Skib Posted December 25, 2008 Author Report Share Posted December 25, 2008 woohoo! :D parts on the way: fuel pressure regulator J-Pipe wastegate actuator energy suspention bushing kit dizzy g pop shop turbo rebuild kit Quote Link to comment
Skib Posted January 5, 2009 Author Report Share Posted January 5, 2009 heres a update pic... lol its all i got for now. more boxes on the way ;) Quote Link to comment
Skib Posted January 5, 2009 Author Report Share Posted January 5, 2009 hopfully not to much longer untill i can put it all where it belongs :D Quote Link to comment
Rubberman Posted January 5, 2009 Report Share Posted January 5, 2009 Skib, your car is lookin good. I like the two tone color, you need to take a day time pic. Where did you get your drivers seat? How much? Quote Link to comment
Skib Posted January 5, 2009 Author Report Share Posted January 5, 2009 Skib, your car is lookin good. I like the two tone color, you need to take a day time pic. Where did you get your drivers seat? How much? thanks man, lol its dirty from driving like 700miles and being covered in snow. i got the seat brand new from someone i knew for $60, iv seen em go from $150-$200 new tho. not a sparco or recaro but its makes my harness functional and its not uncomfortable. Quote Link to comment
Skib Posted January 7, 2009 Author Report Share Posted January 7, 2009 got my turbo rebuild kit from G-Pop today sweeeet :D Quote Link to comment
Skib Posted January 14, 2009 Author Report Share Posted January 14, 2009 finally got the gas tank dropped and getting ready to put the 280z tank in. and got my new radiator since the old one took a crap on me Quote Link to comment
Moisabamf Posted January 14, 2009 Report Share Posted January 14, 2009 and got my new radiator since the old one took a crap on me so your into that kinda stuff eh?:D very nice progress on the car Quote Link to comment
datzenmike Posted January 14, 2009 Report Share Posted January 14, 2009 finally got the gas tank dropped and getting ready to put the 280z tank in. and got my new radiator since the old one took a crap on me Just wonderin'. Would the high pressure 280 pump not fit into the 240 tank? Or was it an external pump? Quote Link to comment
Edz280zx Posted January 15, 2009 Report Share Posted January 15, 2009 Should be an external pump...but the 280 is already set up for return line and stuff...I would guess anyway. Quote Link to comment
Skib Posted January 15, 2009 Author Report Share Posted January 15, 2009 the reason for the tank swap is the 280z tank has baffleing in it for the EFI and the 240z tank dosent, with EFI theres not fuel ready to go like you have with the float bowls so if i had the EFI and the stock tank id get no gas and the motor would cut out around hard corners because of the gas all sloshing to one side of the tank. Quote Link to comment
Skib Posted January 16, 2009 Author Report Share Posted January 16, 2009 :D parts on the way: from MSA: Oil Pump Thermostat Water Pump Main Bearings Piston Rings 2.5in MSA Downpipe Fuel Block Off Plate and Summit: ARP Rod Bolts VDO 30PSI Boost Gauge so far..... :lol: Quote Link to comment
Bleach Posted January 16, 2009 Report Share Posted January 16, 2009 and they still don't make a downpipe for the 280ZX turbo. :( Quote Link to comment
Skib Posted January 16, 2009 Author Report Share Posted January 16, 2009 and they still don't make a downpipe for the 280ZX turbo. :( lol the ZX has that -3in at the fire wall, your stuck with the 90deg DP :lol: my MSA DP is a nice set of 45deg bends Quote Link to comment
comply Posted January 16, 2009 Report Share Posted January 16, 2009 Lookin' good! Do you use those brass knuckles to bust open your boxes with car parts in them? :D Quote Link to comment
Skib Posted January 16, 2009 Author Report Share Posted January 16, 2009 Lookin' good! Do you use those brass knuckles to bust open your boxes with car parts in them? :D lol thos are for "persuading" all thos rusty datto bolts :glare::lol: Quote Link to comment
Skib Posted January 22, 2009 Author Report Share Posted January 22, 2009 mmmmm new box :fu: Quote Link to comment
Skib Posted January 24, 2009 Author Report Share Posted January 24, 2009 :D more parts collecting and some new progress! I got the 280zx radiator in, its bigger than an S30 radiator so it hangs lower than stock, not any lower than the suspension but im going to make a rock shied for the lower tank just in case:D got the 280z gas tank in and its up and running on that now ready to have a clean L28et dropped in :fu: i woke up to find my energy suspension master busing set had come :D and on the way i have an exhaust manifold, and agentalpha cut my a super deal on a fuel pump, thanks man :thumbup: I just need: igniter oil return line (510er might be able to grab thos from the JY for me) a BOV replace some of the crusty bolts with new ones front cover gaskets 1in ArizonaZcar TB spacer some Jegs fuel line coil kit to replace the tiny stock hard fuel lines finish rebuilding the turbo drop the head off at the metal strippers mon. lap the valves when I get it back and waiting on my piston rings that are on back order. then I should have everything I need to re assemble and drop it in :D Quote Link to comment
agentalpha Posted January 24, 2009 Report Share Posted January 24, 2009 (edited) No prob, Sir. GLAD to help ya out! I have a couple of nice stock turbo oil return lines, if you need them. CLEAN, not rusty, no kinks. Spray some engine de-greaser, and then brake cleaner through 'em and they should be good to go. Use the nicest one, and have a spare. Shoot me $10, and they are both yours. Is that fair? :D Edited January 24, 2009 by agentalpha Quote Link to comment
Skib Posted January 24, 2009 Author Report Share Posted January 24, 2009 i need the turbo to oil pan line :D 510er might be able to grab it in the JY tho Quote Link to comment
Skib Posted January 25, 2009 Author Report Share Posted January 25, 2009 mmmmm master polly kit Quote Link to comment
hughdogz Posted January 27, 2009 Report Share Posted January 27, 2009 You've been waiting for those for a long time! My offer is still good if you want to borrow that Ztherapy street racing suspensions VHS for install tips / instructions / descriptions... Quote Link to comment
Skib Posted January 27, 2009 Author Report Share Posted January 27, 2009 i had to go threw a bunch of BS to get them to :mad: i ordered them in freakin Dec. you bet man, Ill have to swing by this weekend or somthing Quote Link to comment
Skib Posted January 28, 2009 Author Report Share Posted January 28, 2009 w00t! :fu: piston rings finally came (where on back order at MSA) and my exhaust manifold came :D just have to get the ARP rod bolts pressed in and the bottom end can go togehter :fu: Quote Link to comment
