slayer Posted May 21, 2008 Report Share Posted May 21, 2008 ok how many people have done sound proofing and what seems to work the best. i am getting 8lb house carpet padding today and i have carpeting but was thinking about sound proofing my 620 as well. then it's time to find a quiet exaust. Quote Link to comment
carsoundguy Posted May 22, 2008 Report Share Posted May 22, 2008 I use Dynamat or Dynamat extreme. It applies well, insulates well, looks good (tho you never see it). I will say it is expensive and heavy, but it's the best you can do. Quote Link to comment
datzenmike Posted May 22, 2008 Report Share Posted May 22, 2008 I used a part roll of roofing tar about 1/4-3/8" thick. It's dry and flexible and comes in a 1 meter width. You can cut easily with tin snips and even 'weld' pieces together with a propane torch, just heat and press together. It's flexible but if heated with a torch even more so and can be pressed into corners. Once in, lay your carpet. It's dry and has a plastic film on one side you peel off if heating. Talk to any roofer they'll probably give you an end roll. I did. Quote Link to comment
Burabuda Posted May 23, 2008 Report Share Posted May 23, 2008 i'd break the piggy bank and get dynamat xtreme it's pretty easy to work with; you can mold it with your fingers and hands (and you'll be thankful of that by the time your done) plus, it makes a HUGE difference in an old dat gets rid of much road noise and tinny sounds Quote Link to comment
Z-train Posted May 23, 2008 Report Share Posted May 23, 2008 I'm coating the floor of the KC with bed liner from Signature spray in liners.I'm not doing this for noise,but it should have a quieting effect Quote Link to comment
MikeRL411 Posted May 24, 2008 Report Share Posted May 24, 2008 JC Whitney sells what is essentially a bitumen impregnated mat by the foot. I used it to replace the factory matting under my rear seat, an exact match for factory installation. Just be sure to let it warm up and install on a sunny day. It will crack if you try to unroll on a cold day. It would be good for sound deadening inside large door panels. Under floor mats I use ordinary foam carpet padding. No fuss, no mus and it cant bleed thru. Quote Link to comment
pope_face Posted May 30, 2008 Report Share Posted May 30, 2008 I know it probably won't make much of a difference, but keep in mind how much these mats weigh, and how much you're using. On a car that weighs less than a ton adding even 50 lbs will make a slight difference in feel. Quote Link to comment
kiznook Posted May 30, 2008 Report Share Posted May 30, 2008 I know it probably won't make much of a difference, but keep in mind how much these mats weigh, and how much you're using. On a car that weighs less than a ton adding even 50 lbs will make a slight difference in feel. Diet and exercise! and get a good skinny girlfriend Quote Link to comment
Burabuda Posted May 31, 2008 Report Share Posted May 31, 2008 Diet and exercise! and get a good skinny girlfriend when you get to be our age, there's none of those left unless you count the tweekers Quote Link to comment
sr71sss Posted August 12, 2008 Report Share Posted August 12, 2008 to add to the discussion has anyone tried the spray on/roll on sound deadening stuff. I remember seeing some on GEARZ a few times which was called lizard skin and it looked just like tar in a bucket-probably was but it says that it comes with a special gun where you can spray it on. Quote Link to comment
hang_510 Posted August 12, 2008 Report Share Posted August 12, 2008 to add to the discussion has anyone tried the spray on/roll on sound deadening stuff. i used a spray on rubber (undercoat) on the floors and wasnt impressed. i have a feelin its gonna be a PITA to remove too :cursing: Quote Link to comment
84TAVeRT Posted August 12, 2008 Report Share Posted August 12, 2008 thinkin bout fatmat myself... only $129 for 100sqft... http://www.fatmat.com/bulk/fatmat/100.html Quote Link to comment
dgi Posted August 13, 2008 Report Share Posted August 13, 2008 The guys on my old Ford forum swear by this product. Comes in rolls 6' x 4', longer lengths by request. Reduces sound and heat very well. A specially made fiberglass insulation bonded to aluminum substrate. Very, very light. You can even use it above headliners. It is sold by one of that forum's members who I think works for the manufacturer. Pricing is very good, and I believe he is nice enough to send a small sample on request. He usually has some listed on ePay, but I didn't find any tonight. If you are interested, send me a PM and I will give you his name and number. Quote Link to comment
Cruez Posted August 26, 2008 Report Share Posted August 26, 2008 I used RAAMat... sticks well and easy to work with.. http://www.raamaudio.com/cgi-bin/index.cgi?p=pr Used it on the firewall, doors, ceiling and floor... also used some bedliner underneath the car and inside the doors.. Quote Link to comment
LAYEDOUTB2K Posted August 26, 2008 Report Share Posted August 26, 2008 thinkin bout fatmat myself... only $129 for 100sqft... http://www.fatmat.com/bulk/fatmat/100.html somebody i know tried that stuff and said it only worked as good as dynamat if you doubled it up. im not sure about the cost difference, but just somehting to think about. Quote Link to comment
84TAVeRT Posted August 26, 2008 Report Share Posted August 26, 2008 i figure 1 roll should do 3 or 4 layers in the 521... firewall, floor, backwall, and under the door panels... later, chris Quote Link to comment
ppeters914 Posted August 27, 2008 Report Share Posted August 27, 2008 I've heard (pun intended) that Q-Pads work pretty good: . I also believe they're cheaper than Dynamat. Quote Link to comment
Gensaiken Posted August 27, 2008 Report Share Posted August 27, 2008 I've heard (pun intended) that Q-Pads work pretty good: . I also believe they're cheaper than Dynamat. yeah, I've used those. A lot cheaper than dynamat but you have to kind of heat it up to get it to stay and form to where you are sticking it. Also a little hard to find locally. A friend happen to know a store but most places I went had no idea what I was talking about and tried to sell me dynamat. :rolleyes: Quote Link to comment
ppeters914 Posted August 29, 2008 Report Share Posted August 29, 2008 yeah, I've used those. A lot cheaper than dynamat but you have to kind of heat it up to get it to stay and form to where you are sticking it. Also a little hard to find locally. A friend happen to know a store but most places I went had no idea what I was talking about and tried to sell me dynamat. :rolleyes: Well, the person who recommended them lives in Arizona. Even then, they warmed 'em with a torch to mold 'em into place. I haven't looked for 'em in Washington, yet. Quote Link to comment
kaoss Posted September 18, 2008 Report Share Posted September 18, 2008 I used fat mat in my '92 mazda, it made a difference. I don't have a dyna matted vehicle to compair it too though. Quote Link to comment
dat521kid Posted October 11, 2008 Report Share Posted October 11, 2008 has anyone tried to spray any of that under the hood? mines is pretty beat up and i think it will make it look good but i want feedback, thanks. Quote Link to comment
sdsurf Posted October 11, 2008 Report Share Posted October 11, 2008 I was thinking of a roll on liquid applied waterproof membrane by tremco called 201. You can build up the mils and it says flexible... http://www.tremcosealants.com/commercial/products/product_detail.asp?selected_type=2&product_id=245 I can get it cheap which is why I may try... Albeit - very very permanent... Quote Link to comment
dat521kid Posted October 11, 2008 Report Share Posted October 11, 2008 hey sdsurf, is that for under the hood? if yes, is it flamable? Quote Link to comment
sdsurf Posted October 12, 2008 Report Share Posted October 12, 2008 i wouldn't use under hood... i would use as sound proofing on th floor boards and other cab areas Quote Link to comment
dat521kid Posted October 12, 2008 Report Share Posted October 12, 2008 darn.. im looking for something under the hood, any suggestions or am i just crazy? Quote Link to comment
