wayno Posted June 29, 2014 Report Share Posted June 29, 2014 It takes a while to read the thread title now. 2 Link to comment
Busta Nut Posted June 30, 2014 Report Share Posted June 30, 2014 Dude....amazing!! Can't wait to see this in person....... Link to comment
TENDRIL Posted June 30, 2014 Author Report Share Posted June 30, 2014 you will be here next weekend right? Link to comment
Bory Posted June 30, 2014 Report Share Posted June 30, 2014 I'm exhausted, just reading your title! Ha- Link to comment
Busta Nut Posted June 30, 2014 Report Share Posted June 30, 2014 you will be here next weekend right? Yessum........ Link to comment
AtomChurch Posted June 30, 2014 Report Share Posted June 30, 2014 Can't wait to see this in person. 1 Link to comment
TENDRIL Posted June 30, 2014 Author Report Share Posted June 30, 2014 got my adapter in the mail!!! so bill is probably the coolest guy in town that does what he does complete with a personal letter and dvd with instructions 2 Link to comment
jrock4224 Posted June 30, 2014 Report Share Posted June 30, 2014 3 link wishbone to avoid moving the gas tank... my mazda foulink with trangualtion bars rear facing ... hard on pinion bearings ... but s i could keep tank location ... swap the triangulation bars to the front for a better design .. this was ten plus years old and worked for the whole time .. not ideal for high horsepower and performance .. but i was mini trucking...i hate fuel tanks in the bed .. and i had 15 gallons of air out back .,.. 1 Link to comment
TENDRIL Posted June 30, 2014 Author Report Share Posted June 30, 2014 perfect !! so is that what is called bag over axle ? Link to comment
TENDRIL Posted July 1, 2014 Author Report Share Posted July 1, 2014 cut out the old gap filler had to remove some things proceeded to put the bed back on to locate wheel well centers and cab and bed spacing had to cut off the old front cab mounts for cab to drop down . back to centering about how much axle needs to move forward to be center, not a problem with the link suspension my drive shaft might only be about 3 ft. long maybe less.... :ninja: anybody have an idea about how far away the bad and cab should be? where i stopped for the day 4 Link to comment
AtomChurch Posted July 1, 2014 Report Share Posted July 1, 2014 I like it without the roll bar. Though I thought the spider web was cool! 2 Link to comment
TENDRIL Posted July 1, 2014 Author Report Share Posted July 1, 2014 i still think i will put the web somewhere because i like it also !! 1 Link to comment
AtomChurch Posted July 1, 2014 Report Share Posted July 1, 2014 I can take a measurement on my 521 tomorrow and let you know how far it is away from the cab. Link to comment
TENDRIL Posted July 1, 2014 Author Report Share Posted July 1, 2014 cool that would be sweet! Link to comment
wayno Posted July 1, 2014 Report Share Posted July 1, 2014 As I said, there are a few ways to go about this, most all of them will necessitate a shorter driveline, except maybe a couple ways. How soon you doing the link suspension, if in the next 3 months or so, then wait it out and do nothing till then about the gap. Link to comment
AtomChurch Posted July 1, 2014 Report Share Posted July 1, 2014 As I said, there are a few ways to go about this, most all of them will necessitate a shorter driveline, except maybe a couple ways. How soon you doing the link suspension, if in the next 3 months or so, then wait it out and do nothing till then about the gap. Why? Why not set the gap for the right look then either shorten the frame or whatever else is needed then figure out the length of the link bars for the RIGHT distance between cab and bed/frame to center the rear wheel? He is not using the 520 frame. And the mazda frame is the wrong length. Link to comment
TENDRIL Posted July 1, 2014 Author Report Share Posted July 1, 2014 mitsubishi frame, and i will be digging right into the 4 link as soon as my rod ends show up. as for the drive line it already has to be 100 % custom made since i am mating a dsm motor to a Toyota w58 trans to a Mitsubishi LSD, i have always wanted the proper body lines, and now i can achieve them, (almost considered a ute build 1 piece body with sweeping pillars ) i have it all almost sorted, the hardest part is lifting the cab and bed off by myself...to take measurements and stuff 1 Link to comment
wayno Posted July 1, 2014 Report Share Posted July 1, 2014 mitsubishi frame, and i will be digging right into the 4 link as soon as my rod ends show up. as for the drive line it already has to be 100 % custom made since i am mating a dsm motor to a Toyota w58 trans to a Mitsubishi LSD, i have always wanted the proper body lines, and now i can achieve them, (almost considered a ute build 1 piece body with sweeping pillars ) i have it all almost sorted, the hardest part is lifting the cab and bed off by myself...to take measurements and stuff I did the UTE thing, it's to much work, never again. Link to comment
AtomChurch Posted July 1, 2014 Report Share Posted July 1, 2014 Did lacey's panties drop when she saw it? Link to comment
TENDRIL Posted July 1, 2014 Author Report Share Posted July 1, 2014 it was dark :rofl: 1 Link to comment
wayno Posted July 1, 2014 Report Share Posted July 1, 2014 What kind of exhaust is that on the 510? Is that you giving everyone the finger? 2 Link to comment
TENDRIL Posted July 1, 2014 Author Report Share Posted July 1, 2014 ratsun salute :fu: Link to comment
