hessianben Posted February 22, 2011 Report Share Posted February 22, 2011 what! you got a flat leaving the tire shop!? on a new set of tires??? ;( WTF? anyway, pics! Quote Link to comment
motavated Posted February 22, 2011 Author Report Share Posted February 22, 2011 My uncles tire shop could not mount them even with the "BAZOOKA". So they used tire inner tubes. I bet one had a hole and it got flat an the way home. O WELL! I will post them tomorrow. I was out in the cold for an hour waiting to get a tire iron long enough to take them off. LOL! Quote Link to comment
motavated Posted February 22, 2011 Author Report Share Posted February 22, 2011 Fine here are some pics.... THEY ARE HUGE! This is how it looks with 14x6 front and back. Quote Link to comment
bonvo Posted February 22, 2011 Report Share Posted February 22, 2011 flare that bitch Quote Link to comment
motavated Posted February 22, 2011 Author Report Share Posted February 22, 2011 Ben I need to borrow your flare gun! I might even need to buy steroids flair kit. Quote Link to comment
Radim Posted February 22, 2011 Report Share Posted February 22, 2011 15x10s? Easy Peasy, i run 205/60/R15 on my 15x10 -40.... Tons of clearance too, hauled an L20B with Trans the other day without air in the struts, frame hit tires didn't even touch the fender. Quote Link to comment
hessianben Posted February 22, 2011 Report Share Posted February 22, 2011 I like it!! If you wanted to- Zg flares would look awesome on there Quote Link to comment
Pacific coast Datsun Posted February 22, 2011 Report Share Posted February 22, 2011 Ben I need to borrow your flare gun! I might even need to buy steroids flair kit. You read my mind :D Flare the back & run the 15 x 10's out back & the skinny's up front. Quote Link to comment
motavated Posted February 23, 2011 Author Report Share Posted February 23, 2011 Honestly this is what I am thinking right now... I need some 15x8 for the front. I don't want to flair the rear and not the front. So for the mean time. I will run the 14x6 for a while and try to find the 15x8.... ANY ONE GOT SOME 15X8 Laying around???? I also want to build a LSD rear end and four link my truck. HOPEFULLY the guy who installed that SUBI diff on the Datsun rear posted how he did it. I want that info! My front end is retarded. I am tired of them being negative chamber all the fucken time. I am looking into building adjustable upper control arms. I can fix that problem with buying some drop spindles. But I have to use 17 wheels or bigger... I like my 14 and 15's wheels very much. I want to keep it that way... I will keep you posted Quote Link to comment
Pacific coast Datsun Posted February 23, 2011 Report Share Posted February 23, 2011 Im liking that adjustable upper arm !! I could build that of modify the stock ones ;) Quote Link to comment
motavated Posted February 23, 2011 Author Report Share Posted February 23, 2011 How I see it You can lower or raise the 620 and it will keep the suspension perfect. The other way you can do it and it much easier is this way. I have talked to Bee and he looks interested. I can do it. But I need a good welding machine for good penetration and time.. For the mean time. Just planning shit... Quote Link to comment
Pacific coast Datsun Posted February 24, 2011 Report Share Posted February 24, 2011 Kool arms. Adam, i wonder if just the adjustable ball joints can be purchased ? If so i can make the rest & graft onto a stock upper arm. Quote Link to comment
motavated Posted February 24, 2011 Author Report Share Posted February 24, 2011 Kool arms. Adam, i wonder if just the adjustable ball joints can be purchased ? If so i can make the rest & graft onto a stock upper arm. YES YOU CAN!!! I have them here. I don't know if its the same ball joint the 620 has though. Those pictured are from a Integra... http://www.skunk2.com/mm5/merchant.mvc?Screen=PROD&Product_Code=916-05-5670 My only concern is will it hit the rim? Quote Link to comment
BEEBANI Posted February 24, 2011 Report Share Posted February 24, 2011 the other issue is whether or not you'd be able to actually tighten the bolts while the wheel is on the truck? Quote Link to comment
motavated Posted February 24, 2011 Author Report Share Posted February 24, 2011 the other issue is whether or not you'd be able to actually tighten the bolts while the wheel is on the truck? I don't think you can. BUT! You can adjust the arm bolts with shims. SO what is it sticks out a little? Add some shims and BAM! Its ok again. Quote Link to comment
motavated Posted February 24, 2011 Author Report Share Posted February 24, 2011 I think you can eye ball it pretty good and have enough room to add shims and let the alignment guy do the rest. Quote Link to comment
motavated Posted February 24, 2011 Author Report Share Posted February 24, 2011 Also what can be done is take it to the alignment's guy and let him tell you how much its off. Go back home adjust it and add a little more to make the wheel positive chamber and then let the alignment guy add shims.... Quote Link to comment
motavated Posted March 14, 2011 Author Report Share Posted March 14, 2011 My hood flew open and I fucked shit up. I have everything now but a straight hood. Also how do you install this? I must have the wrong alt bracket. I got this one from the yard... That is why the alt hits on my truck. But how do you bolt the alt on this? Quote Link to comment
Farmer Joe Posted March 15, 2011 Report Share Posted March 15, 2011 on that bracket the front mounting bolt threads into the bracket from the front holding the front tab of the alt. the back one is just a nut and bolt that holds the back alt tab there.. thats the same bracket on my truck i think.. Quote Link to comment
motavated Posted March 15, 2011 Author Report Share Posted March 15, 2011 Mine looks like this.... Looking at this picture. I think I have my bracket upside down... I AM SO STUPID! Problem solved! Quote Link to comment
motavated Posted March 15, 2011 Author Report Share Posted March 15, 2011 The alt bracket made a huge difference. I have lots of room now. I also fixed the hood and added the new hinges micromachinery sold me. Thanks dude! Quote Link to comment
Rob W. Posted March 15, 2011 Report Share Posted March 15, 2011 Man you are one tenacious dude. I applaud you keepin at it through all the crap. Good looking truck can't wait to see it painted. Thanx for recording all the good the bad and the ugly Quote Link to comment
datsun_620king Posted March 16, 2011 Report Share Posted March 16, 2011 WOW is all i can say im new to forum and i just read your whole build great looking truck and thanks for all the info and pics you posted it will really help me with my build alot. One question for you tho your front control arms are off a 87 pathfinder right and the bolted in to factory location? i have been trying to find front control arms forever and have had no luck and i really want my 78 king cab back on the road with a sr20 under the hood. Quote Link to comment
motavated Posted March 16, 2011 Author Report Share Posted March 16, 2011 The upper control arms are custom built by a guy named beebani. He is on here and can probably build you something nice. The lower ones are stock 1979 620 control arms ball joint. Thanks. I am now driving the truck every day everywhere. It is a learning experience and just like everyone else. You learn alot from your first cars. If I were to have money and have another 620. I would do things a little different. He he he! Quote Link to comment
motavated Posted April 3, 2011 Author Report Share Posted April 3, 2011 Starter went out on it. Got a starter from a Maxima, the gear reduction one. FUCKen Shit! Turns the motor on in a fraction of a second! Cost me 15 buxs! But waited 2 hours to pay on a half of sale day. Quote Link to comment
