gettin crap MPG
Newkid
well since ive got it the gas mileage has been in the toilet, when i first got the 620 i did:
spark plugs
spark plug wires
cap and rotor
air filter
fuel filter
oil change
made sure all the tires are properly inflated( might have to check again to make sure they are still at correct psi)
idk what it could be idk the rpms im running on the freeway since i dont have a rpm gauge in there yet, i intend to get one soon, but it seems like im at the gas station a lil too often.. i know there are other things i can check to see what else can cause bad gas mileage but i dont have a clue, im still learning about CARB vehicles, i was so used to EFI cars
so what do u guys think it could possibly be??
  • Replies 21
If this is around town, short trips to work and home, to the store and back with the motor cold with the choke on much of the time.... I can see that.
Check that your choke shuts off in about 7 minutes or so. By off I mean completely open.
Sounds about right. Too much Choke would definitely hurt mileage.
But consider it's a truck with low gearing, a relatively large engine, and higher therefore less aerodyamic. It's not going to get what a 510 gets even with the same engine.
My EFI minitruck Mazda gets 16 in town and 24 on the highway.
Weight is a big factor as well. Every pound takes gas energy to accelerate up to speed.
Driving habits are another. Some people are on the gas off the gas on the gas off the gas... this is how they drive. Others don't anticipate stops and speed along only to hit the brakes at the last possible moment. Every time you use or have to use your brakes you are throwing away the gas you just used to get the vehicle up to speed... thrown away. See the light changing way up ahead?? Well slowly begin letting off on the gas and begin slowing down. It might be even possible to get there after it's turned green so you've saved some momentum. What the fuck is your hurry????? I go a few over the posted limit and if some asshole behind me is in a hurry he can fuck himself. I'm in no hurry and I'm going faster than the limit so rub salt. Have to get to work? Who would speed to go to work??? Leave 5 min sooner and take your time, enjoy the ride/music/scenery and stop filling up as often.
Speed? In town you drive at 30 MPH. On the highway you drive 60 MPH. Did you think you only need twice as much power to go twice as fast? Think again... it takes at least 4 times as much. Going the speed limit saves big time out on the highway.
Ill have to check the choke to see if its the choke is turning all the way off tomorrow but when I usually start the truck I just lightly step on the gas to warm it up till it can idle under its own power, if I don't do this it will just die, I don't think the idle will turn on when I start the truck.. is there a manual choke cable in the cab somewhere I'm over looking
With my kc620, when I had L16 with u67 head, weber, 5spd and decent cam, with 4.37s I pretty much always got 17. When I went to 4.11 and peanut head it went up a little, about to 19. When I finally put the L20 in with the decent cam, weber, 5spd, 4.11 and peanut head I started getting 23-25. I had a stock carb on for a bit and was getting 28. This is with both city and highway driving. So I agree with checking the timing and the carb
I believe its carb problems cuz yesterday it drove fine to work and this morning it was really sluggish and it felt like I had to push it harder just to get it up to speed...my morning commute to work every morning is about 20-25 miles on the freeway, so about a 45-50 mile round trip. So going with a lower gear and puttin this five speed I have in should really drop down the rpms and help with gas mileage..right??
Just remember if you put a 5 speed in you have to drive for years to recoup the cost of the swap with any savings in gas mileage.... but I agree and i am doing a 5-speed swap too ;) I just found an 83 280ZX thats being parted out, just have to drive an hour to take the trans out.
Its funny i just looked at my carb yesterday, tightened up the nuts holding it on (they WILL vibrate loose if you dont use locktite) and adjusted the ide mix a little and it seems to have done better on the drive back home and to work this am.
