tzagi Posted September 24, 2017 Report Share Posted September 24, 2017 I'm having a hard time finding a balancer at a sane price, what other engines can the balancer be sourced from?, how about a L20B? or the z24? going by looks alone ....it looks the same. Quote Link to comment
Doctor510 Posted September 24, 2017 Report Share Posted September 24, 2017 They are engine specific, not super expensive, last one I saw was about $180, check flea bay. Quote Link to comment
Stoffregen Motorsports Posted September 24, 2017 Report Share Posted September 24, 2017 I found this, but something about it doesn't seem right (if the pic is the actual part). Does yours look like this? http://www.jegs.com/i/Professional-Products/428/80055/10002/-1?CAWELAID=1710581600&CAGPSPN=pla&CAAGID=44693592161&CATCI=pla-199631605751&CATARGETID=230006180039218651&cadevice=c&gclid=EAIaIQobChMIhsjO2pS-1gIVTlx-Ch2MkQP-EAkYAiABEgJKn_D_BwE Also found this at Rock Auto - DAYCO PB1212N Quote Link to comment
420n620 Posted September 24, 2017 Report Share Posted September 24, 2017 > https://seattle.craigslist.org/sno/pts/d/datsun-engines-trans-and-parts/6317263480.html Quote Link to comment
datzenmike Posted September 24, 2017 Report Share Posted September 24, 2017 I found this, but something about it doesn't seem right (if the pic is the actual part). Does yours look like this? http://www.jegs.com/i/Professional-Products/428/80055/10002/-1?CAWELAID=1710581600&CAGPSPN=pla&CAAGID=44693592161&CATCI=pla-199631605751&CATARGETID=230006180039218651&cadevice=c&gclid=EAIaIQobChMIhsjO2pS-1gIVTlx-Ch2MkQP-EAkYAiABEgJKn_D_BwE Also found this at Rock Auto - DAYCO PB1212N '70-'83 would be the L24/26/28z and zx. I thought there was an outer ring sandwiching a rubber sleeve? What are the bolt holes for? extry pulleys? 1 Quote Link to comment
racerx Posted September 24, 2017 Report Share Posted September 24, 2017 Yep...ad is misleading. Only Z has balancer. Maybe pic is just a representation of said part and not actual. Quote Link to comment
I'm BLUE Posted September 24, 2017 Report Share Posted September 24, 2017 '70-'83 would be the L24/26/28z and zx. I thought there was an outer ring sandwiching a rubber sleeve? What are the bolt holes for? extry pulleys? ...... the 2-threaded bolt holes ?......allows for the puller tool to bolt up , and carefully evenly pull off the balancer during disassembly. I'm sure it would have to be the case 2 Quote Link to comment
datzenmike Posted September 24, 2017 Report Share Posted September 24, 2017 ...looks solid though. Quote Link to comment
distributorguy Posted September 25, 2017 Report Share Posted September 25, 2017 That's a 2-piece. The outer ring is shared with MGB. The inner hub is different. You can see the rubber "ring" on the face, separating the two halves. Quote Link to comment
racerx Posted September 25, 2017 Report Share Posted September 25, 2017 Looks just like the harmonic balancer on my 65 mustang. The rubber piece eventually gets cracked and worn and your timing marks will be off then you will scratch your head why ur car is pinging. When mine was went out, my timing was off by 10 degrees Quote Link to comment
Stoffregen Motorsports Posted September 25, 2017 Report Share Posted September 25, 2017 The parts description says something about single versus double groove. So apparently the application description covers more than stock applications. Quote Link to comment
tzagi Posted September 25, 2017 Author Report Share Posted September 25, 2017 I found this, but something about it doesn't seem right (if the pic is the actual part). Does yours look like this? http://www.jegs.com/i/Professional-Products/428/80055/10002/-1?CAWELAID=1710581600&CAGPSPN=pla&CAAGID=44693592161&CATCI=pla-199631605751&CATARGETID=230006180039218651&cadevice=c&gclid=EAIaIQobChMIhsjO2pS-1gIVTlx-Ch2MkQP-EAkYAiABEgJKn_D_BwE Also found this at Rock Auto - DAYCO PB1212N Thanks, the Jegs link is a single pulley...and I need 2 as I have ac. too bad as the price is good. The dayco is about $200...ouch. No one knows if a L20b is a fit? Quote Link to comment
