iwayman Posted October 16, 2014 Report Share Posted October 16, 2014 I bought a pair of these LED bulbs a few weeks back with the idea that they will increase light output and decrease heat from the conventional bulbs. With the bulbs installed for my brakes, as soon as I trigger the brake switch every exterior light comes on (headlights, side markers, reverse, brakes). This does not happen with conventional dual filament bulbs installed. Any ideas for what can be done? Quote Link to comment
danfiveten Posted October 17, 2014 Report Share Posted October 17, 2014 there is something when you run leds you need to get that goes on the wires, led's put alot of strain on a cars electrical system, your lucky you didnt fuck up your harness. Quote Link to comment
danfiveten Posted October 17, 2014 Report Share Posted October 17, 2014 http://www.jpcycles.com/product/ZZ38202?utm_source=none&utm_term=&adpos=1o2&creative=44525597410&device=c&matchtype=&network=g&gclid=CMXqxpOyssECFeZAMgodIjoAlg Load equilizers Quote Link to comment
danfiveten Posted October 17, 2014 Report Share Posted October 17, 2014 Similiar issue. http://www.clubcobra.com/forums/all-cobra-talk/119250-led-brake-park-turn-signal-bulbs-caused-electrical-malfunction.html Yes they require less energy, but your car is meant to handle the load of the dual filiment bulbs. Quote Link to comment
datzenmike Posted October 17, 2014 Report Share Posted October 17, 2014 there is something when you run leds you need to get that goes on the wires, led's put alot of strain on a cars electrical system, your lucky you didnt fuck up your harness. Bubbish!!!!! :lol: LEDs draw almost no power so almost no strain on the electrical system. No way will they harm the system drawing less power. Because they draw less you signals may not work. Older systems are load dependent, the more bulbs the faster it flashes. Newer ones are solid state and flash at the same speed. This post is about brake lights anyway not turn signals. With the bulbs installed for my brakes, as soon as I trigger the brake switch every exterior light comes on (headlights, side markers, reverse, brakes). This does not happen with conventional dual filament bulbs installed. Any ideas for what can be done? Check that the contacts are identical. Looks like those wide contacts (on the bulb) are bridging across the plug terminals and brakes will be powering the running light side. 1 Quote Link to comment
danfiveten Posted October 17, 2014 Report Share Posted October 17, 2014 I know plenty of people that have installed led's and fucked up their electrical in their older cars. Hell im one of them. Quote Link to comment
danfiveten Posted October 17, 2014 Report Share Posted October 17, 2014 screw it. Quote Link to comment
shacks510 Posted October 17, 2014 Report Share Posted October 17, 2014 I was at pep boys the other day looking at those same bulbs. They had the oval contact point bases and round contact bases. I'd try the round contact ones just because that's what the original bulbs are. I'm scared to try them now. My dad got those LED bulbs for his '08 Ford Superduty, and when he'd turn on the turn signals, all the side marker lights would flash (dually flare lights) when they weren't supposed to. There was also the smell of burning electrical when they were on. Can't say why it happened. Quote Link to comment
datzenmike Posted October 17, 2014 Report Share Posted October 17, 2014 Not the fault of the LEDs. The bulb sockets are cross connecting all the lights. There should be no damage to the wiring as everything is fused. Quote Link to comment
Guest Rick-rat Posted October 17, 2014 Report Share Posted October 17, 2014 I know plenty of people that have installed led's and fucked up their electrical in their older cars. Hell im one of them. You should know better than to argue with King shit, he knows everything aboot everything, even if you saw it and had it happen to you :angel: All my lights are bright, even the dash lights, just be sure you have good grounds and the regular bulbs work just fine 1 Quote Link to comment
izzo Posted October 17, 2014 Report Share Posted October 17, 2014 LED's draw no power. What the fuck did they do to their own systems/ There is a load thing you can buy. but... It's to help your system. Basically when you run LED vs stock bulb, sometimes your flasher will flash to fast thiniking the regular bulb is burned out, since the LED doesn't draw enough power. You put those on, and it makes the system think its a regular bulb pulling regular power. IDK why your friends had electrical issues. I have to disagree with the statement LED's have fucked up electrical systems. As much as I would like to agree with you. PS, to the OP... Don't buy that over priced garbage :| Much better quality at realistic prices. https://www.superbrightleds.com/ Some load resistors. https://www.superbrightleds.com/cat/flashers-load-resistors/page/2/ Read up on the website FAQ. You can email them also for free support. Ask them if they have ever had issues with LED's fucking up someones electrical in older cars just to be safe. Quote Link to comment
