]2eDeYe Posted October 16, 2018 Report Share Posted October 16, 2018 Looks right at home in there. :) 1 Quote Link to comment
Ben_upde Posted October 16, 2018 Author Report Share Posted October 16, 2018 2 hours ago, ]2eDeYe said: Looks right at home in there. ? Definitely fits with very minimal clearancing! I’m super happy with how it’s going so far. Quote Link to comment
Stoffregen Motorsports Posted October 18, 2018 Report Share Posted October 18, 2018 I have said this before, if you need more clearance at the steering shaft, it is possible to convert the box/shaft/column assembly to use an exposed steering shaft and u-joints for more clearance. You could use a 720 box or modify your existing unit. A 720 box won't fit directly in as it mounts on the opposite side of the frame rail, but it could be used. Just an FYI. Looks great BTW. Quote Link to comment
Ben_upde Posted October 19, 2018 Author Report Share Posted October 19, 2018 9 hours ago, Stoffregen Motorsports said: I have said this before, if you need more clearance at the steering shaft, it is possible to convert the box/shaft/column assembly to use an exposed steering shaft and u-joints for more clearance. You could use a 720 box or modify your existing unit. A 720 box won't fit directly in as it mounts on the opposite side of the frame rail, but it could be used. Just an FYI. Looks great BTW. Since I won’t be using AC I was able to remove material from the accessory bracket to provide me with all the room I need. 1 Quote Link to comment
Ben_upde Posted October 26, 2018 Author Report Share Posted October 26, 2018 Crazy busy with work so not a lot has happened. Did get the radiator situation sorted put about 95% and started wiring the pig. Gonna bring the wiring thru the firewall with cannon plugs. Cleaner look, easier to work on and i’ll be putting the ECU inside so should be less resistant to damage Quote Link to comment
Ben_upde Posted October 27, 2018 Author Report Share Posted October 27, 2018 And the ultra boring part Quote Link to comment
Ben_upde Posted October 29, 2018 Author Report Share Posted October 29, 2018 Paint came in. Ordered 3 rattle cans for the engine bay and random spots so I thought i’d give her a quick color test. Super happy with the color ? Quote Link to comment
Ben_upde Posted October 31, 2018 Author Report Share Posted October 31, 2018 A little bit of wiring routed and loomed up ? 2 Quote Link to comment
Ben_upde Posted November 2, 2018 Author Report Share Posted November 2, 2018 Finally got my tires ordered and mounted! Am i ever pleased with the look ? Quote Link to comment
Ben_upde Posted November 3, 2018 Author Report Share Posted November 3, 2018 (edited) D21 spindles, rotors, calipers, brackets and sway bar along with Trooper rear rotors and calipers scored at the local u-pull-it yard for $170!! Edited November 7, 2018 by Ben_upde Spelling 1 Quote Link to comment
Ben_upde Posted November 6, 2018 Author Report Share Posted November 6, 2018 Engine wiring harness routed and loomed. Still gotta mount the ECU in the cab and wire it up. Also need to reroute the light wiring outside of the bay to keep it hidden. That’ll happen soon ? Quote Link to comment
Ben_upde Posted November 7, 2018 Author Report Share Posted November 7, 2018 (edited) Narrowed the D21 sway bar about 3.5” at the eyes, moved the 620 frame mounts rearward and tweaked the end links and viola!, front sway bar ? Edited November 7, 2018 by Ben_upde Spelling again 2 Quote Link to comment
Ben_upde Posted November 7, 2018 Author Report Share Posted November 7, 2018 And using most of the stock audi linkages and shifter mechanism I determined with a working mockup that everything feels great and will work exactly as anticipated. Shifter sits in exactly the same place as it used to so a little trimming and fabbing and the Audi shift box will fit right at home. Short video https://imgur.com/a/K0Fc22b 1 Quote Link to comment
Stoffregen Motorsports Posted November 8, 2018 Report Share Posted November 8, 2018 Audi in a Datsun? Sounds funny at first, but it looks good under the hood. Not sold on the green wire loom though... How did you narrow the sway bar? Quote Link to comment
Ben_upde Posted November 8, 2018 Author Report Share Posted November 8, 2018 17 minutes ago, Stoffregen Motorsports said: Audi in a Datsun? Sounds funny at first, but it looks good under the hood. Not sold on the green wire loom though... How did you narrow the sway bar? I think once the truck is painted and the color scheme is completed it’ll look a lot more at home. To narrow the sway bar I just heated an existing bend and tweaked the arm inward on each side. I have a spring shop locally that will re-heat treat it for me when i am to the point of finalizing everything. 1 Quote Link to comment
