slodat Posted September 8, 2008 Report Share Posted September 8, 2008 Right on! I'm excited to see that engine in your 510. I want a ride!! Quote Link to comment
lynchfourtwenty Posted September 8, 2008 Report Share Posted September 8, 2008 nice mikey.. i want a lightend flywheel too Quote Link to comment
blueridgespeed Posted September 11, 2008 Report Share Posted September 11, 2008 what did the flywheel weigh? before and after lightening, if you know. -J Quote Link to comment
808DA6 Posted September 12, 2008 Report Share Posted September 12, 2008 The machine shop was these guys: Rocket Empire Machine (503) 257-7947 6935 Ne Glisan Street, Portland, OR 97213 Good work, but they don't actually test the flow. BUT they've been doing L-heads and 22RE heads forever. -Brian Quote Link to comment
Phlebmaster Posted September 12, 2008 Report Share Posted September 12, 2008 Did you get her running? I like that L-18..looks clean. :) Quote Link to comment
DISLEXICDIME Posted September 16, 2008 Author Report Share Posted September 16, 2008 i started it but i couldnot drive it because the clutch is not engaging. i think one side of the fork poped off the throw out berring Quote Link to comment
808DA6 Posted September 16, 2008 Report Share Posted September 16, 2008 sweeeeeeeet! how's it sound f*cker? i'm gonna have to stop by your place this weekend! too bad you can't beat on it yet. -Brian Quote Link to comment
slodat Posted September 16, 2008 Report Share Posted September 16, 2008 How does it sound?? Quote Link to comment
DISLEXICDIME Posted September 16, 2008 Author Report Share Posted September 16, 2008 sweeeeeeeet! how's it sound f*cker? i'm gonna have to stop by your place this weekend! too bad you can't beat on it yet. -Brian stop bye and hear it this weekend How does it sound?? it sounds realy smooth with just a small lope. it dont sound like a cam'd 350 like your car. lol Quote Link to comment
slodat Posted September 16, 2008 Report Share Posted September 16, 2008 it sounds realy smooth with just a small lope. it dont sound like a cam'd 350 like your car. lol A little 4 banger sounding like a 350... :D Quote Link to comment
DISLEXICDIME Posted September 16, 2008 Author Report Share Posted September 16, 2008 hell yes when it idols. some one asked me the other day when i was driveing it if it had a v8 in it Quote Link to comment
DISLEXICDIME Posted September 17, 2008 Author Report Share Posted September 17, 2008 well i took it on the break in run and broke it i forgot to check cam bolt and make sure it was tight. t poped offf a block a way from my house :mad::mad: but boy was that thing pulling :) now i have to reset the tensioner line it all up and see if it bent the valvs Quote Link to comment
City Hunter Posted September 17, 2008 Report Share Posted September 17, 2008 man all that work. I had to push that damn car back most of the way while mikey steered. Felt good until it broke :D I just hope that cam doesnt have too much lift to where it bent valves. I thought it sounded like it didnt have compression. I never heard any mechanical carnage though so hopefully everything is alright. At this rate my z car is gonna be running for your 10 does mikey :) All I have left is to install a peice of 3/8 fuel line, disable the electric fuel pump power, and put some gas in the tank Quote Link to comment
lynchfourtwenty Posted September 17, 2008 Report Share Posted September 17, 2008 sounds like a rookie mistake hahahahahha, kinda reminds me of the time me an kyle forgot to tightin the cam bolt on that ka 620 Quote Link to comment
808DA6 Posted September 18, 2008 Report Share Posted September 18, 2008 doooooooood. that sux mang. I forget how to get to your place again. Can you pm the address? Not sure if i'm gonna make it out this weekend. $$$ OT opp'y again at work. Gonna have a shit ton to waste on the SR soon. -Brian Quote Link to comment
DISLEXICDIME Posted September 18, 2008 Author Report Share Posted September 18, 2008 well i pulled the front cover got the tensioner out . it was compleatly un dun . the cam stoped in a way that the valvs where almost all closed. so i pulled the chain off . spun the moter to 0 then turned the crank 90degrees so all the pistons where half way through there stroke . then i checked the valv lash on all the valvs and the lash was good on all the valvs except the number 3 exhaust valv there is way to much of a gap between the lobe and the rocker.:( I think i bent a valve :poop: Quote Link to comment
slodat Posted September 18, 2008 Report Share Posted September 18, 2008 ahh dude. Sorry to hear it! Valve should be manageable. Quote Link to comment
DISLEXICDIME Posted September 18, 2008 Author Report Share Posted September 18, 2008 just as i thought i bent the #3 exhaust valve :( :(:( but hopefully a starion buddy can fix it for me since i am low on cash Quote Link to comment
hang_510 Posted September 18, 2008 Report Share Posted September 18, 2008 stock EX valve? ill send you 4 from a W58 if needed Quote Link to comment
DISLEXICDIME Posted September 18, 2008 Author Report Share Posted September 18, 2008 thaks hang but i bought one any one know what the part number is for the felpro front cover set that has the oil pan cut out piece in it Quote Link to comment
DISLEXICDIME Posted October 4, 2008 Author Report Share Posted October 4, 2008 its alive i broke it in today i was doing about 25 in second and when i stomped on the gas it broke the tires loose. boy was it fun sliding that thing today. I cant tell you how good it felt to drive my car. It just felt right. i reved it to 7000 once and it was so smooth. it felt like just wanted to keep on going. i know with a little more tuning i can pull more power out of it but that will have to wait till i break it in all the way. Quote Link to comment
slodat Posted October 4, 2008 Report Share Posted October 4, 2008 Congrats Mikey! it has been quite a while since you have driven the dime! Quote Link to comment
Icehouse Posted October 4, 2008 Report Share Posted October 4, 2008 Thats awesome!! we need a video of it, O and some pics :D Quote Link to comment
DISLEXICDIME Posted October 10, 2008 Author Report Share Posted October 10, 2008 well i figured out what the clack coming from my trans is! my engine is eating the trans . nelsson told me a truck 5 speed wouldnt hold up to this engine but we both figured it would last longer then a week . now i need a z car tranz :) if only he would have told me the truck trans wouldnt hold up be for i putt it in . he thought i still had a z trans in it. Quote Link to comment
lynchfourtwenty Posted October 10, 2008 Report Share Posted October 10, 2008 whats the diff between the 2? Quote Link to comment
