kaoss Posted September 28, 2015 Author Report Share Posted September 28, 2015 Taped off And seam sealed. 3 Quote Link to comment
RedSquare Posted September 28, 2015 Report Share Posted September 28, 2015 Nice. I always wanted to do a tape and seal job like that on a car. Keeps things neat. We do it this way on the aircrafts we work on here at work. 1 Quote Link to comment
kaoss Posted September 30, 2015 Author Report Share Posted September 30, 2015 Got the POR on. Next is working on the courier bearing mount, I don't think I have it right but maybe I do and I don't need to dick with it. 3 Quote Link to comment
kaoss Posted October 13, 2015 Author Report Share Posted October 13, 2015 And she's back on, hopefully forever. 8 Quote Link to comment
kaoss Posted October 26, 2015 Author Report Share Posted October 26, 2015 More boring stuff!!! 4 Quote Link to comment
mattyhacks71 Posted October 27, 2015 Report Share Posted October 27, 2015 This is very cool Quote Link to comment
]2eDeYe Posted October 27, 2015 Report Share Posted October 27, 2015 Nice to see it going back together. :cool: Quote Link to comment
kaoss Posted October 27, 2015 Author Report Share Posted October 27, 2015 Nice to see it going back together. :cool: I has no running motor doe :( Quote Link to comment
datsunfreak Posted October 28, 2015 Report Share Posted October 28, 2015 Are you still planning to put a KA in it? Quote Link to comment
kaoss Posted October 28, 2015 Author Report Share Posted October 28, 2015 Yep. It's sitting next to my work bench, had to buy a washer and dryer instead. 1 Quote Link to comment
maltese Posted October 28, 2015 Report Share Posted October 28, 2015 Glad I'm not the only one whose Datsun money went into appliances. The clothes do smell good, though. And the wife is happy, so... :thumbup: 1 Quote Link to comment
kaoss Posted October 29, 2015 Author Report Share Posted October 29, 2015 Glad I'm not the only one whose Datsun money went into appliances. The clothes do smell good, though. And the wife is happy, so... :thumbup: And she's the one with the vagina so what she says goes. 6 Quote Link to comment
Mr.Dean_Yates Posted October 31, 2015 Report Share Posted October 31, 2015 I read threads like this and it makes me want to build a mini again. I always did static drops but I've always wanted to get into bags. Then I remember I'm a pest control tech whose also paying 20gs to get professional welding certificates and who rents a house from a slum lord...I barely have enough to start working on a z that's already running and driving hahaha 1 Quote Link to comment
chandlerGTi Posted November 10, 2015 Report Share Posted November 10, 2015 That paint scheme is extraordinary. Glad you decided to keep it! Quote Link to comment
kaoss Posted January 25, 2016 Author Report Share Posted January 25, 2016 Well, after the body drop there was an issue with the solid steering shaft hitting the fire wall. I trimmed the tube around the shaft and got it mounted within 1/8" of it's original spot. I drilled one hole out a little lower and reinforced the frame using a piece of 2x3 that I cut out. I'm still not super happy that I couldn't replicate the factory set up. Hole drilled: Donor material for gusset. welded up and painted. 1 Quote Link to comment
]2eDeYe Posted January 25, 2016 Report Share Posted January 25, 2016 Are you planning to sleeve that hole? Quote Link to comment
kaoss Posted January 25, 2016 Author Report Share Posted January 25, 2016 Are you planning to sleeve that hole? No, I'm really hoping the gusset I added would suffice. Quote Link to comment
]2eDeYe Posted January 25, 2016 Report Share Posted January 25, 2016 You will likely end up crushing the rail over time. Those bolts see a lot of force, this is why they are sleeved from the factory. Quote Link to comment
kaoss Posted January 25, 2016 Author Report Share Posted January 25, 2016 You will likely end up crushing the rail over time. Those bolts see a lot of force, this is why they are sleeved from the factory. I guess it all depends on what size tube I can find to make a sleeve out of. 1 Quote Link to comment
]2eDeYe Posted January 26, 2016 Report Share Posted January 26, 2016 I probably have some in my pile that I could donate. :) 1 Quote Link to comment
Anderson521 Posted January 27, 2016 Report Share Posted January 27, 2016 Just read the thread and man this is one intense build. 1 Quote Link to comment
Anderson521 Posted January 27, 2016 Report Share Posted January 27, 2016 Taped off And seam sealed. By the way what is this I've never seen that before 1 Quote Link to comment
finney Posted January 27, 2016 Report Share Posted January 27, 2016 seam sealer? 1 Quote Link to comment
kaoss Posted January 27, 2016 Author Report Share Posted January 27, 2016 Yeah, just run the mill seam sealer. It's $40 a tube at the big box store, but I found it at the local mom and pop auto paint supply store for $16. 2 Quote Link to comment
kaoss Posted September 8, 2016 Author Report Share Posted September 8, 2016 Getting closer. 5 Quote Link to comment
