4wd 1973 620 pickup
  • Replies 517
 Not sure where you got the week trans theory.
The 1st generation had teething pains . They were corrected years ago.
The current 700R-4 is the go to system for most Chevy builders.
  Your going to need the overdrive to end up with any semblance of economy with that set up.
The added weight of the v-6 and the tranny T-case weight are the big disadvantage to that system.
BUT it is ultra reliable and well supported.
Year Horsepower Torque Fuel System Compression Ratio RPO Applications 1985–1986 155 hp (116 kW) @ 4000 rpm 230 lb·ft (312 N·m) @ 2400 rpm 4-BBL 9.3:1 LB1 1,2,3 1985 130 hp (97 kW) @ 3600 rpm 210 lb·ft (285 N·m) @ 2000 rpm TBI 9.3:1 LB4 4,5 1986–1990 140 hp (100 kW) @ 4000 rpm 225 lb·ft (305 N·m) @ 2000 rpm TBI 9.3:1 LB4 4,5 1987–1988 145 hp (108 kW) @ 4200 rpm 225 lb·ft (305 N·m) @ 2000 rpm TBI 9.3:1 LB4 5 1986 160 hp (120 kW) @ 4000 rpm 235 lb·ft (319 N·m) @ 2400 rpm TBI 9.3:1 LB4 3 1987–1992 155 hp (116 kW) @ 4000 rpm 230 lb·ft (312 N·m) @ 2400 rpm TBI 8.6:1 LB4(w/C6P emissions 2500&3500 series only) 2 1987–1992 160 hp (120 kW) @ 4000 rpm 235 lb·ft (319 N·m) @ 2400 rpm TBI 9.1:1 LB4 1,3,6,7 1993–1995 155 hp (116 kW) @ 4000 rpm 230 lb·ft (312 N·m) @ 2000 rpm TBI 9.1:1 LB4 2 1993–1995 165 hp (123 kW) @ 4000 rpm 235 lb·ft (319 N·m) @ 2000 rpm TBI 9.1:1 LB4
Not a huge HP gain for the added weight. But plenty of torque.
 Have fun buddy......
yea this is really the perfect balance of power and weight for my application. i will have a motor update asap, i have been busy fixing the floor and i didn't have a camera.
 Now I wouldn't  go that far.....
yea...i have gone to 3 different auto parts stores, tried 2 different mounts from summit, and gone to a pick and pull all resulting in nothing usable for motor mounts. i really don't want to shell out the $110 that the trans dap motor mounts cost so im just gonna take [2eDeYe's idea and make my own out of some poly bushing i have. more updates on that soon. i also decides to use a turbo 400 because the 700r4 is really hard to find in my area and the only t cases they come with are the wrong side drop.
I was wondering when you were going to figure that out...
We went over all of this earlier in this build.
 You can run this :
And any trany you want.....
