Projekt.....1972 wagon
jrock4224
Any chance of it ever being done.
touche naner......touche'...I'm trying...time to stop feeling sorry for myself...
hey, dat,  asked for your number the other day .........i feel like that's something i should have
and again did zach show u his rx4
izzo...too patina for me.....
  • Replies 594
clean...bondo and all....
fuck doors need work ... filler, block, glaze, block ,  then epoxy prime,  high build 2k prime.sand ...maybe re prime maybe not sand again if prime again then ole single stage enamel .....pfffttt it period correct....lot of the datto colors aren't formulate din bc/cc.....i might in the end do that over the enamel
If it is black 93-94 then yes i saw it,, Where do you think Zach A. Lac gets his money to buy those cars?  He never seems to sell so it aint from profit from the last one..
And the radiator place in Aberdeen is still there but my brothers said Ole Slim died so not sure if they fix or just replace radiators now..( they were closed when we went there Saturday)  It`s on the Wishkah river just inside Aberville ,,  817 East Market st ,,,,,,
FYI there is a wicked cheap thrift store just around the corner before you get to the old high school pool,, i got a zip up hoodie and a pull over for just $3.47 total.
stupid doors..2 to go......yea now i gotta make lines.......booooooooo
extra set of round tops su's for a test clearance.
need a float assembly for a rear carb ..... gonna add it to the wtb list i guess...
i forgot this was a a/c car .... there's a shit ton of extra holes in the fire wall.....ok a few .... but a few big ones..... im just gonna re a/c it ........
on the 12thof nevurary
  • Like 3
  • 3 weeks later...
went and worked sat ...... pulled the rear brake hard line and vent line out of the tranny tunnel......did some other little things to prep for the tranny tunnel mod.....
what is this vent line for it goes down the tranny tunnel and to the rear vapor cannister........ that much i know....my question is what did it hook up to onthe engine side of things....mine ended at a union and was inthe tranny tunnel right under the fire wall on top of the tranny......not sure what it hooked up too but curious....wha tit did hook to .....
heres the line...
when we were done we hit the park to fly some planes with hans daughter....it  was shortlived ....mid air collision.....i was flying upside down right on the deck and hans came through at about a 30 degree angle .... his 54 inch wingspan chopped up my 4o inch wingspan plane ......his is saveable mines needs a new fuselage and canopy....lost a motor again snapped the shaft off...
mine
his
ffa debris field....lool
last weekend helped build the local on road track....
couple new scale spec cars for this year
Every time you post about "working" at Hans, it turns into playing with toys... every time you play with toys its always a catastrophe. Planes in telephone lines, planes in the lake, mid-air collisions. You two are trouble.
its how we wrap up our work sessions ...... usually it takes about thirty minutes to fly about 8 batterys a piece between the planes we bring.....this trip was a catastrophe.....i dont report about the boring uneventful trips....just the oops ones...
doors all stripped finally ... argh stripping jambs yuck...doors in bare metal i guide coate them to so i could sand them and see what i was working with ... my rprefered way anytime u go to the bare metal ... a little thinner will wipe all these off but some 80 grit n a long board .....sand it down and the guide coat will show me where li need to work.....dark black spots will require filler ... the rest of the lighter marks will block out in primer....doors nthe left are un sanded guide coat ... doors on right are the sanded to show the high and low areas....
these are the passenger doors that were replaced at some point along withthe fender.....wish they would found soem decent doors ... the upper body line looks like it got hoofed at a drive through game farm......and i thought the drivers side were the rough ones....um no
drivers side ... pretty nice compared to the passenger......actaully way ncer then i thought
time to start the body work on the outsides.....gonna weld up mirror holes and patch one rusty spot in the door jamb side of the rear passenger side
haven't read the whole thread yet but i've looked at some of the latest purdy pics and i gotta say you do some damn clean work dude! I like where this thing is going
Here`s the Cliffsnotes version :
Buy car ,, disassemble car , play with toys . the end
  • Like 3
