Boxcar Posted August 4, 2014 Report Share Posted August 4, 2014 True. But the PO is not building a trailer queen. Quote Link to comment
q-tip Posted August 4, 2014 Report Share Posted August 4, 2014 Completely agree Quote Link to comment
ratsun73 Posted August 10, 2014 Author Report Share Posted August 10, 2014 i just ordered my arm and studs should be here friday or saturday. Quote Link to comment
Boxcar Posted August 12, 2014 Report Share Posted August 12, 2014 Get that thing done...... I wannnna go wheelin.......... Quote Link to comment
ratsun73 Posted August 14, 2014 Author Report Share Posted August 14, 2014 Get that thing done...... I wannnna go wheelin.......... im going as fast as i can :D :P 1 Quote Link to comment
ratsun73 Posted August 14, 2014 Author Report Share Posted August 14, 2014 i got a box!!!! Quote Link to comment
ratsun73 Posted August 14, 2014 Author Report Share Posted August 14, 2014 what could it be? it is my steering arm from parts mike. it is beef!!! its 1 inch thick and looks awesome. i was super impressed with the short delivery time to, i ordered it on saturday and it got here Wednesday. Quote Link to comment
ratsun73 Posted August 14, 2014 Author Report Share Posted August 14, 2014 my dad just got the mail...i got another box!!!! Quote Link to comment
ratsun73 Posted August 14, 2014 Author Report Share Posted August 14, 2014 body lift Quote Link to comment
ratsun73 Posted August 15, 2014 Author Report Share Posted August 15, 2014 is the steering column out of a pathfinder the same as the one in a 720, and if its not will it work for my application? Quote Link to comment
]2eDeYe Posted August 15, 2014 Report Share Posted August 15, 2014 It's not the same, but anything will work with patience and a sawsall :) Quote Link to comment
ratsun73 Posted August 16, 2014 Author Report Share Posted August 16, 2014 It's not the same, but anything will work with patience and a sawsall :) ok Quote Link to comment
q-tip Posted August 16, 2014 Report Share Posted August 16, 2014 Have sawzall will install Quote Link to comment
ratsun73 Posted August 20, 2014 Author Report Share Posted August 20, 2014 is is so hard to find a 6 lug rear, i am really close to buying a set of 3/4 ton chevy axles for $100, is this a bad idea? Quote Link to comment
]2eDeYe Posted August 20, 2014 Report Share Posted August 20, 2014 I am using a 1996 4Runner rear axle. 6 lug and 60.5" wide. Bonus is that it has an e-locker, actually dropping the diff off today to get re-geared. Cost me $700 for the complete axle. Edit: Keep in mind those chevy axles are full width and will be about 6" wider than the wagoneer axle you have up front. You could use the rear out of the pathfinder your getting the column from. Quote Link to comment
ratsun73 Posted August 22, 2014 Author Report Share Posted August 22, 2014 do you think I will brake the toyota rear? Quote Link to comment
]2eDeYe Posted August 22, 2014 Report Share Posted August 22, 2014 Toyota rears are good up to a 38" tire for the most part. There are guys beating the stock rears with 40" tires and you can always get chromoly or some other strong aftermarket shafts for them. Quote Link to comment
carnuck Posted August 26, 2014 Report Share Posted August 26, 2014 Long time since I've been here. Don't know what part of WA you are in, but I see FSJ axles on CL all the time. I just happen to have a degree in Jeepology and roots back to a 411 SSS 4 dr convertible and SD33T in military tugs. Quote Link to comment
ratsun73 Posted October 12, 2014 Author Report Share Posted October 12, 2014 well i finally got some progress made on the truck, the front axle was fully gone through, new everything, now i just need to make some more time to slap it under the truck so i can take it to my shop. Quote Link to comment
]2eDeYe Posted October 13, 2014 Report Share Posted October 13, 2014 Forward progress, nice :D Quote Link to comment
Boxcar Posted October 15, 2014 Report Share Posted October 15, 2014 Bout time..... :poke: Quote Link to comment
ratsun73 Posted November 3, 2014 Author Report Share Posted November 3, 2014 Bout time..... :poke: yeah...football is almost over so then i will have more time to earn money and dump in the truck 1 Quote Link to comment
ratsun73 Posted November 4, 2014 Author Report Share Posted November 4, 2014 pulled some packs went from 6 to 3, any thoughts? to many? the pictures are at ride height, i think i might add one back because i still have some weight to add to the front of the truck. Quote Link to comment
