A10's U-nite !!!!
A few updated pics of A10 / KA swap!!
KA24DE Bolts right in. 100% good to go. Must use 240sx brackets / mounts. Easy enough! No drilling, nothing. Good to go.
Enjoy! :)
  • Like 3
  • Replies 4.1k
ZX strut swap.
I said the HL is the new PL. About time the E/DEs started to be swapped in. This car really deserves the attention.
ZL2.3 maybe with a zx 5 speed and a late S110 H-190 rear end with a truck 4.375 in it. FUCK ME.
Maybe a Z24 from a 720 in an '80 or newer? 5 speed of course. Maybe 3.889 or 4.11s for the low revving stump puller.
The brakes need to be bled so its not done yet but it pulls the wheels in about (i dont remember right now) a half inch or so
In fact it's exactly 1/2".   :thumbup:
Side note: if you switch them side-to-side you'll have better clearance at the tie rod ends. On some cars, as the pads wear down the caliper moves just enough to hit the tie rod end.
So mhub...you said use 240sx mounts. Like the rubbers?
Yes. I unbolted the entire mount from the engine cross member of the 240sx and installed on the A10
OEM Nissan 240sx mounts, bolt directly to A10 xmember
Almost all the bigger calipers and/or common brake swaps have that problem. It's honestly a no-brainer to swap them. No downside, all upside.
Well I have all new rotors and pads and a few thou miles on them. Will keep an eye on this and if I ever take them off to chamge the damper fluid again I'll swap sides.
Are you saying switch sides so that the caliper is towards the front?
