Daily Randomness.........Back to Randomness........................................
  • Replies 25.2k
  • VFR800
    2479
  • datzenmike
    2341
  • q-tip
    1360
  • hobospyder
    1255
They make an adapter to bolt the SOHC Aluminum block Honda J-series from the mini vans to a Miata 5 and 6 spd.
Narrow, light V6 with plenty of torque.
I'm hoping other companies jump on this for more support and better prices
Interesting. Honda J series spin reverse of almost every other engine, as far as I understood. I guess the miata does as well? Or am I mistaken on that?
Regardless, they really are great engines. Just little aftermarket, and no one has hacked the factory ecu, so developing extra power guarantees an aftermarket ecu.
The 4 cylinders spin backwards. Not sure about the S2000 though.
If you look at a Honda engine bay, if the engine is on the driver's/left side it spins backwards.
The V6s have the motor on the right.
Link to those miata mounts? That's a crazy engine idea.
Yup. That's the one.
And fuck that noise against it. Some engines trancend the boundaries of bias. The S2000 is such a beast in a small package I'll never diss it by calling it Honda. I've driven a couple. One of which I've really "driven". Bone stock. If I wasn't on the pedals I think I actually would think there was an ape getting sodomized under the hood. If I could handle the task of that swap, I would. No question.
