mklotz70
Valve cover make over(pic overload)
Had a huge "to-do" list today....so I blew it all off and played...I mean worked, on something I've been wanting to since I got the mill.
Almost everyone knows that the L series valve cover with the ridges up over the timing hump are getting pretty rare. The have a 1/4 turn cap on them that tends to leak oil pretty badly. The valve cover with the screw in cap is much better about staying clean, but, they're a dime-a-dozen. What most people don't know is that there is a version of the ribbed cover that has the twist in cap. According to Epperly(of ZTherapy)....they are extremely rare. Not sure why...maybe a JDM only kinda thing. He has at least one of any Datsun item that is collectible and even he doesn't have one. Supposedly...they're worth a nice chuck of change. I'm doing it for the "wow" factor on Paula's 521 since it will mostly keep an L series forever :)
Starting to get things laid out. Plans changed a bit after the first pic. I was going a slightly different route...so disregard the hole saw on the ribbed cover.
First up...get the threads out of the common cover.
I then took the slug with the threads in it and chucked it up in the lathe(which has been down for a week...just got it fixed :)) I turned off the excess and made a step in it.
I made it so the step sat just inside a small lip in the ribbed cover.
Now to set up the ribbed cover. I checked the level of the mill as a reference, then shimmed the cover and clamped it. 2/10ths of a degree is close enough for me :)
Using a wobbly and the DRO, I located center and setup the boring head.
Got it really close. The hole or the slug can get shaved a bit to make them fit. I was still hemming and hawing over whether to TIG it or jb weld it. I could have gotten the fit close enough to use loctite...anyway..
Share this post
Link to post
Better safe than sorry...figured I'd post that before I lost it.
The ribbed cover had previously been covered with wrinkle paint...which is a bit harder to get off than smooth paint. I used paint stripper in a spray can...works pretty well. Soaked it down and let it sit for a bit. I did clean the oil and grease off first.
Here's what it looked like after I sprayed it with the garden hose. I dried it off and sprayed it again.
It sure loved the second application!!
  • Like 3
Share this post
Link to post
Pretty damn cool Mike!
I just want a valve cover like Steve has on his 2.5 challenge car - "Datsun 1300 OHC"
Share this post
Link to post
...so about this time, I got fed up with fighting with the old camera...had to press the button 2-10 times to get it to snap a pic.....so I went and bought an 8.2mp that will slip in my pocket nicely for car shows :) Because of the resizing on photobucket...won't be much of a noticeable difference.....anyway....
I realized that the slug was standing a bit too "proud" of the top....so I put it back in the lathe and trimmed it some more.
Starting to see it come together....
As long as I was at it, I thought I'd clean up the elephant cap and use it :)
Share this post
Link to post
A flat file and a sanding block got the nicks out of the ribs and lettering. They'll get polished in a bit.
Setup a test weld for the tig...like it...decided to do the real thing
First inch came out fine.....
I didn't notice that I'd run out of gas.....I nearly f'd up the cover. I think I can clean this up and finish it without too much grief. If not, I'll cut another slug from another cover and bore this hole out again :) It's all about the toyls (spelled correctly...Paula calls them toys, I call them tools :)
.....maybe more tomorrow...after I get the gas :)
Share this post
Link to post
Thanks guys :)
Now I remember why I try to squeeze it all in one posting......other guys viewing/posting make it hang up.....so even though I saw nothing happening at my end....it posted the same thing 4 times :( Oh well. Maybe a mod can clean it up a bit :)
bed time!
Share this post
Link to post
Very cool I like that. Is that a 9x20 lathe? I noticed you had a quick change tool post. Which mine had one. I've pondered the idea of building a aluminum sheetmetal valve cover just for the hell of it.
Share this post
Link to post
I deleted the extras, but thought that it would leave a post...just empty...looks like it got rid of the whole thing :)
Share this post
Link to post
Mike thats to cool! I want that cap on my SR cover, I better send a valve cover to you :D
Share this post
Link to post
mike you are having waay too much fun. i demand that you stop right now!:lol:
looks awesome and is very unique.
did you bead blast that elephant oil cap?
the 1600 valve covers i've seen have the spark plug wire bracket riveted or pinned in instead of a bolt?
Share this post
Link to post
me - I like the Datsun 1600 valve cover unribbed... my opinion
They are my preference too. Part of the appeal was the rarity of the one I'm trying to fake. Plus....once I powder coat it, the ribs look extra cool.
Dude...you have access to better equipment then me and you can tig aluminum better too.......................so if you want it f'd up...send it on down :)
The only thing I might stop is the posting ....so I have more time in the shop!! :)
I actually cleaned it in the parts cleaner with a toothbrush and a brass brush. I run the pressure on the glass beads way too high...if would have fogged it. Glass beads are actually supposed to be run down around 30-40psi so they don't break on impact. If they stay round, they work great for polishing brass and aluminum.....but I use mine for rust removal and cleaning.....so 90psi it is! :)
As for the bracket...I haven't looked to see if the hole has threads. If it doesn't, it will have. Then it will get a chrome button head :)
Share this post
Link to post
Speaking of the pins...the baffle inside the cover was loose and rattled a bit...so I gave them a whack or two with a drift punch and a hammer....tightened them right up :)
Share this post
Link to post
What SDSURF refering to Mike is the Datsun 1600 OHC unribbed and screw on cap. Another valve cover variation.
I've never seen ribbed valve cover with the screw on cap if they exist.
As always, your ideas are very unique and impressive work.
Fortunately all 3 1600 valve covers I'm using have new cap and not experiencing oil leaks from the top.
Share this post
Link to post
SWEET! So how much is one of those Elephant caps worth? They're pretty cool. :thumbsup:
No clue...I heard they were getting hard to find, so I hung onto it.
Looks like fun Mike! I like the ribbed one. Looks different. :D
Thanks. I knew what he meant....that's actually my preference too. In fact, had I been paying attention, I would have dug out a nissan ohc cover and left the datsun one alone :( I probably have a 1600 non-ribbed running around here somewhere. I don't have any more ribbed ones....that I know of...so this will probably be the only one I do.
It's monday...I'm going to hook up the new argon bottle to the tig and call it a day :)
Share this post
Link to post
You know I never knew what folks meant by Elephant Cap! Now I know!
Too cool Mike! Man it has to feel so awesome to make two piece that fit so well together with such precision.
Share this post
Link to post
Thanks.
It felt great until I f'd up the tig welding!! I'll probably try to fix it tomorrow.
Share this post
Link to post
I prefer ribbed for her pleasure. :D
Seriously, very nice. I'm gonna post a link to this thread on the Bluebirds list.
Share this post
Link to post
Wait a minute....you modded the valve cover so it would leak more??!!! :blink:
Share this post
Link to post
