Atomic Posted March 21, 2015 Author Report Share Posted March 21, 2015 It's rock auto.com not sure if the ship overseas never tried lol Haha, and it would add so much shipping + taxes. I need to find them from Europe, but thanks anyways :w00t: Quote Link to comment
TENDRIL Posted March 21, 2015 Report Share Posted March 21, 2015 it was mostly for part numbers, cross reference, thats why o didnt add link cause i know shipping is a bitch 1 Quote Link to comment
Atomic Posted March 22, 2015 Author Report Share Posted March 22, 2015 Gonna order some connectors, Dorman TPS plug DB9 female connector, I will hide this to the center console and I can plug an extension chord from this to my laptop and monitor my ecu And then missing connector for my Bosch spark thingy 1 Quote Link to comment
Atomic Posted March 26, 2015 Author Report Share Posted March 26, 2015 http://www.ebay.com.au/itm/Datsun-Sunny-B310-Early-1979-Coupe-Instrument-Cluster-/141612416838?pt=LH_DefaultDomain_15&hash=item20f8c1ff46 damn gurl :w00t: just what I have been looking for, but it's only local pickup.... :sneaky: Edit, and it's from right hand side model... nvm :crying: Quote Link to comment
ggzilla Posted March 26, 2015 Report Share Posted March 26, 2015 Right Hand Drive? Better to get a the same as you have. Do you only need the tachometre? Quote Link to comment
Atomic Posted March 26, 2015 Author Report Share Posted March 26, 2015 Right Hand Drive? Better to get a the same as you have. Do you only need the tachometre? Yes, I mean that the steering wheel is on the right hand side (mine is lefty) I need speedo+tacho+fuel and clock (whole set) and I also need the cluster panel. If I cannot find both, I just end up making my own design Quote Link to comment
ggzilla Posted March 26, 2015 Report Share Posted March 26, 2015 Place a Classified here ... Quote Link to comment
Atomic Posted March 26, 2015 Author Report Share Posted March 26, 2015 Place a Classified here ... On page 19 I have a long list :rofl: Quote Link to comment
Atomic Posted March 29, 2015 Author Report Share Posted March 29, 2015 Found old pictures, 3 of them. This car was in pretty bad shape back then,my dad said that transit hit it from the side :rofl: And I also noticed that the model number ended 002016, gotta get it ready till 2016 . Anyways, the passenger side door was rusty so I cut some pieces And then i blasted some parts Quote Link to comment
Atomic Posted April 8, 2015 Author Report Share Posted April 8, 2015 Here is the flywheel. It now has Sachs pressureplate from turbo volvo 240, looking good :thumbup: It also got balanced Oh, and it's 215mm disc now, original was 180mm 1 Quote Link to comment
Atomic Posted April 8, 2015 Author Report Share Posted April 8, 2015 It's almost like cooled flywheel with those holes :rofl: 1 Quote Link to comment
Atomic Posted April 10, 2015 Author Report Share Posted April 10, 2015 Clutch disc size comparison Volvo M47 tranny Datsun 60A tranny Decided to cut 5cm from both trannies and then Mig weld then together so that M47 will fit behind the engine :thumbup: I need to remove the crankshaft out of the engine block so I can change the needle bushing because M47 shaft is much larger than 60A Quote Link to comment
dukerollo Posted April 11, 2015 Report Share Posted April 11, 2015 Interesting idea with the trans. I look forward to seeing how it turns out. Quote Link to comment
ggzilla Posted April 11, 2015 Report Share Posted April 11, 2015 Why not machine the transmission input shaft? Leave the engine as is. Quote Link to comment
Atomic Posted April 11, 2015 Author Report Share Posted April 11, 2015 Why not machine the transmission input shaft? Leave the engine as is. The shaft has a hole on it and i'm afraid that when it gets narrowed it has too thin wall and it might brake, but I have it on my mind! I need to take measurement today and then make decisions, I'll keep u guys updated :w00t: Quote Link to comment
Atomic Posted April 11, 2015 Author Report Share Posted April 11, 2015 Datsun shaft measuring 12mm M47 shaft measuring 15mm and hole diameter 10mm, but it gets narrower.So what u guys think, bigger hole to crankshaft or smaller diameter tranny shaft? Quote Link to comment
Atomic Posted April 11, 2015 Author Report Share Posted April 11, 2015 Found ford water outlet that has slightly different angle and bigger outlet. But it has place for water temp sensor and it has a another outlet that I could use for turbo! Looks like this http://www.autopartoo.com/oem/693566.html, but not 100% sure Quote Link to comment
Atomic Posted April 13, 2015 Author Report Share Posted April 13, 2015 Had M47 disassembled this far, I'm going to ask from the mechanics how much further I have to disassemble it. I hope it will fit like this on their lathe Quote Link to comment
Atomic Posted April 13, 2015 Author Report Share Posted April 13, 2015 Cleaned garage and made myself another table for datsun parts \o/ Quote Link to comment
Mattndew76 Posted April 13, 2015 Report Share Posted April 13, 2015 Is that a before it was cleaned photo? :D 1 Quote Link to comment
Atomic Posted April 13, 2015 Author Report Share Posted April 13, 2015 Is that a before it was cleaned photo? :D Yes! Believe me, it took 3hours to make ite look like that :D my dad had piled bunch of junk there. +we have too much stuff and too little space! Quote Link to comment
Mattndew76 Posted April 13, 2015 Report Share Posted April 13, 2015 Yes! Believe me, it took 3hours to make ite look like that :D my dad had piled bunch of junk there. +we have too much stuff and too little space! I know about that combo. 1 Quote Link to comment
Atomic Posted April 14, 2015 Author Report Share Posted April 14, 2015 Aaaaaaaand I have to disassemble the whole tranny, but aint got time for now Quote Link to comment
Atomic Posted May 14, 2015 Author Report Share Posted May 14, 2015 oh shoot it has been like a month from the last update.. Oh man, going to continue this build 1.6.2015, after my graduation. Cheers \o/ Quote Link to comment
Atomic Posted June 1, 2015 Author Report Share Posted June 1, 2015 Pictures as promised: I cut the wheel hubs into more accurate shape Also cleaned these, I need to fab new plates into them And painted the front struts to black :) Quote Link to comment
