Healight Adjustment Spring NLA - Substitutes?
  • Replies 11
If you are really cheap [begs the question, this is RATSUN] steal the springs that retract the cartridge in a ball point pen before you chuckthat BIC.  A little twist here and there with needle nosed pliers and a cut with a side cutter and you have replacement tension springs for just about anything.
