Wheel Fitment 1971 521 Datsun Truck 6 lug
robrizzo
  • Replies 33
With so much talk about a 5 speed in your 521, you are aware that the 71B 5 speed does not just drop in? Your, I assume, stock 4 speed is 26" and the 5 speed 31.5" so driveshaft will need to be taken to a shop and shortened by 5.5". In addition the 521 transmission mount will need to be sectioned and welded.
1 hour ago, Stoffregen Motorsports said:
Yeah if you like the feel of taking off in second.
  • Haha 1
On 4/19/2023 at 6:20 AM, datzenmike said:
The 521/620 720 and D21 Hardbody WD21 Pathfinder and probably Xterra all use the same 6 lug pattern. Toyota/Mazda/Isuzu  6 lug also fit as does GM and Ford.
I sent you a private message with a calculator tool for comparing what you have now with what might work. There is no easy answer for this, you have to make some measurements and plug the numbers in. Generally stock rims are probably zero offset but this can be confirmed with a tape measure.
Would you send me this calculator as well please?
