited) 7 hours ago, robrizzo said: so these fit 1971 521? No, Nissan wheels from 2005 and on use 6x4.5" lugs, with the exception of the Armada/Titan wheels, which are still 6x5.5" We really don't know enough about your truck to make a solid determination here. Is it lowered? Is it on stock tire size? Bottom line is that -25 offset 8" wide wheels will stick out past the fenders regardless of anything else. As DP said, an 8" wheel with about -12 to -15 offset is about as far as you can go and have the wheels be flush with the fenders. Are there certain wheels that you're particularly interested in? There are good sites to find used period-correct wheels from Japan where you can input your specs to see what exists. I've gotten wheels from Croooober before, or there are others... Edited April 19, 2023 by mainer311 Quote Link to comment
mainer311 Posted April 19, 2023 Report Share Posted April 19, 2023 (edited) 22 hours ago, wayno said: I have found that most domestic 6 lug rims stick out too far on a Datsun unless aftermarket made for a Datsun, but I have seen Datsuns where the owner went for that look. Are not all 6 lug patterns the same except for on dually applications? Frontier/Xterra wheels from 1998 to 2004 should fit no problem. Generally they were all 7" wide with little offset. Edited April 19, 2023 by mainer311 Quote Link to comment
pidge Posted April 20, 2023 Report Share Posted April 20, 2023 12 hours ago, robrizzo said: so these fit 1971 521? No. The ‘05 and newer Frontier/pathfinder/xterra rims have a different 6 bolt compared to the older models. As far as I know the Titan wheels from the ‘05 and newer era are the same six bolt as the older Nissan trucks so they’ll fit a 521. -Pidge Quote Link to comment
robrizzo Posted June 19, 2023 Author Report Share Posted June 19, 2023 I found a set of wheels I like Aluminum ols school slotted wheels Thank You everyone. Now off to getting another trans. Last one I bought will not go into reverse GRRRR I found a 280z trans 5 speed with .864 overdrive I only want a gas sipper Advise. Please 1 Quote Link to comment
datzenmike Posted June 19, 2023 Report Share Posted June 19, 2023 280zs did not have the close ratio 5 speed, they were mid ratio with the 0.864 5th. I explained this in a reply PM just now and how to tell if wide. mid or close ratio. Quote Link to comment
Stoffregen Motorsports Posted June 20, 2023 Report Share Posted June 20, 2023 ZX had the "close ratio" trans. Quote Link to comment
Stoffregen Motorsports Posted June 20, 2023 Report Share Posted June 20, 2023 Turns out you can buy new close ratios gear sets - https://jdm-car-parts.com/products/kameari-performance-71b-5-speed-transmission-close-gear-set-for-skyline-hakosuka-kenmeri-laurel-fairlady-z-datsun-240z?variant=32238107459693 Quote Link to comment
