banzai510(hainz) Posted July 30, 2010 Report Share Posted July 30, 2010 Wussies?????? Unfortunatly you can only go so low on a wagoon(rear) before you have to channel the driveline tunnel. Quote Link to comment
gokiburix Posted July 30, 2010 Author Report Share Posted July 30, 2010 Wheel-gap is for wussies! Or those who cannot afford lowering springs... yah...because turning is over-rated, right? <_< :lol: Quote Link to comment
Pacific coast Datsun Posted July 30, 2010 Report Share Posted July 30, 2010 "Unfortunatly you can only go so low on a wagoon(rear) before you have to channel the driveline tunnel. " True Hainz..i have a mod in mind that will let them lay low & still have shock travel ;) Teaser of what i've been building...will debut @ JCCS.. Quote Link to comment
Laecaon Posted July 30, 2010 Report Share Posted July 30, 2010 "Unfortunatly you can only go so low on a wagoon(rear) before you have to channel the driveline tunnel. " True Hainz..i have a mod in mind that will let them lay low & still have shock travel ;) Teaser of what i've been building...will debut @ JCCS.. For those of us who aren't going to JCCS please make a thread about this! After the event of course so you don't ruin the surprise ;) Quote Link to comment
jonesy510 Posted July 30, 2010 Report Share Posted July 30, 2010 Wussies?????? Unfortunatly you can only go so low on a wagoon(rear) before you have to channel the driveline tunnel. i-need-to-do-mine-again-so-i-can-go-lower....but-yes-this-is-true and-goki-yes-turning-is-way-overated- :cool: :lol: Quote Link to comment
INDY510 Posted July 30, 2010 Report Share Posted July 30, 2010 "Unfortunatly you can only go so low on a wagoon(rear) before you have to channel the driveline tunnel. " True Hainz..i have a mod in mind that will let them lay low & still have shock travel ;) Don't hate me........ . but why not just cut out the whole rear floor,, and weld it back in 5-6 inches higher than stock? All the suspension mounting spots would be the same,, just 5-6 " higher........... and then you could always throw on some 2" blocks if it's still not low enough.. [/endhorribleidea} Quote Link to comment
jonesy510 Posted July 30, 2010 Report Share Posted July 30, 2010 haha-if-i-were-to-cut-out-the-whole-rearend-i-would-just-put-the-510-2dr-4dr-independent-rearsuspensin-in-*sorry*-i-dont-have-a-space-bar-or-backspace Quote Link to comment
INDY510 Posted July 30, 2010 Report Share Posted July 30, 2010 I don't want camber,,, ....... My 16x8 +10 wheels would tuck so sweet if I could lower the rear 6-7 inches Quote Link to comment
gokiburix Posted July 30, 2010 Author Report Share Posted July 30, 2010 I don't want camber,,, ....... My 16x8 +10 wheels would tuck so sweet if I could lower the rear 6-7 inches I always kinda like the raked look :blink: Wagon is still functional if you were to haul something heavy. I would dump my goon and have no wheel gap, but I like my goon to still be functional of its original intent (to haul shit). Plus...not having to worry so much everytime I go over a bump is a plus in my book. Rake is like a 1/2 vampire (Blade type...not the gay Twilight type)....best of both worlds. :lol: Quote Link to comment
INDY510 Posted July 30, 2010 Report Share Posted July 30, 2010 It would still be totally functional if ALL the suspension was raised.......... . or maybe just raise the upper shock mounts I like rakes too...... . but in this pic the oil pan is 3/4" off the ground,,, and the rear is on the bumpstops with 400lbs in the back: The front coilovers could still go lower.......... . and the rear would need to be lowered another 5 inches to level out the rockers It's all hypothetical at this point,,,,,,,, but it would be cool to have a slammed goon that could still haul 400lbs of shit Quote Link to comment
jonesy510 Posted July 31, 2010 Report Share Posted July 31, 2010 yup_once-i-redo-my-tunnel-my-goon-will-b-back-to-being-functional-.....i-just-didnt-know-how-much-i-had-to-raise-the-tunnel-before-i-welded-everything-in Quote Link to comment
