Datsun B310 turbo coupe, A15 project
Atomic
  • Replies 1.3k
Picture time:
So I bought the 25mm thick spacers. Their outer diameter is going to be a small issue (150mm original):
img_20160703_162645_by_atomicsickness-da
So I made a smaller one, reducing the diameter to 146mm, so need to have the spacer turned in a lathe when they arrive, no biggie, should have enough wall thickness anyways..
img_20160703_171852_by_atomicsickness-da
Then I moved the engine mounts back 3cm because of the clearance issues with tranny case and center link
img_20160704_223741_by_atomicsickness-da
img_20160704_223755_by_atomicsickness-da
Should not be a problem anymore!  :thumbup: Photo taken when the wheel is rotated all the way to the right, it's traveling same ammount when going to left too, so should be good to go!
img_20160704_223820_by_atomicsickness-da
And damn the motor looks smexy there! *drool*
img_20160704_223835_by_atomicsickness-da
had some clearance issues with turbo and the left hand side engine bay wall, so I'm gonna shave some material off from the turbo (big bulky identification plate) Should be fine after that, more pics tomorrow!
Is there a welder local to you? That could maybe help with the adaptor plate? It is very doable however alum that thick should be heated prior to tig or mig. Plus it loves to be a super clean process any contamination will result in swearing
Yes, I have contacted some local welding companies and have been asking how much would it cost to do the job, will update on this reply when I got some answers o/
So I hammered the engine bay a bit to make the turbo fit, and now it has plenty of space and I managed to survive with minor paint repairs  B)
img_20160705_093330_by_atomicsickness-da
img_20160705_093353_by_atomicsickness-da
And I still have plenty of space for clearing out the steeringbox and downpipe:
img_20160705_093414_by_atomicsickness-da
Gonna try to bring the pipe down to the ex engine mount place, then under the steel tube and have a flex joint aprox where tranny starts
That steel tube is the crank-case breather ... you can probably re-route it, so it's not in your way as much. The whole tube should be removeable, so you can weld it away from the motor.
I ment the watertube that is attached to the block, it has a outlet to the heater. The loose steel tube is just old hydraulic tube for the tranny
More pics:
spacers now fit better:
img_20160706_141001_by_atomicsickness-da
Tested some rims too (14X6 ET 38)
img_20160706_145308_by_atomicsickness-da
img_20160706_145255_by_atomicsickness-da
img_20160706_145238_by_atomicsickness-da
img_20160706_145354_by_atomicsickness-da
Looks fine for me, but I'm looking forward the 885 RS Gold rims (16x7 ET 20), need to order one of those and have it test fit
I think I might have to widen up the rear body because the rims that I want, aren't probably going to fit with the new rear axle, hmm..  :confused: Oh well, gonna get some steelpipes for the jig tomorrow
More pics:
So I tested the Jig with L shape irons to hold the axle in place, but it seemed too difficult to align that damn thing:
img_20160707_144716_by_atomicsickness-da
img_20160707_151353_by_atomicsickness-da
Aligning with laser:
img_20160707_155406_by_atomicsickness-da
So I cut the L irons off:
img_20160707_160808_by_atomicsickness-da
Glimpse on Volvos axle, has been rusting a bit..
img_20160707_171801_by_atomicsickness-da
Made the new holders just flat:
img_20160707_172617_by_atomicsickness-da
And I didn't know that the axle isn't symmetric, as show in photo, the laser will go to the nut of the tranny, and the black line drawn is the centerpoint from the sides, volvos axle had this too, with same dimension:
img_20160707_183609_by_atomicsickness-da
Jig done:
img_20160707_201221_by_atomicsickness-da
Lower joint holders:
img_20160707_201242_by_atomicsickness-da
Upper joint holders:
img_20160707_201249_by_atomicsickness-da
Got the two upper joints disconnected from the axle, it was getting late and didn't wanna disturb the neighbors anymore :D
img_20160707_210425_by_atomicsickness-da
Its getting messy in here...  :rofl:  :rofl:
Also the lower joints are prolly going to be pain in the ass to cut out of the frame, ugh, tomorrow we'll see.. Would be easy if i had plasma cutter...
And next axle to the jig:
img_20160708_120627_by_atomicsickness-da
I decided to cut the hubs of because it was taking so much longer to bolt those fckers off  :rofl:  :rofl: also made it 100% easier to remove the lower joints:
img_20160708_120641_by_atomicsickness-da
still need to remove the spring pads, but they can be like that for now, I need to work with the other axle first...
Its happening  :w00t: also, cup holder:
img_20160708_164012_by_atomicsickness-da
img_20160708_163955_by_atomicsickness-da
img_20160708_154752_by_atomicsickness-da
img_20160708_163746_by_atomicsickness-da
img_20160708_163753_by_atomicsickness-da
img_20160708_164041_by_atomicsickness-da
img_20160708_164049_by_atomicsickness-da
Now to order some rims and then maybe buy some Golf I rear bow to widen up the rear some 5-10cm. These test rims had offset of 20 or so, the ones that I'm going to order, have 35, so it's going to move in 15mm.
So I bought the Golf 1 rear thingies:
img_20160709_174030_by_atomicsickness-da
img_20160709_174051_by_atomicsickness-da
img_20160709_174110_by_atomicsickness-da
img_20160709_194036_by_atomicsickness-da
Doesn't look bad imo  B)
And the bumpsteer spacers arrived, thanks to techotoytuning!
img_20160709_174336_by_atomicsickness-da
img_20160709_194129_by_atomicsickness-da
img_20160709_181127_by_atomicsickness-da
Now i just need some rims to fit them with  :w00t: should be here on monday or tuesday.
I'm restauring the heater core unit, found a big stone inside of it  :rofl:  :rofl:
img_20160710_134620_by_atomicsickness-da
img_20160710_134633_by_atomicsickness-da
The foam seems to be broken, I'm just wondering if it's just normal foam or what should I use as a replacement?  :confused:
img_20160710_141919_by_atomicsickness-da
img_20160710_141924_by_atomicsickness-da
  • Atomic changed the title to Datsun B310 turbo coupe, A15 project