MikeRL411 Posted October 17, 2014 Report Share Posted October 17, 2014 LED's draw no power. If you believe this, I have a perpetual motion machine that you can have for a Million Dollars [American]. A "bulb" that draws no power CANNOT produce a light output. PERIOD! Quote Link to comment
thisismatt Posted October 17, 2014 Report Share Posted October 17, 2014 Could be that the contacts are clocked differently with respect to the bayonette pins. Sounds like you're backfeeding 12v to a ground or switched hot, turning on relays...not really sure. The fact that they claim to not trigger a CAN BUS error makes it sound like they already have a "load equalizer" built in. Quote Link to comment
datzenmike Posted October 17, 2014 Report Share Posted October 17, 2014 Tim's exaggerating for effect. LEDs draw very little current for the light produced. Extremely efficient. Quote Link to comment
banzai510(hainz) Posted October 17, 2014 Report Share Posted October 17, 2014 I notice th same thing with the contacks they look long and may bridge the socket contacks, the turn signal Blinker Cans use a Bimetal switch which heats up and thus makes the click sound also so it needs more current so the metal bends.I seen new solid state flasher units now than can be switched. Im waiting fo soemone to try this and give a report back http://www.deltalights.com/?q=store#!/LED-5-3-4-HIGH-BEAM-HEADLIGHT-SYSTEM-(Pair)/p/29120228/category=2078037 Quote Link to comment
iwayman Posted October 18, 2014 Author Report Share Posted October 18, 2014 Not the fault of the LEDs. The bulb sockets are cross connecting all the lights. There should be no damage to the wiring as everything is fused. This makes sense, I will look into resolving it. PS, to the OP... Don't buy that over priced garbage :| Much better quality at realistic prices. https://www.superbrightleds.com/ Some load resistors. https://www.superbrightleds.com/cat/flashers-load-resistors/page/2/ Read up on the website FAQ. You can email them also for free support. Ask them if they have ever had issues with LED's fucking up someones electrical in older cars just to be safe. Fat discounts for working at a parts store :rofl: Quote Link to comment
Son_of_a_Datsun_Guy Posted October 18, 2014 Report Share Posted October 18, 2014 Check that the contacts are identical. Looks like those wide contacts (on the bulb) are bridging across the plug terminals and brakes will be powering the running light side. Called it Ian. Quote Link to comment
CrazyHawaiian760 Posted October 19, 2014 Report Share Posted October 19, 2014 I use LED bulbs in my dash....works great! 1 Quote Link to comment
a.d._510_n_ok Posted November 2, 2014 Report Share Posted November 2, 2014 I purchased these from autozone a while back and really wasn't impressed their output or performance. Is the style posted by iwayman a better design? Quote Link to comment
datzenmike Posted November 2, 2014 Report Share Posted November 2, 2014 Better re read the posts about the contacts causing a problem.. 1 Quote Link to comment
a.d._510_n_ok Posted November 2, 2014 Report Share Posted November 2, 2014 Better re read the posts about the contacts causing a problem.. i got that but is one style better performing than the other? Quote Link to comment
izzo Posted November 2, 2014 Report Share Posted November 2, 2014 LED's draw no power. If you believe this, I have a perpetual motion machine that you can have for a Million Dollars [American]. A "bulb" that draws no power CANNOT produce a light output. PERIOD! C'mon man really? You really think I was saying literally they were drawing absolutely no power? Tim's exaggerating for effect. LEDs draw very little current for the light produced. Extremely efficient. Haha, this guy gets it... LEDs on a turn signal draw so little power that sometimes the flasher thinks the bulb is not there or burned out and will cause a fast signal indicating so. You can get a little adapter to fix that from the site I listed. 1 Quote Link to comment
iwayman Posted November 3, 2014 Author Report Share Posted November 3, 2014 So far I've given up on the bulbs for now. Not seeing any visible ways the contacts could be cross connecting, also installed resistors in-line to no avail. Quote Link to comment
