Boxcar Posted April 9, 2014 Report Share Posted April 9, 2014 The issue you may run into with the divorced t-case setup is the rear drive line angle, its is a shorter wheel base vehicle after all. Not to mention yky have 2 more u joints to worry about. JMHO . This is a short wheel base vehicle. 80" , with a divorced T-case. 17.75 " drive line... This is NOT a short wheel base vehicle.100"- Divorced T-case , 37" drive line... We actually could have slid the T-case forward another 4 to 5 " but are planning for a future Browny box between the trans and T-case. Most married trans /T-case set ups are close to the same over all length or longer due to the size of the chain drive T-cases. Quote Link to comment
ratsun73 Posted April 9, 2014 Author Report Share Posted April 9, 2014 oh ok that makes sense. Quote Link to comment
]2eDeYe Posted April 10, 2014 Report Share Posted April 10, 2014 We actually could have slid the T-case forward another 4 to 5 " but are planning for a future Browny box between the trans and T-case. What is this Browny box? Quote Link to comment
ratsun73 Posted April 11, 2014 Author Report Share Posted April 11, 2014 i got one of my mounts tacked in more updates and picts tomorrow. Quote Link to comment
Boxcar Posted April 11, 2014 Report Share Posted April 11, 2014 What is this Browny box? Rather than building a doubler and gaining a second low/ high range. I will be adding a second 4 spd tranny between the trans t-case , this allows for 4 selectable low / high ranges. Kind of an old school thing we started to do back in the 70's using a Volvo 4 spd trans. 10" long after machine work. 32 forward gears. 100 - 1 crawl..... That is why I used the flanged drop pan 4 speed. 1 Quote Link to comment
ratsun73 Posted April 13, 2014 Author Report Share Posted April 13, 2014 guess what i got. another motor with a 2wd 700r4. ill post picts in a bit. Quote Link to comment
ratsun73 Posted April 13, 2014 Author Report Share Posted April 13, 2014 this was $175 1 Quote Link to comment
ratsun73 Posted April 13, 2014 Author Report Share Posted April 13, 2014 so i got another 4.3 set up for a carb. this also had a really clean 700r4 2wd and i couldn't even get an accell dizzy for under $200. this one has the mounts i need to. 2 Quote Link to comment
ratsun73 Posted April 20, 2014 Author Report Share Posted April 20, 2014 gonna finally get the las piece of the puzzle to get this junk on the road...enough debating im getting a turbo 350 with a shift kit, rebuilt 22,000 ago, mated to a 203 with a part time kit. there decision made, picts when i get home. 1 Quote Link to comment
q-tip Posted April 20, 2014 Report Share Posted April 20, 2014 Big heavy transfer case, but youll never break it! 1 Quote Link to comment
]2eDeYe Posted April 20, 2014 Report Share Posted April 20, 2014 You can also use it as a doubler if you find another one or a 205. 1 Quote Link to comment
ratsun73 Posted April 21, 2014 Author Report Share Posted April 21, 2014 Big heavy transfer case, but youll never break it! you aint kidding!!! 1 Quote Link to comment
ratsun73 Posted April 21, 2014 Author Report Share Posted April 21, 2014 my dad also helped my uncle clean out his storage unit and got these for me :w00t: Quote Link to comment
ratsun73 Posted April 21, 2014 Author Report Share Posted April 21, 2014 AND i got this finally. tomorrow rear main and oil pan gasket!!! :thumbup: :thumbup: Quote Link to comment
ratsun73 Posted April 21, 2014 Author Report Share Posted April 21, 2014 You can also use it as a doubler if you find another one or a 205. that will be the plan eventually, along with a 4 link, tons and 44's 1 Quote Link to comment
Boxcar Posted April 21, 2014 Report Share Posted April 21, 2014 Congratulations . You just built a Blazer. Quote Link to comment
ratsun73 Posted April 21, 2014 Author Report Share Posted April 21, 2014 :fu: yea...but at least im that much closer to getting it done :rolleyes: Quote Link to comment
ratsun73 Posted April 22, 2014 Author Report Share Posted April 22, 2014 stripped the old motor of all the parts i need except the flex plate. Quote Link to comment
ratsun73 Posted April 22, 2014 Author Report Share Posted April 22, 2014 got the oil pan off, the rear main housing washed and the seal pressed off. i was going to take picts but i would have been late for my next class, more updates tomorrow. Quote Link to comment
ratsun73 Posted April 22, 2014 Author Report Share Posted April 22, 2014 yuck i didn't realize how nasty the seal actually was :sick: :sick: Quote Link to comment
ratsun73 Posted May 4, 2014 Author Report Share Posted May 4, 2014 new rear main Quote Link to comment
ratsun73 Posted May 4, 2014 Author Report Share Posted May 4, 2014 all lined up Quote Link to comment
ratsun73 Posted May 4, 2014 Author Report Share Posted May 4, 2014 first coat of paint on the inside of the cab Quote Link to comment
ratsun73 Posted May 4, 2014 Author Report Share Posted May 4, 2014 the exhaust off the motor i just got tucks closer to the block Quote Link to comment
ratsun73 Posted May 4, 2014 Author Report Share Posted May 4, 2014 intake on with new gaskets. Quote Link to comment
