hughdogz Posted January 26, 2009 Author Report Share Posted January 26, 2009 "Skib badass! Paul FTW on the work and the price and Hugh FTW on the first time porting" Thanks Man!! You're next, Haha:D Quote Link to comment
slodat Posted January 26, 2009 Report Share Posted January 26, 2009 Looks really good Hugh! Are you willing to share how much your bill was with Paul? Quote Link to comment
hughdogz Posted January 26, 2009 Author Report Share Posted January 26, 2009 Looks really good Hugh! Are you willing to share how much your bill was with Paul? Thanks Man! :) Well, I don't want to reveal the exact amount, since I was able to get a "good buddy" discount (which was pretty considerable), and the fact that I did pretty much all the porting work myself. He just sold one a couple weeks ago on hybrid link for ~$2200. Although that one had oversized valves, a Kameari adjustable cam sprocket, and he did the porting and the chambers are within 1/4 cc of each other. For all the machine work, assembly, etc. I had Paul do for me, list price is about ~$1000 (new lash pads, valve seals, new shortened valve guides, valve seats, etc. were included) Quote Link to comment
Skib Posted January 26, 2009 Report Share Posted January 26, 2009 "Skib badass!Paul FTW on the work and the price and Hugh FTW on the first time porting" Thanks Man!! You're next, Haha:D better get that thing on, im catchin up :fu: Quote Link to comment
hughdogz Posted January 27, 2009 Author Report Share Posted January 27, 2009 better get that thing on, im catchin up :fu: No kidding. NO MORE BEERS until I get my ZX running again! (we'll so how long that lasts) If it wasn't for me being so broke right now, I'd be throwing a few back as I type. :glare: Quote Link to comment
hughdogz Posted February 1, 2009 Author Report Share Posted February 1, 2009 (edited) Skib and Slodat, the head chamber CC's are within 1/4 cc of each other, not 1 cc (anymore). Now they are exactly 55.25 - 55.5 cc's. Stock chamber volume is 56.3cc according to L28 Engine Calculator (on Atlantic Z). It is a cool calculator, my CR varies between 7.15:1 and 7.17:1 (down from 7.31:1 stock) It makes sense now on the invoice where the chamber cc'ing was done twice. Paul had to set the seat height to adjust for the cc's for my not-so-uniform first try. Then he had to check it again. Now they are within 0.45 % change of volume with each other. ============= Anywhoo, here are some pics from last year when I was working on creating the sub-harnesses for the Wolf EMS I'm running This is the "Ron Tyler style" power supply panel I reverse-engineered from some photos on hybridz: A little closer: (Aircraft circuit breakers from Waytek) Outside (I used Aluminum sheet metal, then scored it with a pizza cutter, then bent it (no press brake). I can use my CAD software to generate the sheet metal flat pattern)): New fuel rail and injector harness: First the rail was set up for barbed injectors, then I converted it to 11mm o-ring, then I converted it to 14mm o-ring to run the RX7 injectors. sheesh! Coil harness: It was a pain to make 2 GM V-8 harnesses into one custom inline-6 harness!! Here is most of the system: Coils installed: I had to punch a hole in the 6061 Aluminum bracket to retain the CHTS (cylinder head temp sensor) Electronic boost controller PWM (pulse width modulated) controlled by the Wolf: Main power breaker and ground buss-bar. This way, you don't get voltage differences for the system, or have to run ground voltage differentiators. Passenger footwell, I tucked up all the wiring I made behind the dash (it's all hanging out here). You can see where I mounted the power supply panel too! Behind the glove box where I have the Wolf's connector blocks. You can also see the vacuum line for the internal MAP sensor. I tee'd off to run the Innovate LMA-3 datalogging MAP sensor. This is how small the Wolf ECU is! I can still put a few pairs of gloves in my glovebox, Ha! Here's an old pic of my auxillary wiring (for sensors like narrow band O2, I went with a different tach adapter though). I made that bracket for another power distribution block. You can see my old stock ECU too. Here