datzenmike Posted September 26, 2017 Report Share Posted September 26, 2017 Pretty sure they will fit. The Z20/22 and 24 seem to have a balancer on them and are three pulley for air/PS. All L20Bs have a single solid pulley excerpt the S10, last year 620 and first year 720 L20Bs but they also had air con. Quote Link to comment
datsunaholic Posted September 26, 2017 Report Share Posted September 26, 2017 . All L20Bs have a single solid pulley excerpt the S10, last year 620 and first year 720 L20Bs but they also had air con. All L20B's I've seen had double pulley, one for the Alternator/Water pump and one for the smog pump, except trucks with A/C that had a 3-row pulley. Cars with A/C ran the smog pump off the A/C compressor pulley. Only single-row ones I've seen for L-series were L16/L18 WITHOUT A/C or a Smog pump (some L16s had a smog pump, so 2 row), and they have the timing marks in the wrong place for anything else. In all cases, there were a cast pulley, not a damper. Quote Link to comment
racerx Posted September 26, 2017 Report Share Posted September 26, 2017 Had L16, L18 and L20, never had balancer. Timing marks were different, L16 was on pulley, L20 had a tab. Quote Link to comment
datzenmike Posted September 26, 2017 Report Share Posted September 26, 2017 Sorry I said single. Meant solid only. The third V was air con. I think the S10 and '79 and '80 L20Bs had three even if not used? Quote Link to comment
Stoffregen Motorsports Posted September 26, 2017 Report Share Posted September 26, 2017 Here's an original one on ebay, but it looks pretty ratty. You can have these re-vulcanized, but it costs about $300 to get done. http://www.ebay.com/itm/like/182774970538?chn=ps&dispItem=1 Quote Link to comment
racerx Posted September 26, 2017 Report Share Posted September 26, 2017 Don't look good. The hard rubber part maybe all cracked up and the ur timing will be off cuz they do twist. Quote Link to comment
tzagi Posted September 27, 2017 Author Report Share Posted September 27, 2017 > https://seattle.craigslist.org/sno/pts/d/datsun-engines-trans-and-parts/6317263480.html Emailed him....he wants $150 PLUS $100 core....Somebody is "high" Quote Link to comment
racerx Posted September 27, 2017 Report Share Posted September 27, 2017 He isn't serious. If he were he would sell it much cheaper. But I am wondering if the OP gave the JY a chance. Quote Link to comment
tzagi Posted September 27, 2017 Author Report Share Posted September 27, 2017 He Is serious alright... here is a quote: I sell good used ones for 150.00 plus a 100.00 core charge. For your old one to be acceptable as a trade in, all the metal must be in good shape. I can also get an aftermarket pulley that only has one groove so it won’t handle AC. They sell for about 215.00. Let me know. Oliver yes, I have been eyeballing the JY, we got a 280zx and a 83 maxima. I suppose I'll be there Friday busting my knuckles....and I was trying to avoid that! Quote Link to comment
racerx Posted September 28, 2017 Report Share Posted September 28, 2017 Meant he isn't serious about getting rid of his stuff. If he was, then he would sell very cheap. Quote Link to comment
tzagi Posted September 28, 2017 Author Report Share Posted September 28, 2017 To each their own.. Quote Link to comment
420n620 Posted September 28, 2017 Report Share Posted September 28, 2017 Emailed him....he wants $150 PLUS $100 core....Somebody is "high" horry crap, Oliver must be going to take it all with him to his grave. Sorry I posted that CL link now. everything is "HIGH" price on the left side of Washington state since pot became legal. :no: 1 Quote Link to comment
racerx Posted September 28, 2017 Report Share Posted September 28, 2017 I don't get it. He states on Craig's that he needs to liquidate and move to a smaller warehouse...smh Quote Link to comment
