bonvo Posted August 25, 2012 Report Share Posted August 25, 2012 why not just cut the stockers? Quote Link to comment
ProjectFeint Posted August 25, 2012 Author Report Share Posted August 25, 2012 I was thinking about it but id rather not cut up the stock springs and just use them as rollers like micro said 1 Quote Link to comment
MicroMachinery Posted August 25, 2012 Report Share Posted August 25, 2012 ^^^Good man. ;) Quote Link to comment
ProjectFeint Posted August 27, 2012 Author Report Share Posted August 27, 2012 Got a set of d50 springs and ordered some kybs for the rear along with a little something special for the L20b ^_^ Quote Link to comment
ProjectFeint Posted August 30, 2012 Author Report Share Posted August 30, 2012 Soooooo Im in the process of changing the rear springs out, and I can't get the stockers out... I unbolted the bumpstops and the shock, and it looks like the halfshafts are preventing the control arm from going any lower. Can you take the top part of the bump stops off? Really lost :geek: Quote Link to comment
MicroMachinery Posted August 30, 2012 Report Share Posted August 30, 2012 I didn't have to. Can you get in there with a prybar and move the arms down further? I didn't have to remove the halfshafts when I did mine.. I think it's just the resistance in the bushings that you're fighting. Quote Link to comment
ProjectFeint Posted August 30, 2012 Author Report Share Posted August 30, 2012 That doesnt seem to be it, i put a scissor jack between the arm and body and its not really budging Quote Link to comment
bonvo Posted August 30, 2012 Report Share Posted August 30, 2012 drop the half shaft thats all thats stopping the are from swinging freely Quote Link to comment
Tristin Posted August 31, 2012 Report Share Posted August 31, 2012 You might be able to pry that rubber piece off the bottom of the arm... then slide the bottom of the spring out and then down. Otherwise youre going to have to disconnect the half-shafts to get them out. Quote Link to comment
ProjectFeint Posted August 31, 2012 Author Report Share Posted August 31, 2012 I ended up dropping the whole subframe to take the old coils out. But that's good to know! thank you Bonvo and Trisitin! (Going to have to redo it again soon anyways) Kybs Cut one coil off the d50 springs and this is how she sits now :cool: Quote Link to comment
ProjectFeint Posted August 31, 2012 Author Report Share Posted August 31, 2012 Also.... 2 Quote Link to comment
MicroMachinery Posted August 31, 2012 Report Share Posted August 31, 2012 D'oh! Had I seen that picture, I would have been able to tell you that those bump stops unbolt from the bottom. Good job, however :thumbup: That engine's lookin' sharp. Specs? 1 Quote Link to comment
ProjectFeint Posted August 31, 2012 Author Report Share Posted August 31, 2012 Thanks, the engine is a bored l20b with l18 pistons,W53 head with ported intake ports, Polished crank, and a mild cam. Also have a matchbox dizzy laying around and those dcoe 40s that I mocked up :) Quote Link to comment
dobo Posted August 31, 2012 Report Share Posted August 31, 2012 god damn that's a sexy l series. i thinks that's gonna be one nice 610 to drive when its done! 1 Quote Link to comment
ProjectFeint Posted August 31, 2012 Author Report Share Posted August 31, 2012 god damn that's a sexy l series. i thinks that's gonna be one nice 610 to drive when its done! Hope so! Ive fallen for the L series! It felt nice with the 60 hp barely running l18, Can't even imagine what she is going to be like with a decent powerplant Quote Link to comment
Skib Posted August 31, 2012 Report Share Posted August 31, 2012 a well built L can be a lot of fun :cool: 2 Quote Link to comment
ProjectFeint Posted September 1, 2012 Author Report Share Posted September 1, 2012 50% off pick and pull today and snagged these seats Saw this lonely 240z, took a look inside and pulled the nasty seat covers off like it was christmas.Thinking I should make a ratsun patch to cover that hole :lol: Quote Link to comment
ProjectFeint Posted September 2, 2012 Author Report Share Posted September 2, 2012 I was lucky that hundred shot of nos only blew the welds on my seat :( Quote Link to comment
bonvo Posted September 2, 2012 Report Share Posted September 2, 2012 i spy a subi in the backround Quote Link to comment
datzenmike Posted September 2, 2012 Report Share Posted September 2, 2012 Im getting a roadster pressure plate, also read somewhere that there is some fitment issues with the 4 speed bellhousing and teeth of the truck flywheel? Then again aren't all L - series transmissions compatible with each other in terms of engine to trans? All L series auto 3 and 4 speeds and standard 4 and 5 speeds will physically bolt up to L4 and L6 motors, but there may be clearance problems with the larger clutches, yes. Quote Link to comment
ProjectFeint Posted September 2, 2012 Author Report Share Posted September 2, 2012 i spy a subi in the backround she's my track car while the 610 is soon to be my daily :P Quote Link to comment
ProjectFeint Posted September 2, 2012 Author Report Share Posted September 2, 2012 Thanks for clearing that up Mike :) Quote Link to comment
ProjectFeint Posted September 7, 2012 Author Report Share Posted September 7, 2012 Some small updates... Bored the canon manifold to match the intake ports and soft mounted the carbs and got the linkage on. Removed the clutch fan from the water pump and grinded down pulley. Also got some new led socket holder thingys for the dash lights since the old ones kept falling out. Bay is done and painted and L20b is going in within the week :baby: Quote Link to comment
ProjectFeint Posted September 29, 2012 Author Report Share Posted September 29, 2012 Quote Link to comment
