Daily Randomness.........Back to Randomness........................................
  • Replies 25.2k
  • VFR800
    2479
  • datzenmike
    2344
  • q-tip
    1360
  • hobospyder
    1255
I wasn't even aware that you could burn brush WITHOUT diesel.
You don't need to start a fire with diesel when you have a Scotch broom plantation,,  the diesel was pretty thick as it had sat in a tub in front of the garage for about 2 1/2 years ,,, it also had desolved plastic and paint in it as i was using it to clean a couple heads.. So wehad to make like a burn pile all day to get rid of the 10 gallons we had sitting there...
And in accordance with the burn permit we received from Olympic Region Clean Air Agency (ORCAA) there was absolutely no plywood or other kinds of laminated or stained building materials burned,,,,, before dark.
Ooooooh Nanner, You're gonna smoke a turd in hippie purgatory for that one.
I think cats have the potential to cure hunger (in humans). As if hunger was a disease... But cats and rabbits alike are capable of insane population booms. We would never run out
Anyone get this?
does it run better if you don't pull choke, but simply cover some of carb inlet with your hand?? sounds like a vacuum leak to me.[/quote
I'm gonna check it out, at my shop now. Its also doing that thing where it acts like the throttle is sticking (but its not) and then u tap the gas pedal and it goes back to normal idle.
Is it a DGV webber??? ..... mine runs like shit sometimes, and I need to re-adjust the air bleed screw.. while it's running
I think it's 4 turns back from all the way in... (not sure though) ...... that's probably not your problem, if your truck has always ran the same
I've never had one that was. I love the stock Hitachis; never had an issue with one.
Your dry sarcastic humor is almost undetectable. But I'm on to it.
I have the 38/38 and I'm never going back to Hitachi. I did think about switching to a 32/36 though for drivability. 38 is quite aggressive.
