Atomic Posted August 14, 2021 Author Report Share Posted August 14, 2021 On 8/11/2021 at 10:46 PM, datzenmike said: The Tut tut tut tut tut when revving is by the sound of it, a non functioning cylinder. Waiting for the results of the custom oil pump. I think it will be boss!!! Very nice work BTW 18 hours ago, slowlearner said: It runs! Great work! Sounds to me like it could be missing 2 cylinders actually. Keep at it. Check your ignition and injectors and off you go. 🙂 I actually pulled off the spark plugs, cleaned them and then ran the engine. Looks like cylinder 1 and 3 are not getting enough fuel. So fuel problem, need new injectors. 1 Quote Link to comment
afracer Posted August 30, 2021 Report Share Posted August 30, 2021 I would NOT rev or even run the engine long until your injectors are figured out and it's firing properly on all cylinders. Mismatched cylinder temperatures due to no fuel on some but fuel in others can warp the head and/or blow the head gasket. Quote Link to comment
