Kirden Posted May 5, 2014 Report Share Posted May 5, 2014 I thought I wanted 3" blocks but I kinda hate mine now. I highly suggest getting the 720 4x4 springs and 1-2" blocks over using 3" ones. Something about the ride quality just doesn't feel right. I chose the 3" blocks cause they were cheap, but I wouldn't do it again. The 4x4 leaf springs will give you almost 2"s of drop, but they are softer than the stock springs so the ride quality is different. IMO if you really want the best quality, you can get either datsun 720 leaf springs from belltech and retro fit them with a 1" block, or measure your current spring pack and give northcountyspring.com a call. They can give you the drop you want and a stiffer spring for the best ride quality, but it's not cheap. Lastly there is the most expensive option of getting composite leaf springs, but honestly my stock steel ones have lasted 40 years and composites are only warrantied for 3-5 years, so I'd save those for a race project (they drop about 50lbs off the vehicle). The truck is looking good as ever willz. I saw your write up on the fuel cell and now we are looking at fitting one in my 620. I'm just a little worried because I believe my truck sites slightly lower, so I'm gonna look at going with a full aluminum cell that will fit between the cross bars where you made your mounts. Hopefully this will give me 1-2" moire ground clearance, but I'll end up losing a portion of my bed for the filler neck. The tings we do because we need moar lowar :crying: Quote Link to comment
mikeanike99 Posted May 5, 2014 Report Share Posted May 5, 2014 I have a set of 2" blocks with U-bolts wanna trade? Quote Link to comment
willz Posted May 5, 2014 Author Report Share Posted May 5, 2014 @Mikeanike99 Take the bottom flat leaf spring and put it on top, use the 2" blocks, and get some shocks. I used the KYB Gas-adjust on all 4 corners and love them. They will set you back almost $400 though if not more Quote Link to comment
mikeanike99 Posted May 5, 2014 Report Share Posted May 5, 2014 I ain't got $10 so defiantly not $400 I was thinking the Monroe air adjust they run about $60 for a pair and the work great. And I will try flipping the leafs. My leaf pack has 4 plus a 1/2 thick overload spring on the bottom should I remove that? And then put the next on top or just put that one on top? And what size tire are you running? I have 15x9.5 rally's so they are a little wider then yours. Quote Link to comment
heretic Posted May 5, 2014 Report Share Posted May 5, 2014 Rock Auto ... KYB rear GR-2's #344046 ... $19.00 each better than Monroe's IMO Quote Link to comment
mikeanike99 Posted May 5, 2014 Report Share Posted May 5, 2014 But I would prefer the air adjust Quote Link to comment
willz Posted May 5, 2014 Author Report Share Posted May 5, 2014 Bfgoodrich g force 205/55/15 The KYB gas adjust are my favorite so far, tried the Monroe, the air adjust, pinto..... The only thing is like more would be some fully adjustable dampening shocks Quote Link to comment
mikeanike99 Posted May 5, 2014 Report Share Posted May 5, 2014 Ok I am wanting a stretch on the tire would that give me a stretch at all? Quote Link to comment
willz Posted May 5, 2014 Author Report Share Posted May 5, 2014 Yea like 3/4" each side Quote Link to comment
willz Posted May 5, 2014 Author Report Share Posted May 5, 2014 It really all depends on the tires side walls, they aren't all the same. And I spent around 600 on mine, I don't remember Quote Link to comment
mikeanike99 Posted May 5, 2014 Report Share Posted May 5, 2014 I don't have money to get brand new tires so I have to go of what Craigslist has for cheap Quote Link to comment
banzai510(hainz) Posted May 5, 2014 Report Share Posted May 5, 2014 nothing wrong with 3 inch blocks. if you aint got 30-40 dollars you better think of something different. these will alwasy want money and if only rig alot of time for you to walk to your next job if you dont get fired for failure to show up. Quote Link to comment
mikeanike99 Posted May 5, 2014 Report Share Posted May 5, 2014 I want 3" blocks with 720 4x4 springs Quote Link to comment
willz Posted May 5, 2014 Author Report Share Posted May 5, 2014 Do it right the first time. It'll save you time and money. Prioritize your list. I lowered first, bought wheels, and had to wait for tires. Fixed problems, saved some cash, then built the fuel cell setup while the truck sat. Did some free extras like desmog, painting parts Quote Link to comment
mikeanike99 Posted May 5, 2014 Report Share Posted May 5, 2014 I have lowered my truck lifted it lowered it again. and now it sits with tons of take until I get all the stuff for lowering the back done. and it's also out of commission as my gaskets haven't arrived so its just sitting. Quote Link to comment
willz Posted May 5, 2014 Author Report Share Posted May 5, 2014 What happened to the stuff you used to lower it with the first time? Quote Link to comment
mikeanike99 Posted May 5, 2014 Report Share Posted May 5, 2014 They were 2" blocks and I want more then that Quote Link to comment
willz Posted May 5, 2014 Author Report Share Posted May 5, 2014 Start saving or find someone who wants to trade lol Quote Link to comment
mikeanike99 Posted May 5, 2014 Report Share Posted May 5, 2014 I asked Kirden if he wanted to trade Quote Link to comment
Kirden Posted May 5, 2014 Report Share Posted May 5, 2014 Not at the moment sorry, I'm saving to just get full steel lowering leaves. I'd rather do away with the blocks all together, but for now they get me close to my desired ride height even though I'm not exactly happy with the ride quality. The process willz explained about flipping that lower leaf will give you the equivalent of a 3" drop block though. Sorry we jacked your thread around Willz, but it's all for the good of Datsuns :) 1 Quote Link to comment
mikeanike99 Posted May 5, 2014 Report Share Posted May 5, 2014 Ok that seems easy enough...I hope. An then I can put my 2" blocks in for adddd drop! Quote Link to comment
willz Posted May 13, 2014 Author Report Share Posted May 13, 2014 I'll probably end up building a nice adjustable 4 link setup and the blocks can be used as paper weights Quote Link to comment
mikeanike99 Posted May 13, 2014 Report Share Posted May 13, 2014 Well I sold my 2" blocks so I don't have them....4" blocks ere I come!!! Quote Link to comment
willz Posted May 13, 2014 Author Report Share Posted May 13, 2014 how much does one sell blocks for Quote Link to comment
mikeanike99 Posted May 13, 2014 Report Share Posted May 13, 2014 I sold them for dirt cheap (actually cheeper then dirt) to Michael shaffer for $6 (He needed them more then I do) Quote Link to comment
