TENDRIL Posted April 25, 2014 Author Report Share Posted April 25, 2014 welp another 10 points for MYDAILYROUTINE !!!!! sourced a engine harness for me!!! out of a 93 turbo 4g63t he is the dude!! 1 Link to comment
jrock4224 Posted April 25, 2014 Report Share Posted April 25, 2014 text me .,,,,, had to go back to iphone 4 when 5s went swimming in my coffee...i dropped the ball ... shit got hectic .. its been done just need your approval on the rest Link to comment
MYDAILYROUTINE Posted April 26, 2014 Report Share Posted April 26, 2014 welp another 10 points for MYDAILYROUTINE !!!!! sourced a engine harness for me!!! out of a 93 turbo 4g63t he is the dude!! No problem man! I feel like a superstar with all the points I'm accumulating. I'm trying to source the fuel rail and cam angle sensor also, I'll keep you up to date. The harness wasn't easy to find, took me 7 days which is long compared to how fast I usually can come across parts. 1 Link to comment
510T Posted June 22, 2014 Report Share Posted June 22, 2014 Finally found and read through this epic build!!! Excellent work Ray I be watching :) 1 Link to comment
TENDRIL Posted June 22, 2014 Author Report Share Posted June 22, 2014 so all the stuff that has been done previously..... as far as bondo work/ firewall metal will be pretty much redone... now that i have a shop to do what i need/want to properly stayy posted 1 Link to comment
TENDRIL Posted June 22, 2014 Author Report Share Posted June 22, 2014 oh also i have the bell housing adapter on its way Link to comment
TENDRIL Posted June 23, 2014 Author Report Share Posted June 23, 2014 so i found a MS plug-n-play with EPROM ecu, for the 4g63t motor, since MDR harness guy fell through i dont know how good coil on plugs are but i was given a set of those as well, i think jeff (icehouse) said he had to do something with the ignition part of the MS for them... i will find out next up is pretty much taking the head to the machine shop. annnnd redoing somebody work Link to comment
TENDRIL Posted June 26, 2014 Author Report Share Posted June 26, 2014 doing stuff like floor pans rocker rust repair and 2-3 in body drop 4 Link to comment
TENDRIL Posted June 28, 2014 Author Report Share Posted June 28, 2014 the plan is to sandblast the cab 2maro, than i can set the rest of the floor, trans tunnel, firewall i stopped today though due to the fact i would kind of like to check where everything will be... mostly my steering box hole and front cab mounts, also considering redoing the inner fender wells, because the previous owner just hacked them up to not really fit over the front suspension .....and i dont want to be stuck with something that would take me weeks to fix after paint , that i can just do now... so after everything is said and done , if my tape isn't lying i should be around 2 1/2 in. body drop, not including the new cab mounts i need to fab. i have 4-link stuff ordered and on the way (rod ends and weld bungs) i went with 3/4 stuff because i just wasn't sure.... i bought tubing the bung welds snug into today surprisingly cheap i think 20 $ for 16' cut in half?, also picked up some 3/16 plate to do my, C / step notches, had already picked up some 1/4 plate for my tabs/ brackets than i just have to build a cross-member for the links , although i need to look into rear coil overs still, or maybe bags or both ... before i do most of this though i want the block and trans in and bolted, than i can have fun disclaimer: this truck will not scrape rockers 4 Link to comment
TENDRIL Posted June 29, 2014 Author Report Share Posted June 29, 2014 it is :D life is a beach, when you're sand blasting! 1 Link to comment
TENDRIL Posted June 29, 2014 Author Report Share Posted June 29, 2014 these used to line up ... :sneaky: this is supposed to be in the center of the rectangle, will adjust for it when i fix fire wall will need to make small notches in front floor pan, maybe my body mounts will help it clear... one of the reasons i want/need to redo the inner fender well another and 4 link stock... 2 Link to comment
wayno Posted June 29, 2014 Report Share Posted June 29, 2014 I thought you were just shoveling it off the ground, it all looks the same color around there, sandy color. :lol: Progress forward is always better than no progress at all like at my house, it's sad when one looks forward to yard work over working on the Datsun and making it better. I need a new roof also, not looking forward to doing that. 1 Link to comment
TENDRIL Posted June 29, 2014 Author Report Share Posted June 29, 2014 this is the first weekend i have been able to work on it, so in two days i feel pretty accomplished, and sandy 2 Link to comment
Draker Posted June 29, 2014 Report Share Posted June 29, 2014 Beach sand contains silica and when used as blast media it creates PM10. rabble rabble rabble illegal in California.. cancer, no babies. You know the rest. Seems to work great and I know it's a lot cheaper than blast media. Somewhere Indy has a woodie over those last few pictures. Truck is sweet man. Link to comment
TENDRIL Posted June 29, 2014 Author Report Share Posted June 29, 2014 no i didn't know that stuff really... but this is what they sold me for sand blasting :hmm: Link to comment
wayno Posted June 29, 2014 Report Share Posted June 29, 2014 They can call what they sell anything they want, it's not likely sand from a beach. Fact is beach sand doesn't work very good for sand blasting, as I have tried it in a blasting cabinet, it took a long time to get anything done, I finally bought actual blasting media, the difference was night and day. Link to comment
TENDRIL Posted June 29, 2014 Author Report Share Posted June 29, 2014 im sure it was filtered for grit size and so fourth, although good to know anyhow! Link to comment
hang_510 Posted June 29, 2014 Report Share Posted June 29, 2014 looks a lot better than when i saw it. good work! Link to comment
D.D.Anderson Posted June 29, 2014 Report Share Posted June 29, 2014 Wow... speechless, good work and documentation.... this must turn out fantastic. Link to comment