Ben_upde Posted November 9, 2018 Author Report Share Posted November 9, 2018 Charge pipe routed and mocked up. Not quite where I wanted to run it but in the interest of keeping a stock-ish appearance, behind the valance was not gonna work. Still need to source more 2.5” aluminum pipe so I can finalize and weld it all together. Pretty happy with how it fits and where it fits ? Coming thru the fenderwell and down, the silicone will not stay I didn’t have any 2.5” pipe left to mock up with, nor did I want to cut it up till I was sure where it would go I just have some scrap 2” sitting as a placeholder for now. Plenty of room for the larger pipe though This silicone step up connector will likely stay as a means of disassembly for maintenance/repair in the future ‘Custom’ duct tape temporary pipe hanger ? It all hides nicely behind the valance and lip though. Only the slightest hints of what’s going on from the sides ? Quote Link to comment
Stoffregen Motorsports Posted November 9, 2018 Report Share Posted November 9, 2018 Just curious why so many of the turbo builds I see in forums these days utilize the heavy gauge, what appear to be cast aluminum bends. It's not like you're running 100 lbs of boost, so regular old 14 gauge aluminum tubing should work. I do like how it's coming along, so don't think I'm a hater. 1 Quote Link to comment
Ben_upde Posted November 9, 2018 Author Report Share Posted November 9, 2018 (edited) 4 minutes ago, Stoffregen Motorsports said: Just curious why so many of the turbo builds I see in forums these days utilize the heavy gauge, what appear to be cast aluminum bends. It's not like you're running 100 lbs of boost, so regular old 14 gauge aluminum tubing should work. I do like how it's coming along, so don't think I'm a hater. Price. These cast bends are cheaper and have tighter radiuses than mandrel bent tubing. I think they were about $7 each versus $30+ for a mandrel bent aluminum elbow. I could make it out of steel but meh. Edited November 9, 2018 by Ben_upde 1 Quote Link to comment
Stoffregen Motorsports Posted November 10, 2018 Report Share Posted November 10, 2018 Ok. I do realize the bend radius is tighter, but I wasn't aware of the cost issue. I use only tubing on my intake plumbing jobs. Also, I bit the bullet and bought a Kramer bead roller for small tubing a couple years ago. It was not cheap. I use my large bead roller for any tubing over 3". So I guess I'm invested in tubing... Quote Link to comment
Plusnone Posted November 10, 2018 Report Share Posted November 10, 2018 On 11/8/2018 at 7:59 AM, Stoffregen Motorsports said: Audi in a Datsun? The aud-dat-citi... All kidding aside, I'm enjoying the build! 1 Quote Link to comment
Ben_upde Posted November 10, 2018 Author Report Share Posted November 10, 2018 25 minutes ago, Plusnone said: The aud-dat-citi... All kidding aside, I'm enjoying the build! It's not for everyone. Hell i’m literally building the truck for only myself. It’s a lifetime keeper deal ? 1 Quote Link to comment
Ben_upde Posted November 10, 2018 Author Report Share Posted November 10, 2018 2 hours ago, Stoffregen Motorsports said: Ok. I do realize the bend radius is tighter, but I wasn't aware of the cost issue. I use only tubing on my intake plumbing jobs. Also, I bit the bullet and bought a Kramer bead roller for small tubing a couple years ago. It was not cheap. I use my large bead roller for any tubing over 3". So I guess I'm invested in tubing... If you do it more than once in a blue moon it might make sense to buy benders and bead rollers. I’d honestly prefer to just have a single mandrel bent tube in the shape I want with a bead rolled at each end but nobody in the area has the capability and I cannot front those costs for practically zero return. Always compromises but in the end it’ll do exactly what I need it to so i’m happy. 1 Quote Link to comment
Ben_upde Posted November 21, 2018 Author Report Share Posted November 21, 2018 Belltech 2” D21 drop spindles ready to go on Summit racing fuel cell modified slightly for an in-tank Walbro 450 pump ready to mount and plumb Quote Link to comment
Lawlis Posted November 25, 2018 Report Share Posted November 25, 2018 So what systems are you swapping other than the drivetrain? I think it's a great idea and something I'd like to do as well. Maybe a 2.0T for me. Quote Link to comment
datzenmike Posted November 25, 2018 Report Share Posted November 25, 2018 Other systems? Well the EI (electronic ignition) distributor (aka matchbox) and matching coil from a '78 and up is a nice ignition up grade. Better output and no points to replace. A higher output internally regulated alternator is nice. A high volume KA oil pump. A front disc brake kit. A 5 speed was optional from '77 up. Quote Link to comment
