willz Posted January 22, 2014 Author Report Share Posted January 22, 2014 So I'm cleaning up for the night, things that I managed to finish tonight: exhaust is now hung back of cab has 6" of bed liner/undercoating on what looks like was sprayed from factory but had faded away passenger side door panel has been snapped in with the cotton backing and new leather Aluminum intake egr block off plate made (cant install due to the old bolts being too long new valve cover gasket and valve cover painted coyote tan Fuel line hooked up to fuel cell (finally) plans for tomorrow: install block off plate, new stainless hose clamps on errrrthang, finish drivers side door panel and install, sew a new shifter boot together out of the new leather/vinyl, get the bed ready and if I'm lucky I can get it on the truck tomorrow so that I can mount the fuel cell finally, route crankcase vent to the intake and put a breather on the valve cover, repaint the rear tail light cases silver and install new hardware on the lenses, route fuel filler line to original location as well as fuel cell vent line, hook up sending unit... cross my fingers and then crank her over 1 Quote Link to comment
willz Posted January 23, 2014 Author Report Share Posted January 23, 2014 Heres some updates for you peoplez made new braces in the rear out of 2"x2" (1/4" thickness) steel box tubing, the bottoms will be getting cut out so that I can raise the fuel cell that extra 2" and the aluminum block off plate I made Quote Link to comment
willz Posted January 23, 2014 Author Report Share Posted January 23, 2014 before: and after Quote Link to comment
Cpl620 Posted January 23, 2014 Report Share Posted January 23, 2014 that day looks clean. what did you use to do the frame? Quote Link to comment
willz Posted January 23, 2014 Author Report Share Posted January 23, 2014 I used a grinding wheel with an 80grit flappy disk to take it all back to bare frame, hit it with some etching primer, rust-oleum enamel, rust-oleum undercoating, then rust-oleum gloss enamel. Still need to throw the gloss on the new areas and a few others, but it makes it look real nice ;) Quote Link to comment
willz Posted January 23, 2014 Author Report Share Posted January 23, 2014 PS.. dont make a joke to your mother how; if someone slams into the back of your truck youre going to go "kaboom" she will not find it funny :frantics: 2 Quote Link to comment
willz Posted January 23, 2014 Author Report Share Posted January 23, 2014 So i dont know what happened to my "escutcheons" or whatever those plastic cup pieces are that go in the door behind the latch... so I don't have them cut out, only enough to put the latch through till I get a set. Same goes the armrests since I need to source a pair of black ones. other than that, they work great 1 Quote Link to comment
bonvo Posted January 23, 2014 Report Share Posted January 23, 2014 truck is looking nice man! been a while since i stopped in glad to see progress do yourself a huge favor though ditch that hitachi asap!! i might be able to help ya out in that department come spring 1 Quote Link to comment
willz Posted January 23, 2014 Author Report Share Posted January 23, 2014 I rebuilt the hitachi about a year ago and its doing pretty great, I'm currently working on getting a set of dual side draft 40 webers Quote Link to comment
bonvo Posted January 23, 2014 Report Share Posted January 23, 2014 ah well ill tell you from experience the difference a decent carb will make will surprise you hitachi just couldnt make a good downdraft carb to save there life Quote Link to comment
willz Posted January 23, 2014 Author Report Share Posted January 23, 2014 Yea I figured I'll build a nice 2.2 with a cam and dcoe's, port matched manifolds and some serious valve work/porting on a peanut head Quote Link to comment
BlackBird620 Posted January 24, 2014 Report Share Posted January 24, 2014 Better work faster to get that extra 200bones 1 Quote Link to comment
willz Posted January 24, 2014 Author Report Share Posted January 24, 2014 drilling just a few more holes and then the tank will be in! pics to come soon ;) Quote Link to comment
denmarkboy Posted January 24, 2014 Report Share Posted January 24, 2014 and placed where Its going to get mounted I like the placement , I need to do the same install. Except I want to keep my factory tank and add a secound for those long trips. You know the trips longer than an hour ....that's about as far as I can go ... You can watch my fuel gauge go down with every stop light . Quote Link to comment
willz Posted January 24, 2014 Author Report Share Posted January 24, 2014 seriously? I usually do 300 miles on a full tank ''/ Quote Link to comment
ggzilla Posted January 24, 2014 Report Share Posted January 24, 2014 In Japan, model series 620 was marketed as the "Datsun Pickup"' (but more commonly called the Datsun Truck) and the King Cab was the "Custom". They came with J15 engine only USA/Canada came with L-series engines. In the US, all the datsuns had number designations - 1200, 510, 620 etc... In japan the 1200 was a Sunny, the 510 was a bluebird - what did they call the 620?All these had the same model number in Japan and USA but the badges and marketing names differed in different countries. For example in Japan documents and parts catalogs and engine compartment ID plates it said 510 and even today in Japan it is common say 510 Bluebird. Quote Link to comment
ggzilla Posted January 24, 2014 Report Share Posted January 24, 2014 willz, great work on the 620. And nice pics! 1 Quote Link to comment
willz Posted January 24, 2014 Author Report Share Posted January 24, 2014 Fuel cell is finally in! uploading pics to photobucket as we speak, turned out better than I thought I had been worried about clearance on the bottom as the tank needs to sit lower with the 45 degree neck on it, still have an easy 6" from the lowest part of the tank (sump) to the ground B) Quote Link to comment
willz Posted January 24, 2014 Author Report Share Posted January 24, 2014 And pics!! heres the aluminum strap I bent cut the bottoms of these off so that the straps will fit up inside Quote Link to comment
willz Posted January 24, 2014 Author Report Share Posted January 24, 2014 straps each got two bolts with lock washers on each side Quote Link to comment
willz Posted January 24, 2014 Author Report Share Posted January 24, 2014 and here they are mounted on the tank Quote Link to comment
willz Posted January 24, 2014 Author Report Share Posted January 24, 2014 jacked the tank up and started working on clearance and fitment Quote Link to comment
willz Posted January 24, 2014 Author Report Share Posted January 24, 2014 drilled some holes and threw in some 1/4" bolts with lock washers and nylon nuts (might end up adding more hardware but its good for now) 1 Quote Link to comment
willz Posted January 24, 2014 Author Report Share Posted January 24, 2014 and i still got my minimum requirement of 6 inches of clearance that I wanted! 2 Quote Link to comment