greengoon Posted August 1, 2010 Report Share Posted August 1, 2010 To each his own on wheel gap. Goons (& all 510s) look great at any height. They are cool cars that's why we have them. But I have the incurable slamming disease. I can still drive it at this height and it rides surprisingly well for what it is but it obviously rides better with the air in the rear shocks and a rake to it. best of both worlds. :D Quote Link to comment
Loren Posted August 1, 2010 Report Share Posted August 1, 2010 those wheels look SWEET!!! i still like the gold Enkies though. they'd look great on my olive green 'goon, especially if i can get a template made,so i can paint the "datsun" rocker panel stripe on in gold as well. Quote Link to comment
Pacific coast Datsun Posted August 2, 2010 Report Share Posted August 2, 2010 For those of us who aren't going to JCCS please make a thread about this! After the event of course so you don't ruin the surprise ;) Im running rear air shocks thanks to Greengoon :cool: & i plan to modify the shackle plate which will wet the lower shock mount down a bit.Should have travel & sit down a bit more. Quote Link to comment
Loren Posted August 7, 2010 Report Share Posted August 7, 2010 I was driving along 99 today,almost to Canby, I was about to downshift from 5th, to 4th when my trans popped out of gear. I put it into 4th,& it drove ok afterwards,except for a clicking/clunking sound and some vibration. the car always has a lot of noise & vibration,because of my L16 exhaust on an L20, so it may have been bad for awhile! it seems like a bad u-joint to me (reminds me of the same symptoms as a bad cv joint in a front wheel drive). I read my "how to keep your Datsun alive" manual,which seems to back up my thinking. the book didn't really give me a clear way to check it for sure though,& recommend to have the u-joint done by a shop. i searched the forum here,but didn't find a clear and specific post in the drivetrain thread either. does anyone have a clear way to diagnose a bad,but currently functioning u-joint? thanks -Loren Quote Link to comment
Loren Posted August 10, 2010 Report Share Posted August 10, 2010 new pics of my '70 Goon after painting over the yellow stripes,and putting on the Datsmo,Goon Squad & "Get that Datsun difference" decals Quote Link to comment
gokiburix Posted August 11, 2010 Author Report Share Posted August 11, 2010 Loren....VERY awesome! Congrats...your windows are now full of WIN! :D ーゴキ Quote Link to comment
gokiburix Posted August 11, 2010 Author Report Share Posted August 11, 2010 With a few minutes to spare, I came up with this: :D ーゴキ Quote Link to comment
Duncan Posted August 11, 2010 Report Share Posted August 11, 2010 With a few minutes to spare, I came up with this: Nice! Are you the Goon Puppet Master!? :rolleyes: Quote Link to comment
Stupid_fast Posted August 12, 2010 Report Share Posted August 12, 2010 They will be on the wagon soon(The wheels). Quote Link to comment
gokiburix Posted August 12, 2010 Author Report Share Posted August 12, 2010 Nice! Are you the Goon Puppet Master!? :rolleyes: I suppose the Goon Puppet Master of my Goon :P Quote Link to comment
Laecaon Posted August 12, 2010 Report Share Posted August 12, 2010 Well you sorta kinda started this amazing thread... You may just be The Goon Puppet Master. Quote Link to comment
gokiburix Posted August 12, 2010 Author Report Share Posted August 12, 2010 Well you sorta kinda started this amazing thread... You may just be The Goon Puppet Master. hehe THANKS! Quote Link to comment
Pacific coast Datsun Posted August 13, 2010 Report Share Posted August 13, 2010 Hey did we ever figure out how many wagons will be showing @ JCCS ? I'm in :cool: Quote Link to comment
datrod Posted August 13, 2010 Report Share Posted August 13, 2010 Hey did we ever figure out how many wagons will be showing @ JCCS ? I'm in :cool: Mark. In the JCCS thread I think we had about 10-13 wagons so far. Might be more than that. Quote Link to comment