is how I made an Intake Air Temp sensor bung and idle regulator bracket. Air temp sensor is a Bosch unit that has an o-ring seal (popular with the Audi A4 / A6's. It has a very linear T vs V response curve. If I keep it away from the manifolds, it will be less likely to get heat soak. The IAT will mount on the underside of the tube after the intercooler exit. (I know...no one likes my welding.. :lol: Inside: The Idle air mounts to the block where the A/C used to be: I made another bung on the charge pipe to fit another fitting to run to the IAC where you see the line plugged now. Maxima 3-wire TPS painted and new mounting holes (it was brown, now wrinkle-painted). The Weber 65mm throttle body is cool since it has so many ports you can use before and after the throttle plate! : Wrinkle painted the trigger cover (formerly known as a distributor cap ): I'd better go work on finishing up the exhaust. I've been draggin' ass on that project... Edited February 1, 2009 by hughdogz Quote Link to comment
hughdogz Posted February 3, 2009 Author Report Share Posted February 3, 2009 (edited) Here's how I made the Aero ducting...the project is not finished yet, but this was a good improvement. :) This is what I need to block off for better aerodynamics and directing the air into the intercooler and radiator area: These are the patterns for the sides and the "tester" piece I had to sacrifice: I bought some scraps from Pacific Metals in Tualatin, right off T-Sherwood road (~$6.00 per pound) (my Decepticon flat-pattern! ) Folded: All three pieces: Driver side: (that hole in the side piece is where I mount my horn bracket) Passenger side: Thanks for looking! Edited February 3, 2009 by hughdogz Quote Link to comment
Edz280zx Posted February 3, 2009 Report Share Posted February 3, 2009 Very nice!!! I like it alot. Quote Link to comment
hughdogz Posted February 11, 2009 Author Report Share Posted February 11, 2009 I can't believe it's been three months and I still haven't finished yet! Next, I'll grind down the welds on the DP and then make a couple more mounting brackets for the center and rear sections... Almost all of the 3" pieces are slightly different sizes, so I had to port out any "steps" the best I could. Hopefully I'll make more progres tomorrow. Before: After: More "porting" At least now I got the "kink" out where the flow has to bend in the flex pipe: 1st attempt: Quote Link to comment
Icehouse Posted February 11, 2009 Report Share Posted February 11, 2009 Dude that wiring is SO nice!! I'm inspired :D What horns are you running? I swear I saw those in a STI.... Quote Link to comment
hughdogz Posted February 11, 2009 Author Report Share Posted February 11, 2009 Dude that wiring is SO nice!! I'm inspired :D What horns are you running? I swear I saw those in a STI.... Thanks Icehouse. That wiring was a challenge to say the least ;) I'm running these Hella Supertone Horns Horn Kit PN: 85115 I've seen STI guys rockin' two pairs sometimes! They are the loudest horns I'ver heard that aren't airhorns! (72W / 118 dB) Quote Link to comment
hughdogz Posted May 5, 2009 Author Report Share Posted May 5, 2009 I made a little progress this weekend. I've mostly spent days cleaning grease off my oil pan, engine mounts, engine bay, etc. after pulling the motor out. The paint on the inside of the oil pan started flaking off like crazy when it dried. Not sure if it was caused by the solvents I used...is this common? Anyway, I'll have to repaint it, since it would most likely clog the oil pickup screen. Here is my block painted. I had to clean it with engine degreaser, then B-12 Chemtool and finally rubbing alcohol. I think it turned out pretty nice. First I sprayed it with two coats Thermo-Tec "cool-it" 1200-1800 degreee paint. It looks like chrome, I almost wanted to keep it this way! :blink: Then I sprayed it with 1.5 cans of Dupli-Color paint to match the body paint (2000 Acura Electron Blue Pearl). It may not look like much progress, but Man did it take a lot of time and loss of braincells. :o Now back to fighting the "rust wars" / bubbling paint in the engine bay! :eek: Quote Link to comment
