510T Posted February 1, 2014 Author Report Share Posted February 1, 2014 You have tires yet?? What size?? Today I ordered (2) BFG Rivals 225/45R15. They should be here Tuesday, hopefully get em mounted up same day. I am still making plans for the flare install. I have a guy lined up to do the finish welding on the tubs. I plan on doing the cutting, fitting and tacking myself. Right now I'm hoping to run a square tire setup but only ordered 2 just in case. Worst case I stretch a 205/50 on the fronts, kinda doubt I will have to do that though. This weekend I will order my hardware and some welting. Speaking of welting, another thread about that stuff brought to my attention that it is available in various colors. Should I just go black or try to color match a darkish blue? I will be painting the flares to match the car for sure. Quote Link to comment
KlassicMotion Posted February 1, 2014 Report Share Posted February 1, 2014 I think black will look fine. I doubt the likely hood that the blue matches. I'm assuming the two blues will clash. Worse case, just paint the black with the same blue as the car. 1 Quote Link to comment
datsunfreak Posted February 2, 2014 Report Share Posted February 2, 2014 Should I just go black or try to color match a darkish blue? Black. For sure. B) 1 Quote Link to comment
zat Posted February 3, 2014 Report Share Posted February 3, 2014 Got to test fit today, no tires. With the flares taped up: I am going to run the rears with a 10mm spacer most likely and the fronts require a 5mm spacer to clear the calipers. They are oictured with the spacers on. What you think? wicked setup, mate! 2 Quote Link to comment
510T Posted February 3, 2014 Author Report Share Posted February 3, 2014 Thanks zat! Got the 2 tyres mounted up, it looks like I should be good to go with 225's up front too. :) I ordered my mounting hardware today also; Black oxide coated SS button head allen screws and some crazy rubber / brass rivet nuts that looked fun to try out, along with some rubber bulb seal for in between the flare and body. Soon!!! 2 Quote Link to comment
datsunfreak Posted February 4, 2014 Report Share Posted February 4, 2014 Sorry if I missed it, but are those Z31 rotors/hubs? And is this on 280ZX struts? I have that combo and was wondering if it fits under some 15" wheels. I wanted to run the 15x8 RKRs, so I reeeeally hope that's the combo you're running. ^_^ Quote Link to comment
datsunfreak Posted February 4, 2014 Report Share Posted February 4, 2014 Also curious to know how you like the G-Force Rival when you get it on the road. They also make a 205/50-15 that would work a treat on the 15x8. B) Quote Link to comment
510T Posted February 4, 2014 Author Report Share Posted February 4, 2014 Sorry if I missed it, but are those Z31 rotors/hubs? And is this on 280ZX struts? I have that combo and was wondering if it fits under some 15" wheels. I wanted to run the 15x8 RKRs, so I reeeeally hope that's the combo you're running. ^_^ The struts and hubs are Infiniti M30, with drilled Z32 26mm rotors. IMHO these are the best struts if you don't need the ZX's narrow track width. Also curious to know how you like the G-Force Rival when you get it on the road. They also make a 205/50-15 that would work a treat on the 15x8. B) This will be my second set of Rivals. My first set are indeed 205/50's but I have them mounted on 6" wheels. Would be perfect on an 8" I agree! I use them primarily for auto-x but I thought they were great on the street too. Quote Link to comment
510T Posted February 4, 2014 Author Report Share Posted February 4, 2014 Trying to show the size difference, they are very close. In person it is fairly obvious though. The top and bottom of the tire sandwich are the 205's on a 6" and the middle is the 225 on the 9". 1 Quote Link to comment
datsunfreak Posted February 4, 2014 Report Share Posted February 4, 2014 The struts and hubs are Infiniti M30, with drilled Z32 26mm rotors. IMHO these are the best struts if you don't need the ZX's narrow track width. Sorry, misspoke there. Mine are also M30. :rofl: But my hubs/rotors are 4-lug Z31. Should be the same diameter rotors as yours if the calipers fit that strut and rotor. :thumbup: This will be my second set of Rivals. My first set are indeed 205/50's but I have them mounted on 6" wheels. Would be perfect on an 8" I agree! I use them primarily for auto-x but I thought they were great on the street too. Thanks! :thumbup: Quote Link to comment
510T Posted February 4, 2014 Author Report Share Posted February 4, 2014 With these calipers I have been able to fit every 15" wheel I have tried, only required spacers to clear the outer face of the caliper. Quote Link to comment
datsunfreak Posted February 4, 2014 Report Share Posted February 4, 2014 With these calipers I have been able to fit every 15" wheel I have tried, only required spacers to clear the outer face of the caliper. Same here. My 16" SSRs got close but that's because of the design of the valve stem. Took a 3mm spacer to clear the caliper face. Quote Link to comment
datsunfreak Posted February 4, 2014 Report Share Posted February 4, 2014 And thanks again! Was worried I'd have to ditch these brakes to run those wheels... :thumbup: Of course, assuming your caliper bolted up without an adapter? Do you know the diameter of that rotor? 1 Quote Link to comment
datsunfreak Posted February 4, 2014 Report Share Posted February 4, 2014 Is that a yes? :rofl: Quote Link to comment
510T Posted February 4, 2014 Author Report Share Posted February 4, 2014 Sorry, yes the caliper bolted right on no adapter and the rotor is 280mm diameter. Quote Link to comment
datsunfreak Posted February 4, 2014 Report Share Posted February 4, 2014 Sorry, yes the caliper bolted right on no adapter and the rotor is 280mm diameter. Cool. :thumbup: Mine are 275 I believe. No major difference then. Quote Link to comment
510T Posted February 4, 2014 Author Report Share Posted February 4, 2014 Cool, Is the Z31 hub / rotor floating or captive like the older stuff, and do you know the rotor width by chance? Quote Link to comment
datsunfreak Posted February 4, 2014 Report Share Posted February 4, 2014 Cool, Is the Z31 hub / rotor floating or captive like the older stuff, and do you know the rotor width by chance? Captive, and 22mm. 1 Quote Link to comment
kawagon Posted February 11, 2014 Report Share Posted February 11, 2014 saw these pics looks like the same flares. can't wait to see yours done 2 Quote Link to comment
mattyhacks71 Posted February 11, 2014 Report Share Posted February 11, 2014 :wub: :wub: :wub: :wub: :wub: :wub: 1 Quote Link to comment
TENDRIL Posted February 18, 2014 Report Share Posted February 18, 2014 The struts and hubs are Infiniti M30, with drilled Z32 26mm rotors. IMHO these are the best struts if you don't need the ZX's narrow track width. so the m30 struts are a bolt on to the 510 swing arms/ball joints?, and are you using bump steer spacers? 1 Quote Link to comment
510T Posted February 18, 2014 Author Report Share Posted February 18, 2014 Yes and yes, you just need a bump steer spacer or adapter to step up the size of the raised part of the steering arm to fit the larger hole in the M30 strut. Same as S12 stuff. Quote Link to comment
510T Posted February 18, 2014 Author Report Share Posted February 18, 2014 Got some Datsun logo centercap emblems from MSA: 8 Quote Link to comment