hughdogz Posted May 5, 2009 Author Report Share Posted May 5, 2009 (edited) Thanks Man!! I saw your driving vid too. Sounds nice and rumbly :D Edited May 5, 2009 by hughdogz Quote Link to comment
Skib Posted May 5, 2009 Report Share Posted May 5, 2009 Thanks Man!! I saw your vid too. Sounds nice and rumbly :D :D just gotta get the tuning done. you workin in the garage tonight? I can roll by and bring your stuff too Quote Link to comment
hughdogz Posted May 5, 2009 Author Report Share Posted May 5, 2009 Yeah, I'm always here...but I might go walk down to 7'evy to get another short-case of Henry's while we're in between storm sqalls :rolleyes: Come on over if you want...later! -hughdogz Quote Link to comment
DISLEXICDIME Posted May 5, 2009 Report Share Posted May 5, 2009 man that looks good nice work hugh Quote Link to comment
Bleach Posted May 5, 2009 Report Share Posted May 5, 2009 get it together before Canby! :D Quote Link to comment
hughdogz Posted May 28, 2009 Author Report Share Posted May 28, 2009 More progress pics... Here is my painted oil pan. What a saga! :blink: I cleaned the slude out of the inside of it using a little bit of Gunk engine brite. I'm not sure if it was from the solvent, but the paint on the inside started flaking off when it dried. For sure it would clog the screen in the oil pickup tube. I cleaned off all I could, and a week later it started flaking more!! I had to get it hot-tanked, then I painted it with two coats of etching primer, then 3-4 coats of 500 degree gloss black engine enamel (no way I was going to paint the inside again). Here you can see I finished polishing the front timing cover. I must have spent ~20 hours on it. :confused: Since the turbo I'm installing needs a spacer, the stock oil drain line isn't long enough. So I had Oil Filter Service here in P-town braze on a -10 AN bung: Then I had to repair some bubbling paint on the brake booster from brake fluid leaking out of the master cylinder. Then I had to remove rust on the driver's side frame rail since the brake fluid leaked all over that paint too! :mellow: Quote Link to comment
SIXTY-NINE-DIME Posted May 29, 2009 Report Share Posted May 29, 2009 sickest z ive seen thus far! Quote Link to comment
Edz280zx Posted May 29, 2009 Report Share Posted May 29, 2009 Very good work...hope mine looks half as good when I do the turbo conversion! Quote Link to comment
Bleach Posted May 29, 2009 Report Share Posted May 29, 2009 It just keeps getting better. That engine is so clean! Now I'll just have to do better for Canby next year :D Quote Link to comment
b210in Posted May 29, 2009 Report Share Posted May 29, 2009 wow, very nice and clean, what are the specs on the turbo? Quote Link to comment
hughdogz Posted May 29, 2009 Author Report Share Posted May 29, 2009 (edited) wow, very nice and clean, what are the specs on the turbo? Thanks! I totally appreciate the comments Guys. :P I had Ken Peak at Phoenix Turbos custom build it for me. It is a T3/T04E, 50 trim compressor wheel in a .60 A/R housing. It has a .63 A/R stage III turbine wheel that has the .63 A/R housing HPC ceramic coated!! I got it with a (late) Ford 5-bolt housing so I can use the "Ultimate Internal Wastegate" I got from ATP turbos. Here are some more pics of the setup: Notice the "Bullet" low-drag nut to enhance airflow: I'll post up some pics of the oil flanges later: Here is the "Ultimate Internal Wastegate". I didn't want the hassle of modding the stock turbo exhaust manifold for an external wastegate just yet. A divorced external wastegate downpipe like my friend John Kurzals made seemed like a huge challenge as well. I hope I don't get much boost creep with this unit. It looks like it should flow really well! S130's don't have much room for a DP or external wastegate compared to the S30 turbo'd (~3 inches less space to the firewall). So, this gave me good flow and already has a 3" flange for easy disconnection from the downpipe. Another shot: Stacked! LOW restriction! (hopefully) Edited May 29, 2009 by hughdogz Quote Link to comment
]2eDeYe Posted May 29, 2009 Report Share Posted May 29, 2009 Awesome attention to detail. Love it :cool: Quote Link to comment
